Old 03-09-2013, 10:04 AM   #1
Rock Junkee OP
Rock Junkee's Avatar
Oddometer: 218
has any one installed the grey water pump seal
Has any one had any trouble putting the new GREY teflon seal on the water pump shaft??? did you need any special tools? i searched here and the o.c halls of wisdom, i can not not find what to do.
the newer seal way to stiff and can not slip over the shaft even wtih grease and tape. thank you
KTM 08 990 Adventure
KTM 01 520 SX
KTM 2013 300 XC-W-SXS top end mod
Wife rides KTM 05 200 XC-W
2008 Honda Xr 650L
Rock Junkee is offline   Reply With Quote
Old 03-09-2013, 10:26 AM   #2
Rock Junkee OP
Oddometer: 218
ah ha found this one http://www.ktm950.info/how/Orange%20..._overhaul.html
looks like i need to make a tool or try to find one of those.
KTM 01 520 SX
2008 Honda Xr 650L
Old 03-09-2013, 12:01 PM   #3
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 736
I just did it this week, no issues, i used the tape trick and it popped right on. I used wheel bearing grease on it..
Dave
pdxmotorhead is offline   Reply With Quote
Old 03-09-2013, 07:06 PM   #4
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Originally Posted by pdxmotorhead View Post
I just did it this week... I used wheel bearing grease on it
you don't want to use grease or oils- you're contaminating your seal
Coolant is the proper lubricant for water pump seals, and it does make it slippery!
The factory shaft/seal tool makes this job SO much easier, and without the fear of catching an edge. It also packs right in with your new spare seal & shaft in the tool kit you carry on trips
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 03-09-2013, 09:38 PM   #5
Katoom72
Katoom72's Avatar
Oddometer: 864
Heat-shrink tubing does the trick.
Lube the shaft with silicone grease, put heat-shrink tube over it, all the way to the bottom. (there is a size that just fits the diameter perfectly, il measure it tmmo if needed). Leave about 5 cm over the top of the shaft. Shrink it with heat so it forms around the shaft nicely. the surface of the heatshrink wil be smooth as to a bit rough when not shrinked. Put silicone grease over the shrinked tube. Put silicone grease on the seal and slide the sucker over the shaft. I pounded it in gently with a socket and some protection. Then just pull the heat-shrink out. Et voila! No busted up o-ring.
As for the 'no grease on o-rings warning', silicone grease is safe for rubber!
Silicone grease is commonly used for lubricating and preserving rubber parts, such as O-rings. Additionally, silicone grease does not swell or soften the rubber
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 screwed with this post 03-09-2013 at 09:44 PM
Katoom72 is offline   Reply With Quote
Old 03-10-2013, 12:24 AM   #6
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
a single layer of vinyl tape and silicone grease has worked for me for many installations of the grey seals.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-10-2013, 01:11 AM   #7
pdxmotorhead
Oddometer: 736
Since its a PTFE seal,, I didn't figure it would matter.. I could see it if it was a standard rubber seal. Guess we shall find out..
Dave
Old 03-10-2013, 04:24 AM   #8
Peanuts
Peanuts's Avatar
Oddometer: 1,607
I have always used grease on waterpump seals. Must have done 100 KTM waterpump rebuilds and no premature failures.
Peanuts is offline   Reply With Quote
Old 03-10-2013, 06:17 AM   #9
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,243
+1 No issues.
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster is offline   Reply With Quote
Old 03-10-2013, 08:41 AM   #10
geometrician
let's keep going...
Oddometer: 1,026
Thumb Cool Beans!
I'm referring to all the factory manuals I've seen over the years when dealing with water pump seals & o-rings
It's not the seal I'm worried about per se, it's the introduction of (petroleum) grease/oils to the cooling system & seal lips.
Better safe than sorry, I'm glad to hear silicone grease does the trick w/o problems
After doing half a dozen pump rebuilds w/sockets & tape, switching to the two KTM tools makes the job SO easy, and at dealer cost/+10% it was easy to add them to the collection. I take them for granted now!
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
Old 03-10-2013, 09:52 AM   #11
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,464
Not a single joke about "grey water" ? There's something not right about this place.
Any bike can be taken off road. The question is; How much fun did you have doing it?
04 950 GO!!!!! 2011 250 XC 89 Transalp 69 350 CL 04 225 XT
08 450 XC-F SOLD to a good home
YOGOI is offline   Reply With Quote
Old 03-10-2013, 10:57 AM   #12
nomad guy
A legal alien
nomad guy's Avatar
Oddometer: 824
I was also wandering who puts a plumbing question in the Orange Crush...
Cheers
Guy
04 KTM ADV 950S GO!!!!!
09 KTM 690 ENDURO R
nomad guy is offline   Reply With Quote
Times are GMT -7.   It's 01:08 AM.
