Old 03-10-2013, 12:31 PM   #1
superpimp OP
Oddometer: 68
Yes another canisterectomy question!!
Hey guys i have been checking the canisterectomy threads but not really finding what i'm looking for.
I have a super enduro 2007 and want to take off the canister but not the SAS since i'm keeping original exhaust on it.On the KTM.info page they say not to remove the SAS if your keeping your OEM exhaust , because iit will cause internal damage to the CAT.
So a friend of mine showed me how to do it .But i still wondering if it done right.
They say you need to put two screws in the heads on the left side of the bike.
That's done
Then... on the right side two tubes come out and are supposed to be plugged with a screw or a cap.This is where i'm confused.
On my Setup one hose is plugged with a screw and a retainer and the other goes and plugs up to the SAS that big valve behind the airbox.
Is that ok?
Most guys on the net plug both hoses, since the SAS valve is gone, but mine is being kept.
Thanks for the input
superpimp is offline   Reply With Quote
Old 03-11-2013, 08:46 AM   #2
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
The whole purpose of those side tubes is for when you sync the carbs. I would bet that plugging the one hose into the back of the airbox would throw off that cylinder's air/fuel ratio. Grab another screw and fix that tube like the other one, then cap the vent from the back of the airbox.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 03-11-2013, 11:42 AM   #3
KEELAYMONSTER
BRRAAAAPPP!!!
KEELAYMONSTER's Avatar
Oddometer: 174
If you are keeping the SAS, then yes you leave the hose connected to the valve behind the air box and plug the other
Kyle Montagne #141K
KEELAYMONSTER is offline   Reply With Quote
Old 03-11-2013, 01:16 PM   #4
Katoom119
Katoom119's Avatar
Oddometer: 1,837
I may be thinking of a different plug. When I had my SE I used this:
http://www.ktm950.info/how/Orange%20...pc_removal.htm
Old 03-11-2013, 04:11 PM   #5
KEELAYMONSTER
BRRAAAAPPP!!!
Oddometer: 174
Are you keeping your SAS?
If so then leave the line on from the cylinder head to SAS valve behind the airbox. Plug the other line from the other cylinder.
Kyle Montagne #141K
Old 03-12-2013, 06:12 AM   #6
superpimp OP
Oddometer: 68
Where do you guys get the caps?
Yep on the last tutorial the guys removed the EPC and the SAS.
In my case it's only the EPC being removed.
Old 03-12-2013, 04:47 PM   #7
superpimp OP
Oddometer: 68
thanks for the answer! i'm re-assured now that its plugged right.
Times are GMT -7.   It's 05:22 PM.
