Old 03-07-2013, 05:49 PM   #1
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 1,022
Rear ride sag.
I just got my rear shock re built. It lost its oil. While off I got another spring fitted. The stock was too stiff for me.
I would have liked to send it to Superplush but being in the land down under.......
It`s come back and I now have same sag figures as before ! The spring used ( Eiback )1000.250.0750 These figures relate to free spring length, inside diam and Lbs/in rate. It is 5mm shorter, Cant get same length apparently ?
Thing is it dosnt feel any less supple. The old used to be fairly harsh. 2 up last night it felt ok. I am 75kg wife is 60kg. He also used the same valving. Can anyone with rebuilding experience tell me if I have just wasted $$
I have figures of fully extended 650
bike only 640
rider sag 590
So a riders sag of 60 mm. I dont have a manual, so is this in range?
Cheers.
rossguzzi is online now   Reply With Quote
Old 03-07-2013, 07:32 PM   #2
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,388
Maybe a stupid question but,,, did you try reducing the compression settings?
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 03-07-2013, 07:51 PM   #3
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 1,022
Yes I have backed off com and reb to almost none. Also no pre load.
Of coarse I havn`t ridden another one set up well, so its a bit hard to tell how mine really compares to a well set up one.
Old 03-08-2013, 09:07 AM   #4
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,388
Sounds to me you have the wrong spring and/or the valveing is incorrect for your weight. Valveing changes won't change sag measurements.
IMO, you didn't like the way it felt before but had it rebuilt the same way so really nothing has changed. You should have experessed your concerns with the rebuilder and they could have changed the valveing and recommended a spring.
Some good basic tuning...
http://www.ktm950.info/how/Suspensio...l/siddall.html
http://www.enduroeng.com/storage/pdf...c23-LOWRES.pdf
Manuals here...
http://www.ktm950.info/how/owners_ma...s_manuals.html
Boatman screwed with this post 03-08-2013 at 09:22 AM
Times are GMT -7.   It's 11:16 AM.
