Old 03-09-2013, 08:14 PM   #1
kymbo OP
kymbo
Oddometer: 380
Question sidecar brake
hi all the chair that iam going 2 install has a 10inch rim ,so thats going 2 be replaced by a13 inch with a four stud patten . has any one fitted a mini disc and caliper set up on there rig ,or something else cheers kymbo
kymbo is offline   Reply With Quote
Old 03-10-2013, 12:18 AM   #2
ErictheBiking
Oddometer: 126
I had a 13 inch wheel on my Goldwing outfit.
It had a drum brake with an electric brake installed.
Braking effect could be adjusted for road and load conditions. No hydraulics or pipes.
Very commom on trailers and caravans.
Worked really well; I'd do it again in a shot.
ErictheBiking is offline   Reply With Quote
Old 03-11-2013, 12:39 AM   #3
sidecarcrazy
grandad in gladstone
sidecarcrazy's Avatar
Oddometer: 181
Side car brake
I have a Nissan 4 stud hub with a 15 inch wheel with a hydraulic disk brake on its own pedal, good for steering around left hand corners and helps with braking as I can brake side car & rear with one foot, am in Gladstone up north of you in SA
PJ
sidecarcrazy is offline   Reply With Quote
Old 03-11-2013, 07:48 AM   #4
jaydmc
Oddometer: 1,057
We make a hub from billet that runs a 4 bolt pattern on 4 inch with a modified Citreon GSA rear brake rotor (about 7 inches) and is set up for a Brembo calipar. It runs on a straight one inch axle. We also make a hub with a 5 bolt pattern on 4.75 and it also has at BMW 5 bolt pattern for use with rear BMW wheels.
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
jay@dmcsidecars.com
jaydmc is offline   Reply With Quote
Old 03-14-2013, 05:00 AM   #5
tripodtiger
I used to be SCRay
tripodtiger's Avatar
Oddometer: 4,718
I really like my separate sidecar brake. NB 'separate'.
I really didn't like it when I had one plumbed in to the rear brake. I had no method of changing the hydraulics, so the sidecar wheel would lock & skip. I disconnected it fairly soon after I got that one. Yes, it was as instructed to Leigh, but it didn't work.
rayb Crash Dummy (no testing involved)
Old 03-14-2013, 05:33 AM   #6
turkey380
turkey380
Oddometer: 53
Brake
G`Day I put a kwaka 90 disc honda xr 250 caliper pit bike rear brake unit.
I have it separate from the bike brakes as said before magic to slow bike down before corners Drag into fast left handers. Max Turkey Beach
turkey380 is offline   Reply With Quote
Times are GMT -7.   It's 12:10 PM.
