Old 03-05-2013, 08:38 PM   #1
fmfpunk OP
Hooligan in training
fmfpunk's Avatar
Oddometer: 1,170
2001 KTM 400 EXC: crankcase breather?
Bike is used, and i don't know its history. Breather hose comes off motor and is open to atmosphere behind the motor. Is this correct? I can't find any info on parts fiches or manuals i have. Buddy says it should go to airbox, but i don't see anywhere for it to go.
Thx for any info you can send my way.
I'll slack you off, you fuzzy little foreigner. I'll fill your bagpipes with Wheatena!
fmfpunk is offline   Reply With Quote
Old 03-05-2013, 08:58 PM   #2
overlander
Gravel Travel Tours
overlander's Avatar
Oddometer: 400
Breather
Should be connected to a spigot on the carb at the air box boot. Most will plug that spigot and install a small vent filter to the hose and route it up high away from potential water ingress. Hope this helps!
I drive way too fast to worry about cholesterol!
overlander is offline   Reply With Quote
Old 03-06-2013, 06:46 AM   #3
fmfpunk OP
fmfpunk's Avatar
Oddometer: 1,170
thx. Yeah,that's not there. Think that part of the carb has been replaced with one of those power now widgets. Guess easiest thing is to get a little filter
Times are GMT -7.   It's 11:12 AM.
