Old 02-03-2013, 12:17 PM   #3586
640 Armageddon
640 Armageddon's Avatar
Oddometer: 438
Originally Posted by faustinoeldelbarrio View Post
I also took down the left light, and noticed there is a spot where a bolt might go, but i am not sure if there should actually be something there. The left light actually has a threaded hole that matches the spot I signaled in red in the next picture:
Anyone has any opinions on these issues?
My 2002 was exactly the same, the bolt was missing. I bought a second set of headlights on ebay and there is a vibration dampener there. This is the same dampener as the one used in the light support bracket.
I used to run the lights without this dampener and nothing weird happened, I have LED's now so
D.
Work like you don't need the money
Live like there's no tomorrow ...
640 Armageddon is offline   Reply With Quote
Old 02-03-2013, 12:28 PM   #3587
faustinoeldelbarrio
Faustino
Oddometer: 33
Thanks to both of you, I'll consider buying the dampener to give extra support for the lights.
faustinoeldelbarrio is offline   Reply With Quote
Old 02-03-2013, 01:14 PM   #3588
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,168
Send a message via MSN to warewolf Send a message via Skype™ to warewolf
Originally Posted by Boon Booni View Post
Maybe someone did some shad tree porting/polishing, though I've read that the porting and polishing from the factory looks poorly done.
"Looks" being the important word. There is no correlation between looks and flow. Some of the roughest porting generates great flow characteristics. Only the flow bench (or dyno) can tell you what is "beautiful". :cool:
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
Originally Posted by Steve McQueen
All racers I know aren't in it for the money. They race because it's something inside of them... They're not courting death. They're courting being alive.
warewolf is offline   Reply With Quote
Old 02-03-2013, 02:06 PM   #3589
gunnerbuck
I.Hopp.
Oddometer: 3,075
This hole is unused on the left side of the framework, on the right side it supports the horn and wiring support...
I use these on both sides to bolt my LED light support brackets on, it keeps them tucked in nice and tight out of harms way as pictured below...
640 A x 2
gunnerbuck is offline   Reply With Quote
Old 02-03-2013, 02:50 PM   #3590
bmwktmbill
Traveler
Oddometer: 3,998
Originally Posted by beek-02 View Post
Hi Bill,
I've worked on quite a few bikes , cars, etc. Have a pretty fair working knowledge of how motors work but cannot figure out how bad valve guides/seals could continue to a bubbling radiator? Not questioning your knowledge just looking for some enlightenment.
Beek
Sent from my SCH-I535 using Tapatalk 2
Beek,
Please, you should question my knowledge!!
Like you I have worked on a little bit of everything including people as I am a nurse.
As for the LC4, I think possibly failing valve guides and seals allows engine compression into the top of the engine forcing engine oil into the air box. If the water pump seals are also bad engine oil and air could be forced into the coolant as well.
I know that sounds crazy but I had a situation like that happen to me(I think).
I had bubbles and oil in the coolant/radiator, coolant in the oil and oil in the air box.
I thought I had a cracked head so I tested it using Gunner's method...it was not cracked. So why did I have so much oil in the air box and oil in the coolant, air bubbles in the coolant and coolant in the oil?
I rebuilt the water pump and rebuilt the head with valves, guides and seals.
All is well now.
When I removed the head the head gasket was perfect. I did replace it.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 02-03-2013 at 03:01 PM
bmwktmbill is offline   Reply With Quote
Old 02-03-2013, 10:35 PM   #3591
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,013
Send a message via Skype™ to Low594
My headlight has that dampner, but it secures to a bracket just inside of where you outlined, not visible in this pic.
'99 KTM 640 Adventure R
East Bay Weekly Coffee
Support your local creep! CREEPS MC
Low594 is offline   Reply With Quote
Old 02-03-2013, 11:42 PM   #3592
hAjPR
Location: Czech Republic (that's in between Germany&Poland!)
Oddometer: 11
Speedo
I read somewhere that the KTM speedo can be modified that the digits of Trip 2 become the same size as speed digits? Can anyone advise, please? It's 640A '07 plus I got the tripmaster switch. Thanks!
'07 LC4 640 Adventure
hAjPR is offline   Reply With Quote
Old 02-05-2013, 06:19 AM   #3593
Kawidad
Kawidad's Avatar
Oddometer: 3,804
I'm in too. I just bought a 2001 640 Enduro from a buddy, so I guess I've got a lot of reading to do.
"Deeply flawed people make deeply flawed decisions."
Kawidad is offline   Reply With Quote
Old 02-07-2013, 07:47 AM   #3594
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,159
Originally Posted by Gerst View Post
Hi all, this is a premature post on my part. But I think I have this bracket, new, in a box somewhere.... If anyone wants it I'll let it go for shipping plus a donation to Baldy. I'm posting before I confirm this as I know I'll forget about it if I don't do it now. With my current work schedule it may take a few weeks before I can dig it out and ship it. If your interested PM me, be patient and I will get back to you. Just trying to help out an inmate and ADV which has given me so much.
Gerst
Following up on this, Gerst sent me a link to some photos of the bracket he has. I'm nearly 100% certain that it is not the SW-Motech bracket, but I'm not sure if it's something else that will work on and ADV. I haven't seen it before, but I've only been at this a short while.
Anyone seen this before, and know if it will work on a 640ADV? It vaguely looks like the KTM bolt on option, but it looks like the spring would have to be routed under the stand instead of on top?
I'm about ready to have a friend weld a tab on my frame so I can run a center stand and side stand, but if this would work as a bolt on option, I'd prefer that.
Thanks..
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx
You can be Han Solo, and I can be another Han Solo...
Boon Booni is online now   Reply With Quote
Old 02-07-2013, 01:49 PM   #3595
rxcrider
rxcrider's Avatar
Oddometer: 972
Thanks..
That looks exactly like the bracket for the SW Motech side stand I had on my '97 400RXC. It would not work with a center stand and I'm not sure if it would fit a newer 640, even if you removed the center stand.
Here it is at twisted throttle:
http://www.twistedthrottle.com/sw-mo...nduro-rim-size
It is an automatic up stand so watch your shins when you lift the bike off the stand. Also keep the pivot point clean and lubed. With the spring mounted on the inside, any play that develops allows the stand to be pulled in and eventually the foot starts rubbing a groove in the swing arm. It also doesn't tuck in very well or pul up very high so it is prone to getting dragged through the mud if you are in a deep rut.
'95+'95+'96 BMW R1100RS/RSL
'99 Husky WR250
'98 Honda XR 70
AMA, OMTA (ohio organization), BRC, BMWMOA
rxcrider screwed with this post 02-07-2013 at 02:39 PM
rxcrider is offline   Reply With Quote
Old 02-07-2013, 09:10 PM   #3596
bmwktmbill
Traveler
Oddometer: 3,998
Guys,
I have lowered my 640a so the center stand an kick stand have been either shortened or bent to function properly and to hold the machine at the proper angle.
The tubing is good quality and if heated, bent and cooled slowly the strength is not affected. You can also braze on the tubing if you want to add different feet or other accessories.
Rustolium grey paint is a good match to KTM frame grey.
bill
Bill Shockley
Old 02-07-2013, 09:52 PM   #3597
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,013
I just changed the 1piece Throttle Assembly/Right Control Pod out for the Pod from a 950(not PlugNPlay) and the independent Throttle from a 250XCF. I did this so I can adjust the cable angle without affecting where the starter button sits. The following I posted in my build thread!
Originally Posted by Low594
So I was able to ride the bike today, just down to our weekly coffee. Only about 6-8 miles round trip. The throttle changes were so drastic, it seemed like a whole different bike! Super crisp response and return to idle! It was probably a combination of things, not sure what made the biggest differences. Could have been: questionable old cables, old lube/oil (2 yrs since last lubbed), good new cables, G2 throttle sleeve, fresh cable oil or the Dow33 lube on the throttle tube/assembly.
I should have compared the size of the throttle tube cams. The G2 was marked K100, which lists as stock, but for a 2008 250XCF, not a '99/'01 640A!
Here's what was used:
-'08 250XCF Throttle Housing (77002010100)
-G2 K100 Throttle Tube kit
-'05 640A Throttle Cables
-Smart Parts SL33K/Dow33 lube (yes, paintball lube!)
-Cable Life lube
This reminds me, that my clutch and decomp cables are long over due for a lube!
BTW, I've got lots of changes going on, in prep for a trip to Death Valley in a month and a half!
Low594 screwed with this post 02-07-2013 at 10:00 PM
Old 02-08-2013, 07:36 AM   #3598
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,159
You nailed it, thanks.
Old 02-08-2013, 10:00 PM   #3599
Mo-Tarded
Mo-Tarded's Avatar
Oddometer: 136
Originally Posted by Mo-Tarded View Post
Katrina has developed a leak when the gas is "On". Also have a slight hesitation mid-range (feels like a fuel starvation). So I'm going in... (Again).
So I got the BST parts marked with a '#' kit. Pulled the carb off, found nothing remarkable... R/R'd all the elements in the kit, put it all back together, temporarily hooked up the tank, turned on the gas and it's leaking worse.
So I pulled the float bowl off while the carb is on the bike and of course the float bowl frame and floats essentiall off/out.
I put the float frame back up into the fuel intake seat and turned the gas on and toggled the floats up and down. It was still leaking gas in the "Up" position. The only other leak path would be around the rubber "O"-ring around the float bowl frame insert into the gas intake itself.
Went to the local H/W store that has a bunch of rubber "O" rings and found one to fit. R/R'd the one on the frame and repeated the above. No leak...
While I found the solution, the problem is the "O" ring that failed (dried/shrunk/fatigued) is NOT in the "#" kit. It comes with the float bowl/frame assy.
It's all back together and runs flawlessly through the entire power band.
"Our lives can be spent carrying out actions that we hope will lead us to a greater sense of purpose, accomplishment and meaning, but all these are secondary to the need to feel alive." - AntiHero ADV Rider
Mo-Tarded is offline   Reply With Quote
Old 02-08-2013, 10:22 PM   #3600
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,013
Great timing! Mine just started doing the same!
Times are GMT -7.   It's 07:45 PM.
