Old 03-08-2013, 06:56 PM   #1
vector_dumb OP
Happier Here
vector_dumb's Avatar
Oddometer: 316
Sleeping Bag Systems?
I was wondering if anybody had some advice on sleeping bag systems that would work for a broad range of temperatures. I'd like to get some gear that could work between a solid 30 degrees and 70 degrees.
I'm OK with solid but no frills gear and I'm hoping to keep things on the lighter side ~3 lbs since I'll use it for backpacking. Despite how marvelous a $500 dollar sleeping bag may be, I'll never spend that much. I'm a player between 150 and 200.
I was looking at something like a Wiggys ultra light w/ a silk liner or a lower cost 30 deg. down bag (http://www.campmor.com/outdoor/gear/Product___37418) w/ a liner.
I've done a bit of camping, but it was with older coleman bags. You'd freeze at the low temps, be comfortable in the mid temps, and roast in the warmer weather. I'm hoping that a bag and liner would be a good layering system that could cover the full range of temps. If others know otherwise ...
Feedback would be greatly appreciated. Might as well scoop up some winter closeouts.
FYI I'm 6'2" and 165 lbs, so it I'm usually on the colder side at low temps.
Mac, you have an exceptional number of bugs in your teeth. You're gonna wanna rinse those out. It's disgusting. (Always Sunny)
vector_dumb is online now   Reply With Quote
Old 03-08-2013, 07:03 PM   #2
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,648
Get two bags, one rated for about 50 degrees and one rated for around 30. When it's warm, you use the light one. When it is colder, the heavier one. When it's really cold, you use both. Despite the claims, liners don't add all that much warmth. Some claim as much as 20 degrees, which is not the case.
Mummy bags are warmer than rectangular bags. All bags are rated for survival temps, not comfort. A 20 degree bag will keep you alive at that temp, but you'll be miserable.
Wearing a fleece or wool hat when you sleep keeps you significantly warmer in cold temps and takes little space.
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman is online now   Reply With Quote
Old 03-08-2013, 07:04 PM   #3
Cannonshot
Having a Nice Time
Cannonshot's Avatar
Oddometer: 20,404
http://www.amazon.com/Military-Modul...xp_grid_pt_0_0
Cannonshot.net
Cannonshot is offline   Reply With Quote
Old 03-09-2013, 01:41 AM   #4
squish
Out of the office.
Oddometer: 6,319
My system...
Silk liner
Fleece liner
10degree down dri loft bag
This combo has worked from a night time high of 75 to a night time low of about 20.
I sleep COLD.
When it's hot I use just the fleece, when it's normal it's the silk and the bag and when it's cold it's the fleece and the bag.
The bag is a ten year old rei brand bag.
I've been totally happy with the down bag.
On vacation for a spell
squish is offline   Reply With Quote
Old 03-09-2013, 05:38 AM   #5
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 5,442
Originally Posted by Cannonshot View Post
i thought about this myself but at 12lbs i'll find something else....
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 03-09-2013, 06:02 AM   #6
vector_dumb OP
Happier Here
Oddometer: 316
I certainly like the idea of the MSS, but it's a bit of a pig for backpacking.
I have a cabin in the adirondacks and when I was in my teens my dad and I did the 46 peaks. Dad wasn't a fan of camping, so we did them all as day hikes ... which was pretty grueling for some of the more remote peaks. Anyways in the adirondacks (just like any mountains) the temps can vary quite a bit. We almost got hypothermia on a hike in late June when a front moved through (luckily both wearing synthetics). Anyways to cut to the chase: for spring to mid fall camping up that way I want to carry only one bag, and sometimes you'll see a fair range of temps over a week. Unfortunately I think the MSS is out even though it has a lot of pros.
For those interested in the MSS I found the component weight break down:
http://www.tennierindustries.com/RFI...ent%20info.pdf
While a bit more than what I was planning to spend I might be better served by a 20 deg. Kifaru slick bag.
http://www.kifaru.net/slickbag.html#
I'd probably be comfortable in a 20 deg. bag down to 32 deg. If things get really cold, something didn't go to plan and I'll put on everything I got and hop in the bag. In warmer weather I could just bring a light fleece blanket and leave the bag open.
I only wonder at what temp you begin to roast in a bag like this?
Thanks for the suggestions. I think Squish has a pretty good system that shouldn't weigh much. I might end up going that way.
Old 03-09-2013, 06:53 AM   #7
Grinnin
Forever N00b
Oddometer: 2,871
Depends on the zipper length. (?)
I have a Kelty down 20 and it's comfortable for cold and up into the 40s. The zipper, however stops just above mid-thigh. When it's at all warm my legs are trapped together in a slim down bag. Not good at all. There's a vent at the bottom of the foot, but it's not enough. This would be usable if the foot zipper was removed and that length added to the side zip. As it is, the bag is too focused on a narrow temperature range.
For me Kelty fails. My previous 3 sleeping bags all opened up usefully.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Old 03-09-2013, 07:40 AM   #8
riceaterslc
Urinal Cake Engineer
Oddometer: 130
i would not recommend this item. i've been using it for the past 8 years (issued, not by choice) and while it is exceptional compared to most other military gear, it is not suitable for backpacking.
PROS:
1) with all three layers, you'll be comfortable to about 10F
2) if you don't plan on carrying a tent the gore-tex bivy will keep a majority of your body dry
CONS:
1) heavy
2) packs down HUGE (i only carry the bivy and light bag in my assualt pack and it comply compresses to roughly 15"x18"
3) bivy alone, outside, will allow water to sneak in by your face.
2) heavy and packs HUGE :)
the other posts recommending 2 bags are probably your best bet. i've been using a 20F north face bag (blue kazoo i think) for the past 20 years. it works great in anything above 10F (with hat and fleece like the other guys recommend) and packs down to about 7"x14"
09 Street Triple R
12 Tiger 800XC
12 350 EXC-F
riceaterslc is offline   Reply With Quote
Old 03-09-2013, 08:45 AM   #9
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,973
Go to Amazon and look at the Big Agnes bags. I bought a 15-degree down bag, one model year old, for about 65% of what the current models were going for. I'm a big guy (6'2"-270 lbs.) and the larger bag packs down to about 10"X12", and weighs just over 3.5 lbs.
Here's link to a bag I found on Amazon:
http://www.amazon.com/Big-Agnes-Enca...ords=big+agnes
It packs down relatively small, weighs about the same as mine, and is also rated to 15 degrees. Good price, too!
Big Agnes bags need pads to slip into a sleeve on the bottom side, as there's no insulation. I use an Exped SynMat 7, but have used Big Agnes' own brand before. As far as sleep quality goes, both mats give me outstanding comfort through a wide range of temperatures. The only differences are with inflation methods: the BA pad needed lung power, and the Exped has a cool hand pump system built in. I didn't mind blowing up a pad, but it got kind of tiresome when doing it day after day at 8K feet.
Hope this helps.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 03-09-2013, 09:41 AM   #10
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,648
Down has a lot to recommend it. I've had a Sierra Designs down bag that I bought back in the 80s that's still going strong. There have been some recent advances in treatments for down that make it much more waterproof. Quality down is still the warmest, lightest and most compact.
That being said, I don't see the need to purchase a down bag for summer touring in warm weather. There have been some large advances in synthetic insulation. My lightweight summer bag is synthetic, and packs down to about the size of a loaf of bread. Even when wet, synthetic insulation offers some warmth. Wet down is worthless.
Synthetic insulation is also more tolerant of rough handling. You can ruin a down bag by leaving it stuffed while damp. The same treatment isn't good for man-made materials, but takes a lot longer to trash the bag. Synthetic insulation is also vastly cheaper than quality down.
My system consists of a Marmot "spirafil" bag rated at 40 degrees. The rating is highly optimistic. For colder weather, I'll take a Mountain Hardwear synthetic bag which is rated at 32 degrees, and is adequate at those temps. For cold, rainy conditions, I'll take both. For cold, dry conditions, I take the lighter bag and my 20 degree down bag.
An advantage of a split system like this is that it's easier to pack than a single bulky bag. With compression stuff-sacks,
each bag makes a compact package which is much easier to stow than a single large one.
The other part of the system is a good sleeping pad. You'll be much more comfortable on an inflatable, insulated pad. Throwing a "space blanket" under your pad in cold conditions helps also.
You don't have to break the bank. However, there is a big difference in the comfort and quality of bags available at Wal-Mart and a good outdoor outfitter. If you shop around, you can assemble a high-quality system for about $250. Getting a good night's rest cannot be overemphasized. Particularly on a long trip, exhaustion is cumulative, and leads to errors in judgement and accidents.
The Rock 2013 RR
Old 03-09-2013, 10:44 AM   #11
UtahFox
UtahFox's Avatar
Oddometer: 446
I'm a big fan of Marmot bags. I hate being cold too so I use a Marmot Never Winter, click for a screaming deal on one. 2 & 1/2 pounds, packs really small. If it's hot out, then I use it as a blanket. If it's really cold, then I just put more clothes on.
Pair that with a Thermarest NeoAir, and you've got a super lightweight sleep setup that'll keep you warm in just about any temp as long as it's dry. I have a bunch of sleeping pads for various uses and the NeoAir 'seems' fragile (they claim it is durable - I bring a repair kit always), but it's super warm and comfy.
For potential rain, I always carry a Tarptent. Much bigger than a bivy (had 4 people on one in a surprise rain storm in the GC), but about the same weight - mine weighs 2 pounds.
Going this route is more expensive, but you'll have the bag the rest of your life. I've used my Tarpent for almost 20 years, and I've had the pad for a few. This setup is about as light as you can get without sacrificing comfort. Camp touring on a bike and backpacking go really well together, save some weight on your kit you can bring more beer!
UtahFox is offline   Reply With Quote
Old 03-09-2013, 12:02 PM   #12
squawk77
Dreamer
squawk77's Avatar
Oddometer: 561
If the ground is cold, getting off the ground with a pad or cot will keep you much warmer.
I use a mummy down bag. I have 2 but I only use both to sleep in Canadian winters. I have a thin fleece liner as well for comfort
A hat is a must imo! You lose a lot of heat through your head otherwise.
A gortex bivy keeps you dry and also makes another layer of air (it adds warmth even though there's no insulation) The bivy also keeps the down dry when riding
I stuff the valise with clothes to make a pillow and keep tomorrow's clothes in the bag with me.
ADVriders on Kiva | Balkans | Morocco | Alps | Corsica
squawk77 is offline   Reply With Quote
Old 03-09-2013, 02:53 PM   #13
johninlv
Oddometer: 39
Light sleeping Systems
14 years ago my wife and I geared up for ultra light back packing. Our guild was the Back packing light web sight.
http://www.backpackinglight.com/cgi-bin/backpackinglight/index.html
We purchased Bozeman Mountain works Arc X down Quilts that weighed in at 16 oz each and had a comfort range of 32 to 60 degrees.
http://www.backpackinglight.com/cgi-bin/backpackinglight/00059.html
We later sent them back to Nunatak to have them over stuffed by 2 oz each, making them weigh 18 oz.
Down quilts work as a system. You need a good insolated mattress and a layered clothing system to wear in the quilt when it really gets cold.
I like the Big Agnes Insolated Air Core sleeping pads, they are light, pack small and are comfortable.
https://www.bigagnes.com/Products/Detail/Pad/InsulatedAirCore
The Nunatak Arc Alpinist is the top of the line.
http://www.nunatakusa.com/site07/arc_products/arc_alpinist.htm
Jacks-R-Better sells an line of quality down quilts for less money.
http://www.jacksrbetter.com/quilts/
Once I started using the quilt system I never looked back. I have one of each the 18 oz Arc X and a Jacks-R-Better 29 oz winter only quilt.
These items come up for sale on EBay and back packer classifieds from time to time.
You can research the ultra light forums for gear reports that will give you a good idea of what will work for you and at what cost.
2004 Yamaha xt225, 2008 Wr250R Works in Progress
johninlv screwed with this post 03-10-2013 at 07:29 AM
johninlv is offline   Reply With Quote
Old 03-09-2013, 03:08 PM   #14
Cerberus83
The Wingman
Oddometer: 143
Not sure if this is something you're looking for, but I picked up Mountain Hardwear Lamina 35 for $80 (link). There are other bags on this site that are priced pretty well. I'm planning to get Sea to Summit liners (coolmax and reactor), but those two are approx. $110...
Cerberus83 is offline   Reply With Quote
Old 03-09-2013, 03:58 PM   #15
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,648
I recently picked up a Mountain Hardwear long bag also for about the same price. Not the Lamina -- I'd have to check the model. I got it with one of Sierra Trading Post's additional 35% off deals. Nice bag. Well constructed. Roomy for a mummy. I've done a few tests with it, and it's very warm. It doesn't pack very compactly in the stuff sack provided, but I have some compression stuff sacks in inventory. It came with a very nice mesh storage bag. I'm 6'2" and 250, and there's plenty of room. I like it a lot. Mountain Hardwear is making some good gear for reasonable cost.
The Rock 2013 RR
Times are GMT -7.   It's 06:07 PM.
