04-12-2012, 01:35 PM
#2581 | ||
Joe Cool
Oddometer: 184
I remember when I was assembling my LC4 when I purchased it when it had been used as a spare part box and it came in pieces; it took me around 3-4 hours to figure how all of the cables go to the carb and around the bike. I had never worked on an LC4 before, so, it took quite a while to figure it out. ![]() Also Quote:
Work systematically as well. Don't change too many things at once. Like in this case, did your bike run well without the snorkel before you took the side cover off? When you say that the mid-range was affected, also realize, that the needle position affects the mid-range power. Lortdadu screwed with this post 04-12-2012 at 01:42 PM |
04-12-2012, 03:16 PM
#2582 | |
I.Hopp.
Oddometer: 3,131
640 A x 2 |
04-12-2012, 03:28 PM
#2583 | |
Sticks and Stones™..
![]() My slide/and guide@22K ![]() ![]() New slide/guide ![]() ![]() Needle jet(emulsion tube) @22K ![]() Needle was fine but my drain screw was not.
AMA 487807A |
04-12-2012, 04:32 PM
#2584 |
Oddometer: 87
Took the carb off the bike tonight. It wasn't as difficult as I expected, but I'm quite worried about re-assembly; it's quite a tight fit - or so it seemed to me - and I presume it will take more time than taking it off.
I found the inlet boot from the airbox to the carb was "a bit" cracked : Tomorrow I'll open the carb to take a look inside and see what I find. I don't know if the carb has ever been serviced, so it's well worth taking a thorough look at it. |
04-12-2012, 05:09 PM
#2585 |
Oddometer: 87
04-12-2012, 05:13 PM
#2586 | |
Can't tell for sure from that picture but I'd bet your slide guide is worn.
AMA 487807A enduro0125 screwed with this post 04-12-2012 at 05:19 PM |
04-12-2012, 06:39 PM
#2587 |
Exchange your GPS Track!
Oddometer: 2,600
Make sure you have a filter on the air intake on the top of the carb
Sometime bike with the smog stuff removed have this left open. Bad idea
Yamaha Majesty '08 KTM 690 Enduro '10 |
04-12-2012, 10:18 PM
#2588 | |
I.Hopp.
Oddometer: 3,131
The airbox manifold does look bad and will for sure need to be replaced, in a pinch you can patch it up with a urethane bonding agent such as aquaseal... This stuff is designed to repair waders and wetsuits but works fantastic for motorcycle botch fixes..
640 A x 2 |
04-12-2012, 11:57 PM
#2589 |
Joe Cool
Oddometer: 184
By the looks of the top of your carb, it's about time you clean that thing!
![]() If you have a compressor, you should clean all jets and ports inside the carb with pressured air. That way you can clean the ports effectively. A few friends of mine have used carburetor cleaner sprays/fluids, personally I've never used them. My carb has never been so dirty that I would need to use such. I've used industrial alcohol to clean the carb with linen cloth and a toothbrush. |
04-13-2012, 01:48 AM
#2590 | |
Oddometer: 1,574
![]() Your doing a great job! Was the inline fuel filter present in the steel line of the carb? daryl dlh62c screwed with this post 04-13-2012 at 01:58 AM |
04-13-2012, 11:12 PM
#2591 |
Oddometer: 87
After having children, planting trees and writing books, now I'm complete with the experience of disassembly/reassembly of a carburettor.
![]() With the help of a friend we were able to remove the screws left, one of them with a screwdriver, the other with the impact one. Here's the result : Daryl, it did have the tiny filter in the steel line of the carb. It had about 25% of its surface clogged with tiny small debries. Thanks for making me find it. I was looking for an usual fuel filter, not this type. Idle jet is 45 (stock, I think), main 152.5 and the needle is at the 3rd clip ( counting from top, two more left ). The idle jet was a bit dirty too, probably being the cause of the engine stalling from time to time. I cleaned everything up with air pressure and then with alcohol. I didn't find any remarkable wear in the slide/guide. Lateral play is less than 0.1mm, so nothing to worry about I presume. One thing, probably not very important, was that when removing the floats, the o-ring was sort of "stuck", and when reassembling I thought it would "fit" or make a click to enter a predetermined space. It didn't make that click as I was expecting. Maybe the o-ring was stuck and that caused I had to pull - lightly - the float to remove it. I guess this is just held by the screws of the float cover, if I'm not wrong. I'll wait for the inlet boot airbox/carb for reassembly. Will see if it works fine again. Probably the engine was running lean due to the fuel filter and idle jet being quite dirty. A new plug will tell. Anyhow, I've learned a lot thanks to you and now I can - with a fair bit of spare time ahead - understand the bike a bit more. Cheers for that. |
04-14-2012, 02:24 AM
#2592 | |
Oddometer: 1,574
Your well on your way. The filter is easy to overlook. It does its job well. daryl dlh62c screwed with this post 04-14-2012 at 02:30 AM |
04-14-2012, 09:16 AM
#2593 |
Oddometer: 1,138
Waterpump revival
I'm presently reassembling my 2002 LC4e as it's been in boxes for 3-4 years. I've been riding smokers and RFS bikes over that period. Now the big-boned girl is coming out of mothballs due to the sale of the RFS.
I noticed the o-ring seals on the waterpump are dried out from all that sitting. I'm also unable to find the waterpump rebuild kit I bought 3 years ago for the occasion. To add insult to injury - it looks like the rebuild kits are all sold out for this model. Question - can I pull the o-rings, clean and revitalize, then reinstall? Are these o-rings (large diameter, small thickness) available at an auto parts store? Is it wise to reuse the other original parts, impeller and such, or should I look for a total rebuild before reassembly? Don't really want coolant perking into my oil. ps - wish the LC4 had the RFS system with a weep hole on the side
Well loved but gone - 1982 Maxim 650, 2000 Concours, 2001 KLX300, 2001 DRZ400E, 2004 KLR650, 2006 TE610, 1998 KDX220, 2001 Suzuki Bandit 1200S, and a 2002 KTM 400EXC. Occupying the stable - 2007 Suzuki Bandit 1250, 2002 KTM LC4E, and a 2007 KLX250S. |
04-14-2012, 09:30 AM
#2594 | |
I.Hopp.
Oddometer: 3,131
The Bearings{6001 2rsr c3} used in the pump are a common item and available through a bearing shop... These bearings are also used in electric motors and I was able to buy a 10 pack for under $15 by shopping around...
640 A x 2 |
04-14-2012, 12:00 PM
#2595 |
slave to gravity
wasn't there a Creeper valve check thread? I can't find it....anyone?
Riff Raff 2012, 2011, 2010, 2009 Skibum Soiree 2012 Skibum Soiree 2011skibum soiree '10 RIP ITsteve, ride in peace my friend save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk |
