Old 03-20-2013, 09:24 PM   #16
rdwalker
Oddometer: 2,538
Originally Posted by DLvid View Post
Thanks, guys. I will perform the checks mentioned and get back to you.
The first thing I did was to replace the fuel pump. Nothing like spending $500 to cover a $15 dollar relay... ...
This deed is done, but before you spend any more money on your bike parts, check for the available alternates to OEM. You'd be surprised how much you can save.
A great source is Beemer Boneyard - not only used parts, but also many new ones. Here is the link. They do carry fuel pumps etc. for most models.
Here is an example: oilhead Valeo starter motor is $200, Hall sensor $230.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker is offline   Reply With Quote
Old 03-04-2014, 07:19 PM   #17
DLvid OP
Oddometer: 37
Hi all. Wow, it's been a while but the problem has been found. There is a diode related to the Motronic and most of the relays that was failing. My hat is off to Mike at Moto Marin for having the courage to tear apart the fuse box, find the diode, test it and confirm that when warm it was allowing voltage to flow in two directions (not what a diode does). Since this find and repair all is well.
No good deed goes unpunished.
DLvid is offline   Reply With Quote
Times are GMT -7.   It's 01:35 PM.
