Old 03-06-2013, 05:37 PM   #1
woahblackbetty OP
Oddometer: 20
1979 xr500
Picked this little under-powered toy over the weekend. ;D ;D
1979 XR500
The seat needs to be rebuilt. Mice got into it and built themselves a nest in the airbox. Had a lot more power once that was cleaned out.
Still needs a tune up to be 100%, currently running a can of seafoam and tank of fresh gas through it. Will be catching all the standard maintenance points in the coming weeks
Original owner's manual was in a ziploc bag in the tool bag.
Tucked into the lineup... One oddball rectangular light!
woahblackbetty is offline   Reply With Quote
Old 03-06-2013, 05:45 PM   #2
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,634
That's one sweet line-up!
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman is offline   Reply With Quote
Old 03-06-2013, 05:52 PM   #3
stiggs13
stiggs13's Avatar
Oddometer: 203
Nice pick up
What year is the CT-90?
stiggs13 is offline   Reply With Quote
Old 03-06-2013, 06:10 PM   #4
woahblackbetty OP
Oddometer: 20
Thanks!!
Originally Posted by stiggs13 View Post
Nice pick up
Honestly not sure, it's a friend's bike that I'm slowly piecing back together for him.
Old 03-06-2013, 07:50 PM   #5
Gadget Man
Out in the Garage...
Gadget Man's Avatar
Oddometer: 92
Wink
I once owned a 1979 XR 500. I bought it brand new in 1980.
It was never meant to be street legal. But "back in the day" I went to the license bureau and just told them it was a Honda 500 and they gave me a plate.
I bolted it right on the rear fender and rode that bike all over northern Minnesota for several years. I called it my two wheeled tractor. It was a great bike.
I also had a 1972 Honda CT 90. Another awesome bike. It had the high/low gear box with the automatic 4 speed.
I would love to find either one of those bikes for sale today.
Good luck.
Gadget man
My Kids May Be Smarter Than Me, But I Know More.
Current bike.
2013 V-Strom 650 Adventure
Gadget Man is offline   Reply With Quote
Old 03-11-2013, 02:04 PM   #6
woahblackbetty OP
Oddometer: 20
I've been naughty again...
GS500 wheels, axle diameters match to the XR500. Just need to get calipers & master cylinders sorted. The front wheel is already drilled & tapped from the factory for dual disc. Chain pitches match also! Like it was meant to be...
Old 03-11-2013, 04:17 PM   #7
woahblackbetty OP
Oddometer: 20
Positive proof of concept...
A minor interference that will have to be rectified. This lug mates to the original front hub and secures the drum brake.
Old 03-11-2013, 06:40 PM   #8
woahblackbetty OP
Oddometer: 20
Old 03-11-2013, 08:39 PM   #9
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,086
Dig the vintage sumo concept. Plan on doing that to my XL600R. Are those Suzuki GS500 wheels?
Carter Pewterschmidt is offline   Reply With Quote
Old 03-11-2013, 09:23 PM   #10
woahblackbetty OP
Oddometer: 20
Yessir!!
The GS500 and XR500 share front and rear axle diameters (15mm front & 17mm rear) as well as chain pitch (520).
Simple drop in and install spacers front & rear, up the rear sprocket to a 49T (JT Sprockets makes one) which is the closest match to the original 14/48 ratio of the XR500.
Going from a 130/80-18 to 130/70-17 isn't too bad of a drop and the 1T higher on the back will give a slight torque increase (because an XR500 really needs more torque right??)
Obviously still have to get calipers & master cylinders squared away. I'm planning on using a KLR600 front wheel paired with the stock XR500 rear wheel for offroading. The KLR600 is also a 15mm front axle so I'll have to make sure that whatever my solution for front brakes is adaptable to that hub configuration.
woahblackbetty screwed with this post 03-11-2013 at 09:29 PM
Old 03-14-2013, 01:19 PM   #11
woahblackbetty OP
Oddometer: 20
After some consideration I have decided to try rotating the fork tubes 180* to remove the interference of the drum brake lug.
This will hopefully also allow me to utilize that lug out in front as a mounting point for part of the front caliper bracket.
I have a line on a GS500 rear caliper and front disc locally. Those parts plus the other farkles I'm collecting along the way have me simply needing to fab brackets and wheel spacers!
'79 XR500 -*-'74 MT125
Old 03-15-2013, 07:19 AM   #12
woahblackbetty OP
Oddometer: 20
49T rear sprocket is virtually the same size as the rear disc.
Old 03-15-2013, 09:30 PM   #13
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,769
NICE!!
bam balam!
wrk2surf is offline   Reply With Quote
Old 03-16-2013, 04:12 AM   #14
Pigford
British
Pigford's Avatar
Oddometer: 952
I think you may have some serious handling issues reversing leading axel forks The wheel will have a tendancy to "drop-in"
Good to see you giving it the personal treatment..... but not to my liking, but hey-ho thats what makes bikes so interesting
Heres my old XL500R...... great little bikes
Took me to Le Mans a couple of years back..... ENJOY
Pigford is offline   Reply With Quote
Old 03-19-2013, 08:36 AM   #15
woahblackbetty OP
Oddometer: 20
Yeah, I've already rotated the tubes back around the right way and swapped them left to right. That puts the axle back in front and moves the drum mounting lug outboard & clear of any interference.
Have to fab my wheel spacers so I can finish up the bracket design for the front caliper. I have the option of a radial mount or standard mount. Unsure yet which way I'll go...
Obviously this isn't where I'll mount it if I go standard, I'll sling it behind the fork leg.
This is going to be one configuration for the XR. I'm working on securing a 21" front wheel with disc brake setup so I can run that with the stock 18" rear when I want to hit the trails hard. None of my modifications involve cutting the frame. I'm welding a couple of brackets at the back for the rear caliper stabilizer but I can swap back to the stock setup without a problem.
That's one sweet looking bike!
Times are GMT -7.   It's 04:09 AM.
