Old 11-01-2012, 03:07 PM   #3286
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,504
Originally Posted by mgorman View Post
I still have my '89 TA, 2 totally different beasts but I love them both.
I felt the TA was just too compromised. I didn't like it offroad, and I didn't like it onroad. That said, for a bike I "didn't like" I owned it for 6 years.
Now if the TA had a kickstart like the ADV it might be a different story . Since I figured out the kicker, I've been starting the KTM nearly every day for the last week just because it's so damn cool.
Old 11-01-2012, 04:21 PM   #3287
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,477
2 x8000 km trips on mine, and about 4000 2up, not vibey to me. I love that bike even though my cam roller failing ended up in a bunch of damage. Not a big deal if you plan for that maintenance near 30K.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 11-03-2012, 11:04 AM   #3288
hillbilly enduro
hillbilly enduro's Avatar
Oddometer: 20
I just read the thread on the neoprene fork guards. It's mentioned to shorten them, as they will affect the suspension if not... Anyone know how long they should be???
hillbilly enduro is offline   Reply With Quote
Old 11-04-2012, 01:40 AM   #3289
bmwktmbill
Traveler
Oddometer: 5,103
You can slid then up and down.
Currently mine are 6 " long, maybe they are pieces of others I cut up.
You could cut a set in two and have replacements, they get worn looking after a while.
They mostly act as additional wipers for me.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 11-05-2012, 01:25 PM   #3290
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,449
sorry for the cross posting. not getting bites at the other thread.
Originally Posted by NSFW View Post
my cush hub sprocket carrier is from a 2002, the carrier not turning smoothly, there's some resistance, and somewhat crunchy.
pushed bearing out, it's made by NSK (germany), # 6205 B2RSR2NG. the OD is 2.0465-2.0470. the bearing itself turns smoothly and no play.
anyway, since it's 2 years old and over 6k miles, i decided to get a new bearing. JAF 6205RS (made in japan @ $30). same OD as the NSK 6205.
i checked the ID of the carrier, 2.0442-2.0445...
based on the above numbers, the interference is over .002. that's a lot....
that explains why the bearing was tight. the outer raceway was getting crushed causing it to collapse.
we do a lot of press fit bearing installation here and the typical interference is .0005 - .001.
does anyone has an uninstalled oem ktm bearing ? OD? :
what's the ID of your carrier?
my next move is machine the ID of the carrier by removing .001 of material.
and thanks in advance.
NSFW is offline   Reply With Quote
Old 11-05-2012, 01:34 PM   #3291
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,445
Is the bearing you are talking about the double race one in the rear? If so there is a bearing that is exactly the same, but with different part numbers that works...it is for a Chevy truck I believe. Cheaper and easier to source than the part from KTM. Let me know if that is what you are looking, I think I still have the box for the one I used in my '02 somewhere in the garage.
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 11-05-2012, 01:42 PM   #3292
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,449
thanks j, i already have the bearing, just single - 52mm od, 20.5mm wide and 25mm id.
Old 11-05-2012, 01:56 PM   #3293
juames
juames's Avatar
Oddometer: 2,445
Are you sure? I thought the rear sprocket bearing was a double race. I'll dig out the box and see what the part number is. Shouldn't have to machine anything off it.
Old 11-05-2012, 02:16 PM   #3294
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,449
i'm positively sure. ktm switched to 2 bearings on the newer models, my guess from 2005 and up
it's item #28
Old 11-05-2012, 02:24 PM   #3295
juames
juames's Avatar
Oddometer: 2,445
Yep #28 that's the one...definitely double race. Changed it on my 2002 this summer.
Old 11-05-2012, 02:30 PM   #3296
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,449
my mistake, double race but 1 bearing. i got it mixed up with peeps using 2 bearings that are narrow.
i believe you. what's the outside diameter of your bearing, metric and std (4 decimal places) if you can?
thanks.
joel
Old 11-05-2012, 04:21 PM   #3297
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,179
thanks.
joel
I have an NSK bearing from my 03 cush that pretty much measure 52mm spot on... The bearing number I replaced it with NSK- 3205b-2rsrtngc3, I picked this up from a bearing supply place for about $30...
640 A x 2
BC RIDING 2014
gunnerbuck is offline   Reply With Quote
Old 11-05-2012, 04:44 PM   #3298
Alik
viertaKTMotor *****
Oddometer: 260
Originally Posted by kelvyn View Post
So - I had to replace an O-Ring on the end of the cam/valve rocker thing - took these photos,
How many miles does this engine have? What's your thoughts on the condition?
https://dl.dropbox.com/u/16137719/IMG_1597.JPG
https://dl.dropbox.com/u/16137719/IMG_1598.JPG
https://dl.dropbox.com/u/16137719/IMG_1599.JPG
Answer - circa 23,000 miles, just returned from a 6,000 mile trip from England, Spain, France, Morocco and back :-)
Condition, a little rattlier than when it left.. probably going to ride it through winter and rebuild (pay for a) - in february.
It probably should have been serviced while out there, but c'est la vie.
I would invest in the new rollers - the bigger one already looks worn, causing (worse) cam wear too. But You should know it if You are planning rebuild. ;)
Alik is offline   Reply With Quote
Old 11-05-2012, 11:02 PM   #3299
bmwktmbill
Traveler
Oddometer: 5,103
Pop the grease seal on the old onee an completely wash it out remembering it is a two race bearing. Get it very clean, then regrease it and replace seals. reinstall it and run it another 20K miles.
Every 20K miles...Remove again, repeat.
I doubt you wrecked it, it is a tough bearing. Mine has run with a little 'hitch' for 50K miles. There is no play in it, just a very scant roughness.
Heat the sprocket carrier assembly with a propane torch to instal/remove.
Get it fairly hot.
to install, bearing in the freezer, use some lube if you must.
bill
Bill Shockley
bmwktmbill screwed with this post 11-05-2012 at 11:07 PM
Old 11-06-2012, 11:37 AM   #3300
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,207
Just try not to beat on the inner race, it sometimes divots the metal creating that chunkiness feel. Use a puller if you can
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Times are GMT -7.   It's 05:52 AM.
