04-04-2006, 05:15 PM
#181 |
ride'n 2 live
Oddometer: 1,710
Hey thanks MEAT
Im killing some time right & going over the index, unbelievable, thanks for your time & patients. I owe ya some COLD ones.
Content, NEVER! |
04-05-2006, 01:59 AM
#182 | |
Bend it Bend it
Oddometer: 5,437
PS baby eventually turns into hulking great bloke. |
04-05-2006, 01:03 PM
#183 | |
Ignostic
Oddometer: 13,839
Thanks for the compliments folks!
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. |
04-06-2006, 09:48 AM
#184 |
Oddometer: 370
I couldn't find a thread listed in the index about the low octane wire for the LC4, did I miss it? Trying to find out if my '04 SXC has such a thing too.
Couldn't find a piccy of the offending wire loop or whatever with searches other than a guy who hacked a newer ignition into an older bike.
2004 KTM 625 SXC 2004 Yamaha FZ-1 1996 KTM 620 RXC |
04-06-2006, 05:34 PM
#185 | |
Ignostic
Oddometer: 13,839
CountPacMan's (hopefully) Definitive CDI Guide - http://www.advrider.com/forums/showp...48&postcount=9 Not sure if the SXC has the switchable CDI; I would expect it if for no other reason than part redundancy makes life simpler for KTM.
04-15-2006, 08:17 AM
#186 | |||
Oddometer: 3
unreasonable vibration in adventure 640 2006
04-15-2006, 08:29 AM
#187 | ||||
surly adventurer
My cats breath smells like cat food
04-15-2006, 08:38 AM
#188 | |
Ignostic
Oddometer: 13,839
There are quite a few questions that La Familia will have to ask you before we can help. Why not start your own thread? Not everyone who can help will find your post here. In fact many who are good with the LC4 probably rarely come in here... So start your own thread with this topic, titled something like "new 2006 KTM 640 Adventure strong vibrations!" And then add some additional information, such as when you bought it, where (who set it up), and have there been any modifications to date. It is possible that the setup shop mistuned the engine, or perhaps it needs some fine tuning and break in, or (very unlikely) there is a problem. But you are correct a new LC4 shouldn't vibrate any more than your old one. In fact, since they put a second counterbalancer on in 2003 it should be smoother in the highway cruising range (my understanding of its function). That help?
04-15-2006, 10:04 AM
#189 |
Oddometer: 1,003
They vibrate less with a couple of thousand miles on them, even less with a freer flowing exhaust and less again after jetting, when new and in standard trim the vibrate like a crack ho with money for batteries.
04-15-2006, 01:09 PM
#190 | ||||
Still alive...
Oddometer: 10,718
Vibration is first of all, subjective. What is a bad vibration to you may be nothing more than "character" to someone else. Also, we have no idea what your physical condition or stature is. You may have arms like a 10 year old girl, and any vibration would be objectionable. ![]() Assuming your bike vibrates abnormally, so much so that anyone would consider it an issue, there are many possible avenues you can take to reduce it. * Take it to the dealer and have someone there experienced with LC4s ride it and offer their opinion. If they say it vibrates too much... then the dealer can deal with it. It's a rare thing, but there may be a problem you cannot fix easily yourself. * Assuming it's "normal" and not an engine that had the counter-balance left out of it , there are many things you can do to reduce the vibration.* LC4 engines, as Buckster indicated, benefit from miles and jetting. Vibrations at 2,000 miles of engine use are roughly half of what they are at 500 miles. * LC4s are jetted a little lean from the factory. You can richen some of the circuits and fine tune the idle speed and mixture to reduce vibration. An LC4 vibrates less with a high hot idle speed... between 1600-1700 is the most common and preferable. * Check all the engine mount fasteners and torque them if necessary to the correct specification. In fact, check all the major fasteners on both the engine and chassis... there is no guarantee that the individuals that assembled the bike, or the one that set it up did it right. A good example of fasteners affecting vibration levels is that if only a few exhaust header/collector bolts are loose... "felt" vibration can increase dramatically in frequency and even amplitude. *Check chain tension, as too tight or too loose a chain can cause a vibration. *Check the torque value on the handlebar riser thru bolts. The bars are rubber mounted and if the bolts are over or under-torqued, excessive vibration can be transmitted. *The stock OEM KTM handgrips suck... they suck universally. Replace them with something more comfortable. These are just a few things to check... but you get the idea. Best of luck m640b, C |
04-16-2006, 11:27 AM
#191 |
Oddometer: 3
2006 adventure 640 engine is different than the 2002 year?
Hi. my new adventure 640 2006 model feel no so strong as the 2002 model.
Is it because thay change the engine, or maybe it because the new euro 3 standard? How I can make the engine stronger? |
04-16-2006, 03:36 PM
#192 | |
Ignostic
Oddometer: 13,839
Once you have gone thru those threads please ask us for clarification. By the way, where are you from?
04-17-2006, 12:49 PM
#194 | |
Ignostic
Oddometer: 13,839
There is plenty of information in the index to get you started on a number of things - including tuning your bike properly (fixing setup problems), if that is indeed the problem. Did you find those threads?
05-20-2006, 12:08 AM
#195 |
Ignostic
Oddometer: 13,839
An update!?!
Yup, I finally threw it together...
Still I am not happy with Part Deux (I think it needs organization on par with Part One), but that is less important than the obvious need of many important recent threads. I hope this helps.
