Old 03-07-2013, 01:33 AM   #1
chileperro OP
Chileperro
Oddometer: 19
2007 6500GS dakar battery ground - where is it?
Where is the battery ground connection (off the negative battery terminal) that connects to a frame or engine lug to complete the ground circuit.*Any ideas? photos?
I'm not talking about that bolt you jump start it from, but where the wiring harness connects to the engine block.
It has to be somewhere, right?
chileperro is offline   Reply With Quote
Old 03-07-2013, 04:06 PM   #2
divimon2000
divimon2000's Avatar
Oddometer: 629
Under the plastic cover for connectors on the right side of the engine. Right above the housing for the stator.
divimon2000 is offline   Reply With Quote
Old 03-07-2013, 10:09 PM   #3
chileperro OP
Chileperro
Oddometer: 19
thanks alot, i'm aboit to start the process of repolcing a burnt out wiring harness. I read your thread on the rotax rebuild. great job.
Do you have any tips for me?
Old 03-08-2013, 03:09 AM   #4
divimon2000
Oddometer: 629
It's easy, I've done it. Lots of pics. There is a good image of how it goes in the service manual. The beefiest part is at the shock adjuster, so start replacing it back there first then work forward. Look how it goes around the engine frame there - the thick branches - one goes up, one goes down. Just go slow, remember it only goes in one way, so almost impossible to screw up. Keep this post updated and I can help you. This is what mine looked like- yuck.
Oh, make sure you have the correct one going back in. Ie abs, year.
Times are GMT -7.   It's 05:34 PM.
