Old 03-09-2013, 03:00 PM   #1
Alleycatdad OP
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Valve check help...
Ok, so I successfully checked the rear cylinder clearances without issue; however, when I attempted to move the front cylinder to TDC, the crank bolt loosened. So....how tight does it need to be?
...and, how does one go about tightening it? How do you hold the crank to get it tight? This may be complicated by the fact that I have a rekluse....can't use the engine locking bolt because it's not at TDC....
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad screwed with this post 03-09-2013 at 04:09 PM
Alleycatdad is offline   Reply With Quote
Old 03-09-2013, 03:36 PM   #2
Katoom72
Katoom72's Avatar
Oddometer: 893
Put the sparkplugs in, turn the crank clockwise until the compression kicks in and hit the wrench with your palm a few times. Take the sparkplugs back out and you should be able to turn the crank over counterclockwise. If the bolt losens just rinse and repeat.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 03-09-2013, 03:48 PM   #3
baloneyskin daddy
bikaholic
Oddometer: 2,158
Pull the plugs an put the bike in top gear and rotate the engine with the back wheel. If you have a cenyer stand.
baloneyskin daddy is online now   Reply With Quote
Old 03-09-2013, 03:53 PM   #4
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 2,955
That crank bolt should not back out just by backing up the engine to check the valves. It's got a lot of torque on it and green Loctite. Did you do something odd like leaving in the engine block bolt in place while you tried to back up the engine to go to the second cylinder??? In my mind, if you've done something to cause that bolt to back out, you should get it torqued back in place to the right specs and using green Loctite.
Orangecicle is offline   Reply With Quote
Old 03-09-2013, 04:07 PM   #5
Alleycatdad OP
Oddometer: 1,439
There's sme great help there, thanks.
I did nothing unusual to back the bolt out; even had the spark plugs out, and the engine locking bolt is out as well.
This is, however, the first time I've been in this specific engine but it has had one highly suspect dealer service.
Couldn;t find the torque spec cause I don't know what KTM calls that bolt; so that's really a big help.
Steve
Old 03-09-2013, 04:09 PM   #6
Alleycatdad OP
Oddometer: 1,439
This is basically what I did. I was worried about turning it backwards, tho. Thanks!
S
Old 03-09-2013, 11:46 PM   #7
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,581
This may be a obvious statement, but here it goes: the bolt that holds the flywheel on SHOULD NOT come loose from turning the engine CCW without the plugs installed..... honestly its a VERY good thing that you caught it before it came loose while the engine was running.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-10-2013, 05:56 AM   #8
Orangecicle
On a "Quest"
Oddometer: 2,955
Yep. I'll add to that and suggest that you take off the generator cover and tighten that bolt properly using the proper Loctite. It costs you a few hours of time, some odd Loctite, and one gasket. If that bolt comes off during operation, the flywheel can damage the stator, and that can make one heck of a mess, and stators are sometimes hard to find:
http://www.advrider.com/forums/showthread.php?t=339036
My guess is that the dealer accidentally left the engine block bolt in and tried to back up the engine during the first valve check, resulting in the condition you have now. That flywheel bolt should just never come out under any kind of normal use/repair conditions.
Old 03-10-2013, 07:34 AM   #9
Peanuts
Peanuts's Avatar
Oddometer: 1,664
You really believe the dealer did a valve check ;)
Peanuts is offline   Reply With Quote
Old 03-10-2013, 08:38 AM   #10
Alleycatdad OP
Oddometer: 1,439
I'm kinda torn on this, actually...given the fact that pretty much everything the dealer touched during the service was done incorrectly, left incomplete, or misassembled, I had assumed that the valves were never checked, which is why I was in there in the first place yesterday.
However...oil seepage from the valve covers, grossly overtightened valve cover bolts (except for the two that were nearly falling out), loose throttle body boot bolts, and barely finger-tight sparkplugs actually lead me to believe that they did actually get in there. My measurements were pretty close to what they got as well, which is a surprise to say the least...
Anyway, yeah, I've got a gasket on order. Got it secure enough to finish the valve check and put the covers back on, but I'll worry about it until it's right.
This crap is why I do almost all of my own work. There's a rant on the site somewhere about this service experience so I won't repeat it here, but short story is that it was the first service on the bike and I wanted to be sure I was covered if we had a later warranty issue; however, given the level of performance and service I was given I don't think I'd let these idjits fix a warranty issue anyway... I was due for the service, working 24/7, and had a big trip coming up. Shoulda just gone back and gotten the bike when they called me asking if I had spark plugs or an air filter for it...
I remember seeing another thread with this issue a while ago, but couldn't find it with a search, so thanks for all of the help!
Steve
Old 03-10-2013, 08:48 AM   #11
Alleycatdad OP
Oddometer: 1,439
OK, I'm back.
I've seen the threads referencing loctite 648 green for the rotor locking bolt; however, my current service manual specifies 243 for this bolt.
Input?
Steve
Old 03-10-2013, 10:10 AM   #12
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,399
Originally Posted by Alleycatdad View Post
OK, I'm back.
Input?
Steve
The 648 is for the six small bolts that hold the freewheel to the rotor.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 03-10-2013, 10:14 AM   #13
Alleycatdad OP
Oddometer: 1,439
Thanks. I'll catch up eventually...
S
Old 03-10-2013, 02:43 PM   #14
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,581
The major difference between the two is the max operating temp while still retaining the fastener. IMO, using the 648 on the large center bolt is OK. Just need to remember that the bolt will need to be carefully heated to make future removal easier.
Sent from ADVmachines.com via Tapatalk
Old 03-10-2013, 03:39 PM   #15
MortimerSickle
Semi-Adventurer
Oddometer: 12,399
http://wiki.answers.com/Q/The_actual...en_loctite_648
G.H.W.S. 1878-1962
Times are GMT -7.   It's 05:21 PM.
