Old 03-14-2013, 03:58 PM   #16
MANXMAN
Overlander
MANXMAN's Avatar
Oddometer: 1,550
Originally Posted by Disco Dean View Post
I made my socket today and will be doing the switch over on the weekend.
Maybe I can beat manxman to it!!!
Installed the ball joint today and will reassemble the forks and fender on Saturday.
Disco Dean, you will beat me to the finish line though because my wheel will not be here in time to complete the installation by this weekend.
MANXMAN is offline   Reply With Quote
Old 03-14-2013, 07:09 PM   #17
Quirky
Quirky's Avatar
Oddometer: 581
Good ta see a few of ya's getting stuck into it.
Just a tip for avoiding potential disaster - make sure and keep abs sensor wire away from the pinch point (just in front of the ball joint pivot area.)
BMW R1200GS, Yamaha WR250R
SPOT link
Quirky is offline   Reply With Quote
Old 03-15-2013, 06:03 AM   #18
Disco Dean OP
Disco Dean's Avatar
Oddometer: 1,282
Looks like it will be a horse race!!! My wheels won't be in for a little while also. I have ordered them but had to do a few payments to alleviate pressure on the CCard... But, all good. I will have it up and running this weekend with the old wheels though so will post pics.
Did you use heat to get the nut off? I am thinking of torching it a bit to get it loose as I know the BMW oem ball joint is sealed in.
Funny thing is the rep rom says to put some moly on it???
What did you do Manxman?
D
youmoveyou
As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?
Disco Dean is offline   Reply With Quote
Old 03-15-2013, 10:38 AM   #19
MANXMAN
Overlander
MANXMAN's Avatar
Oddometer: 1,550
D
No torch, use a heat gun to the underside of the ball joint. It didn't take more than a few minutes and it was easy to break it loose. Real sticky unscrewing it because of the factory thread locker.
Once removed, wire brush the threads of the ball joint real clean and apply red thread locker then install into the new Ralle Moto clamp.
Do not use a 12 point socket! 6 point only. There is not enough nut to grab with the 12 point with that kind of torque.
Old 03-15-2013, 11:47 AM   #20
Disco Dean OP
Disco Dean's Avatar
Oddometer: 1,282
Got it... good thing I got the 6 point!
I turned it down flat at the bottom of the socket and chamfered the end so it would fit as tight as possible. Still a lot of play with such a big socket to my mind but I guess they think it will be applied to monster nuts!!
youmoveyou
Old 03-16-2013, 07:57 AM   #21
Disco Dean OP
Disco Dean's Avatar
Oddometer: 1,282
No pun intended. ;)
youmoveyou
Old 03-16-2013, 07:09 PM   #22
Disco Dean OP
Disco Dean's Avatar
Oddometer: 1,282
Did it today first heat and it came right off.
The the forks in. Careful to line them up. Put the axle in loose then adjust. Then tighten and make sure the axle spins freely.
Then put the baby on!!!
Dab of red paint for safety.
Then bleed the brakes.
Tomorrow I wire an aux plug up front. Then wheels. Woodys will be coming this week. I'll post tomorrow the fender and clearance for the 21incher. Wish we didn't have much snow but no bother I'm riding tomorrow!!!
youmoveyou
Old 03-17-2013, 11:26 AM   #23
Disco Dean OP
Disco Dean's Avatar
Oddometer: 1,282
Done. All good. But check the fender screws. The oem ones I had are smaller than the Rallymoto's. All cool unless you have to search for some short M6's on Sunday!!! Had to dig a trench through the snow to get out but made it and now for a wonderful early spring sunny day ride. Next week I slide the wheels on.
youmoveyou
Old 03-17-2013, 01:36 PM   #24
MANXMAN
Overlander
MANXMAN's Avatar
Oddometer: 1,550
Was surprised to find that too. I had plenty of bolts the right size, but seeing as clearance is the whole point of the replacement clamp, I will try to find some with very thin screw type heads to retain the maximum clearance.
I wonder if Quirky's bike which was used for the development of the clamp has larger fender screws than ours does. I think his bike is newer.
Old 03-17-2013, 02:47 PM   #25
Disco Dean OP
Disco Dean's Avatar
Oddometer: 1,282
I checked the fiche and the 2010 has the M5 like ours - so they must have put in the M6... I don't mind either as I think those are the only M5's on the bike. And, M6 is alright - but I too will have to find some nice low profile bolts.
Dean
youmoveyou
Old 03-17-2013, 03:24 PM   #26
Quirky
Quirky's Avatar
Oddometer: 581
I now have had my memory jolted and do remember Mark telling me they went up a size on them 4 bolts. Why? nope, I don't remember.
Think he likes the beefier bolts.
Could also have something to do with a few less tool changes on the mill and or longevity of the tools.
Cheers,
Quirky
SPOT link
Old 03-17-2013, 10:31 PM   #27
mark0ne
Ralle-Moto Adventure
Oddometer: 112
Bolt Size
Hi guys, Im really sorry about the no bolts in the package..... It was my bad I simply forgot to put them in with the first 4 clamps that went out
We made the bolts bigger because they are simply stronger and the M6 screws are what almost every bike uses for the front mudguard.
We us a M6 x 20mm button head cap screw stainless steel.
Cheers
Vaughan
The man who dies with the most toys wins
mark0ne is offline   Reply With Quote
Old 03-18-2013, 06:02 AM   #28
Disco Dean OP
Disco Dean's Avatar
Oddometer: 1,282
Cheers
Vaughan
I think that these bolts are such a big issue for me that you should give me a integrated steering dampener to make me feel better for it!!!
...seriously all good. The little oem "turd" like bolts that came off - stripped the head of one anyway as the Torx was so small... so having to get new ones regardless. Good choice on the bolts. Just hard to find them at the hardware store on Sunday.
youmoveyou
Old 03-19-2013, 03:24 AM   #29
mark0ne
Oddometer: 112
No probs mate here you go a free steering damper!! Just see the bottom to read terms and conditions!
Photo only damper not included!!!
But at least it can give you something to work towards
Cheers mate hope you find those bolts if not let me know and I can organise something for you?
Old 03-19-2013, 04:26 AM   #30
Disco Dean OP
Disco Dean's Avatar
Oddometer: 1,282
youmoveyou
Times are GMT -7.   It's 02:17 AM.
