Old 03-09-2013, 10:22 AM   #1
ZAPLAJE OP
ZAPLAJE's Avatar
Oddometer: 282
KTM 950 ADV without spark
Hello.
I bought a toasted KTM 950 and change the engine for a newer one. Now I have all toghether and there's no spark on the sparkplugs, I checked the side stand switch, the ignition coils, neutral swich and all works well. The sparkplugs are new.
any ideas or suggestions? thanks very much
Going UP!!! don't wait for me
ZAPLAJE is offline   Reply With Quote
Old 03-09-2013, 10:31 AM   #2
Dustodust
Dustodust's Avatar
Oddometer: 952
risk of asking pretentious question but are you sure the handlebar kill switch is ON ?
are you grounding the spark plug well ?
key switches are also a common problem
good ground from engine to battery
You say toasted, although not common on the 950, extreme overheating destroys the ignition section of stator coil and possibly pick up coil (hall effect sensor transistor)
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Dustodust screwed with this post 03-09-2013 at 10:38 AM
Old 03-09-2013, 11:42 AM   #3
ZAPLAJE OP
ZAPLAJE's Avatar
Oddometer: 282
The kill switch is on, the engine turns but doesn't start.
All the key switches were tested.
Engine ground is directly to the battery for now.
The previous engine was toasted, this is a suppously running engine.
All looks good but no sparks on the sparkplugs. We (a mechanic friend and I) will check the pulse generator now, is our last option
Old 03-09-2013, 03:28 PM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,997
I had a similar problem.
The 990 sidestand sensor is different from the 950 one. I had to use my 950 s/s sensor to be compatible with the 950 wire loom. Did you keep your carbs?
Old 03-09-2013, 04:00 PM   #5
ZAPLAJE OP
ZAPLAJE's Avatar
Oddometer: 282
yep, carbs keeped... the "new" engine is a 950 too
Times are GMT -7.   It's 09:23 PM.
