Old 06-20-2011, 02:20 PM   #1591
WVdyhrd
mudhole 400 guy
WVdyhrd's Avatar
Oddometer: 2,545
random question. It's probably been answered but I'll try anyway. Any good 400rxc solutions to luggage? Not a lot but enough for a change, some food, and my hammock. Right now I rely on wolfman bags, and Zip ties through the plastic. No rear subframe makes finding a reliable rack option a bit of a pita
KTM 400 RXC & 01 955i Tiger, Cannondale HT Caffeine
"The fool doth think he is wise, but the wise man knows himself to be a fool." -Bill
Shakes
WVdyhrd is offline   Reply With Quote
Old 06-20-2011, 02:59 PM   #1592
WVhillbilly
WVhillbilly's Avatar
Oddometer: 11,128
http://www.giantloopmoto.com/products/coyote-saddlebag
WVhillbilly is offline   Reply With Quote
Old 06-20-2011, 03:45 PM   #1593
G-Funk
That ... Umm ..... "Dude"
G-Funk's Avatar
Oddometer: 5,259
Originally Posted by WVhillbilly View Post
+1 on the giantloopmoto gear ........
G.
03 Caponord
"The Funness out-weighs the Dumbness ....." - Mr. Jetmoto
G-Funk is offline   Reply With Quote
Old 06-21-2011, 11:39 AM   #1594
Cling
Oddometer: 5
Got a chance to check the valves on a 2001 LC4 640 I purchased. Looks like the adjusters were never touched after 28,000k/m, ouch. I ended up having to make some major adjustments due to 0 clearance on all valves, one of the exhaust side adjusters has to be adjusted to its maximum in order to get any clearance at all...
Would this be an issue with the valves and/or seats? I'm a little new to doing my own valves, I would assume that a worn lifter follower bearing and/or camshaft lobe would cause too much clearance instead of a lack of clearance as I am having right now.
Cling is offline   Reply With Quote
Old 06-21-2011, 11:49 AM   #1595
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
No clearance on all the valves? Are you checking them with the engine on the right stroke? Try carefully rolling the engine around one more revolution and see if you get some slack....
gunnerbuck is offline   Reply With Quote
Old 06-21-2011, 12:01 PM   #1596
Cling
Oddometer: 5
I just need it at TDC right? I know it was TDC because i had the head off and I was cleaning all the carbon off of the piston head.
Old 06-21-2011, 12:05 PM   #1597
rxcrider
rxcrider's Avatar
Oddometer: 1,365
There are two TDCs on a 4 stroke
1- just after the spark plug has fired and it is making power with both valve closed - the point when you should be checking valve lash
2- and the end of the exaust stroke / beginning of the intake stroke when both the intake and exhaust valves are partially open.
Choose wisely
'95+'95+'96 BMW R1100RS/RSL
AMA, OMTA (ohio organization), BRC, BMWMOA
rxcrider is offline   Reply With Quote
Old 06-21-2011, 12:19 PM   #1598
Cling
Oddometer: 5
Choose wisely
So you think I might be checking them at the 2nd TDC? Its possible, I didn't even know there were two TDC's lol. I'll review Creepers finding TDC thread and made sure I did it right, i'll get back to you tomorrow
Old 06-21-2011, 03:50 PM   #1599
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,544
If you had the head off you should be able to clearly see the condition of the valves. Here's what brand new ones look like for reference:
The valves usually last much longer than 28K km but if they have been run too tight they can get burned as they won't seat against the head properly to cool down.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 06-22-2011, 10:11 AM   #1600
rxcrider
rxcrider's Avatar
Oddometer: 1,365
Since you had the head off, make sure you timed the cam right when it went back together as well.
Old 06-22-2011, 11:02 AM   #1601
Cling
Oddometer: 5
That was it guys, I was at the wrong TDC, just my luck. Anyways, valves have much more realistic adjustment values now, thanks for the help!
Old 06-22-2011, 11:10 AM   #1602
rxcrider
rxcrider's Avatar
Oddometer: 1,365
Good deal - much better that having done it right and having to pull the head and throw money at it... or assuming that you had done it right and having to pull the head and throw more money at it in ten miles. Three cheers for double checking your work when something doesn't seem quite right
Old 06-22-2011, 03:26 PM   #1603
SikDMAX
Oddometer: 720
OK, me dummy. Could use a little help. Just did the valves on my 01 Duke II and pulled the capacitor and bracket off the right side of the bike. I CANT REMEMBER WHAT BOLT IT WAS OFF OF!!! WTF?
Help me out please....
Matt - SikMoto www.Facebook.com/SikMoto San Luis Obispo, CA
SikDMAX is offline   Reply With Quote
Old 06-22-2011, 03:28 PM   #1604
christian
Exchange your GPS Track!
christian's Avatar
Oddometer: 2,653
on the tank rubber holder
KTM 950 ADV '05.5
KTM 690 '10
christian is online now   Reply With Quote
Old 06-22-2011, 03:30 PM   #1605
SikDMAX
Oddometer: 720
Ah ha! I placed it there but wasnt sure! Behind the rubber or in front? (Closer to center of the bike or outside)
And is the way I have the bracket oriented correct? The cap sits forward of the bolt? Thank you!
Times are GMT -7.   It's 06:34 PM.
