Old 02-08-2012, 08:53 AM   #2206
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Are you co-opting my avatar?
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 02-08-2012, 09:06 PM   #2207
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,235
Originally Posted by micq View Post
Looking at a SXC 625 , 07 model with 10000 klm's , any pointers on what to look for appreciated .
there's a thread near the top of the index on what to look for in a used bike, LC4 or otherwise. (Page 1 of this thread)
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 02-10-2012, 01:53 PM   #2208
guymanbro
da Vermonster
guymanbro's Avatar
Oddometer: 1,451
Originally Posted by guymanbro View Post
Haven't found any info on racks for a '99 LC4 640e that will work with Ortlieb quick release bags. Anything out there that I'm missing?
Originally Posted by reid4747 View Post
guymanbro, I use the pro moto billet rack with the side pannier guards by the same company for my Ortlieb bags. They work fine though I push the loaded bags as far forward as I can for C/G. Here is a link to some photos of the rack on my 2001. Let me know if you need more help. http://s1076.photobucket.com/albums/w452/reid4747/
Originally Posted by Tall Mike View Post
Happy Trails carries Rack-It billet racks - http://www.happy-trail.com/KTM-LC4-%...argo-Rack.aspx
also these guys - http://www.cyclebuy.com/shopping/promoto/racks_ktm.htm
looks like a nice solution for my ortliebs too! (as long as we're all going bike camping!! )
These setups look good for the standard Ortliebs, but the quick release version that I have require a round tube frame to latch onto (no straps across the seat). Still looking, though I may just have to buy some beer for a welder friend of mine. . .
da Vermonster
http://www.kirstyrock.com
fIRST aMERICAN cHAPTER tEAM nONGA
guymanbro is offline   Reply With Quote
Old 02-10-2012, 05:11 PM   #2209
MNCherryinCA
KTM Noob
Oddometer: 577
Centerstand and side stand
Hey All,
Do the LC4s have a center stand and side stand or do you have to choose between the two? I just got a centerstand for my SXC and I'm going to put it on tomorrow. Am I going to have to remove my sidestand?
Anything tricky about installing the KTM centerstand?
MNCherryinCA is offline   Reply With Quote
Old 02-10-2012, 05:51 PM   #2210
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,466
Originally Posted by MNCherryinCA View Post
Hey All,
I know with the 640 it's an either/or deal...unless you go with a SW-Motech sidestand.
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 02-10-2012, 10:07 PM   #2211
Tall Mike
TAT Rookie (planning!)
Tall Mike's Avatar
Oddometer: 542
And watch out for those spring-loaded SW-Motech sidestands...They WILL get your leg a couple times! (wear the moto boots!)
Ride the Earth! (Pavement Optional)
stable: '05 DL1000,'06 DL650, '99 XR600R, '03 640ADV
Tall Mike is offline   Reply With Quote
Old 02-11-2012, 12:43 AM   #2212
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,148
Yes! They bite!
Low594 is offline   Reply With Quote
Old 02-11-2012, 05:53 AM   #2213
meat popsicle OP
Ignostic
Oddometer: 14,235
Or you use Loadedagain's reverse-polish installation of the KTM side stand - then he says they both work.
Old 02-11-2012, 02:49 PM   #2214
MNCherryinCA
KTM Noob
Oddometer: 577
air in clutch line?
I mysteriously have a clutch with no pressure! Anyone know how air could get in there out of nowhere?
I picked up a magura bleed kit. Hopefully I can pump the air out from the bottom.
Old 02-11-2012, 03:18 PM   #2215
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,252
I don't think so...tomdanger's avatar looks like the russian orthodox saint seraphin:
Originally Posted by tomdanger View Post
thanks kids! i have been under the seat and mask.....i guess i'll do it again
2003 KX250 - plated
2014 WR450F - plated
AtomicGeo Videos
AtomicGeo is offline   Reply With Quote
Old 02-11-2012, 04:16 PM   #2216
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,767
either you are going to need a O ring on the bottom slave or a piston at the top master.. do both and yourself a favor.. also get a new bushing and screw for the handle as it will wear allowing the lever axial movement making the master piston wear out faster.. partnumber for the bottom O ring 0770020210 KTM O-RING 23,52X1,78... on the top piston if your bike has the stock sxc clutch the size it 10.5 and a parts unlimited or WPS dealer can get the piston cheaper but here is the OEM pn 58402032000 .. the nut bolt and bushing for the handle is..50302038000
wrk2surf is offline   Reply With Quote
Old 02-11-2012, 05:43 PM   #2217
MNCherryinCA
KTM Noob
Oddometer: 577
Bluhduh
So I used the kit to pump air from the bottom bleed area out the top with the cover off. Not much air came out, but I was able to fill it up and get it put back together with a pretty solid feeling when I pulled the clutch in. When I went to go for a short ride, I noticed the clutch was still having to be pulled ALL the way in to disengage the gears. After about 3 miles, I lost all pressure and basically had no clutch. Had to limp home by forcing it into gear without the clutch. Now back to square one.
I guess I should have waited to hear what you had to say wrk2...This bike is like golf! i just can't seem to get everything running right all at the same time! At least I'm learning a lot though! I just wanted to be riding the last 2 weekends and not fixing stuff! Hopefully Munn can ship all of these parts out quick!
When you talk about the bushing and screw for the handle...is that what allows the handle to kind of wiggle around?
Thanks for the pointers...
Old 02-11-2012, 06:12 PM   #2218
MNCherryinCA
KTM Noob
Oddometer: 577
Hey wrk2surf...What microfische is the 0770020210 o-ring on? I'm trying to figure out exactly where that o-ring is supposed to go.
Old 02-11-2012, 07:56 PM   #2219
MNCherryinCA
KTM Noob
Oddometer: 577
All parts on order...hopefully they get here quick...I need to get out and ride!!! Now I have to go to church and then sit home all day for another Sunday
Old 02-11-2012, 08:24 PM   #2220
MNCherryinCA
KTM Noob
Oddometer: 577
pressure back in clutch after i lost it earlier
ok...now it really gets wierd...i went out to look at things some more and now there is plenty of pressure in the clutch again! Here's the sequence:
changed the engine oil
clutch lost pressure
bled the clutch from banjo bolt up to top reservoir, made sure top reservoir was filled
put everything together
clutch was working ok, but still required a full pull-in to disengage the gears
rode about 3 miles and lost pressure in the clutch
came home, ordered parts
went in garage about 2 hours later and pressure has returned to the clutch
Times are GMT -7.   It's 01:12 AM.
