Old 02-22-2013, 05:31 PM   #3646
DaddyBigDaddy
AKA -Evel Kneilson
DaddyBigDaddy's Avatar
Location: Liberal ShitHole, San Fran-sissyco, Kalee-Fornee-a
Oddometer: 309
Came with
Originally Posted by Droptarotter View Post
BigDaddy;
Where did you get the tank guards??
Cheers
Came with the 1998 620 Adv I recently bought
No idea who makes em but perfect fit, I only bored out the left petcock access hole that was way too small...used a doorknob drill bit...perfect size now and painted orange to match tank
PS rust oleum enamel in safety orange is a perfect match!
DaddyBigDaddy
1998 KTM 620 Adventure
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
DaddyBigDaddy is offline   Reply With Quote
Old 02-26-2013, 09:27 AM   #3647
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,710
The front end of my 2002 640 ADV has an unacceptable amount of stiction (2 bushing "48" USD). I compared mine to a friends 950 and his front end is soft a supple when pumping the bars.
When I picked the bike up from the PO last fall the front would bind up pretty bad after 2 pumps. I replaced the fork oil and verified that the forks were installed parallel and equidistant all the way down. They aren't twisted or anything in the triples.
The fork oil helped a bit, but it still stictions up more than I would like when I pump them. I think it might be the seals as I could feel a little bit of stiction even when pumping the forks against the ground while off the bike. I've verified with v-blocks and a dial caliper that the fork tubes are strait as an arrow, and everything moved very nicely before the seals were installed. (I re-used the seals)
Looking at Mun's web site they show the fork seals for my bike as NLA. I seem to remember reading a write up of various seal manufacturers but can't seem to find it now. Anyone have a link to that write up, or a recommendation for the "slickest" fork seals?
Thanks..
Oh and...
...my first real 30 miles on the bike.
Boon Booni is online now   Reply With Quote
Old 02-26-2013, 07:31 PM   #3648
bmwktmbill
Traveler
Oddometer: 5,205
Boon,
A couple of things.
What torque did you use on the triple clamps?
The front axle.
Did you use the procedure outlined in the owners manual to reinstall the wheel.
Did you clean out the tunnels on the bottom of the fork legsand polish the axle so it will slide easily and the forks can find center after you pump them.(don't oil the axle slide area).
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 02-26-2013, 07:48 PM   #3649
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 309
Heat gun
Originally Posted by Hurley959 View Post
Silicone is probably your best option, you definitely don't want a bunch of crap getting down in between the guard and the tank.
It's a pretty permanent option though, so keep that in mind. I just peeled mine off to have a fresh wrap of carbon and some shiny clear added to them, and removing the old silicone from the tank took some serious effort. Even after a few hours with a razor and some turpentine, there's still a film that I'm not sure I can remove.
Heat gun
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
Old 02-26-2013, 08:56 PM   #3650
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,132
I thought the 02s had 43mm forks? SKF seals are the best for the wp forks, at least that's current wisdom. I know they're available for the 48mm MXMA, not sure about the 43s. 43mm USD WP forks are common though, I think aftermarket places like Moose and Synergy seals will be selling seal/bushing kits.
So when you have the forks out and assembled except without the top cap screwed into the fork outer leg, the outer/inner don't slide smoothly?
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 02-27-2013, 05:21 AM   #3651
Hipster
Hipster's Avatar
Oddometer: 1,812
In the suspension thread over at ktmtalk one respected suspension builder sands the fork tubes on his personal bike with 240 grit sand paper (on a lathe) to reduce stiction. He said for customers bikes he'll use 400 or 600 grit because they'll complain about the appearance of scratched fork tubes.
It seems counter intuitive but, he says it similar to honing a cylinder bore where the scratches retain a film of oil, thus reducing friction.
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 02-27-2013, 08:06 AM   #3652
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,710
Originally Posted by bmwktmbill View Post
Boon,
A couple of things.
The front axle.
bill
Read up on Creepers(?) fork thread where he says to tighten the lower pinch bolts just finger tight, so not much torque. I've also experimented with having them completely loose and it makes no difference.
Top triples are torqued to what's in the owners manual.
Right fork is free to slide on the axle. With the right side axle pinch bolts loose I can deflect the fork a few mm along the axle and tapping the bottom of the fork will bring the fork back to center from deflected. It doesn't make any difference to the stiction if I leave the bolts loose or snug them up while pumping the forks. That said, I did not clean the pinch bolt tunnels of either fork.
Pretty sure they're 48mm. Measured them with a caliper and 48mm is listed in the parts fiche's that I've looked at. I didn't look at what type of seals they were when they were out. I should have, but thought the stiction was from the 2 year old oil in my forks.
When I dropped the tubes into the sliders everything moved like butter along the full stroke of the fork. Smooth and silky. I remember there being a little stiction once I installed the seals, but before installing the spring and top cap. I didn't think anything of it at the time. I did put some grease between the two lips of the fork seals before driving them into place.
Once everything was assembled and filled with oil, I compressed the forks against the ground with my weight, and could detect a little resistance from the seals but it seemed acceptable. Maybe it's the combined stiction of both forks that I didn't take into account.
The seal review I remember reading listed 5-6 different manufacturers and which ones were notorious for stiction, which ones typically started leaking the quickest etc. I remember Moose was considered low quality and that OEM were well regarded but beyond that I'm a blank..
That makes sense to me. Not only could the scoring help hold some oil, it might break the seals in faster as well.
I was hoping the the 200 miles I did this weekend would help loosen them up some, but that didn't happen.
Boon Booni screwed with this post 02-27-2013 at 08:38 AM
Old 02-28-2013, 07:02 AM   #3653
Hurley959
Hurley959's Avatar
Oddometer: 58
It doesn't sound like seals to me if they're moving freely with the caps off. Either they're binding due to something being bent, or there's an internal issue.
If the oil wasn't changed with any regularity it's possible that you have a valve that is gummed up and not flowing like it should. I'd tear them down completely and inspect for issues. These things are pretty easy to work on, just a little messy. Re-assemble, set your air gap, reset your clickers to stock settings and go from there.
These forks are known for the rebound valve getting funky and losing full range of adjustment, so make sure to clean them while you're in there.
Hurley959 is offline   Reply With Quote
Old 02-28-2013, 07:55 AM   #3654
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,710
They were smooth with the caps off, but before I drove the seals in. I don't remember what they were like with the caps off but seals in. (I don't think I checked as I was just moving along with the rebuild.)
I did rebuild the forks down to the shim stacks (disassembled the stacks to clean the valves). I found one of the rebound valves gummed up, the other looked perfect.
Boon Booni screwed with this post 02-28-2013 at 08:44 AM
Old 02-28-2013, 11:01 PM   #3655
Droptarotter
Oddometer: 1,288
I added a little more orange to my 640 today. A new front fender and some fork guards off of an 85SX.....
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is online now   Reply With Quote
Old 02-28-2013, 11:24 PM   #3656
bmwktmbill
Traveler
Oddometer: 5,205
Boon Booni,
I'd start a separate thread on this one.
You have a problem and it has a solution.
Something isn't right.
I think you need to pull the legs off and dump the oil into something clean and then work both legs without the springs or oil.
bill
Bill Shockley
Old 03-01-2013, 09:02 AM   #3657
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,710
Boon Booni,
bill
Yeah..
Talked with Neil at Hitchcock Industries last night. He actually re-valved my forks 2 years ago for the PO, also installed OEM KTM seals at that time. Neil doesn't think changing the seals out would make that big of difference. He thinks if my axle is strait, the bottom triples aren't too tight, the forks are parallel in both x & y planes and that I'm positive the axle clamp on the right fork is aligning correctly that it's more than likely the bushings. When he rebuilt the forks 2 years ago he didn't replace the bushings, and several thousand miles and lots of offroad could easily have done the bushings in. He gave me some specs to check for tolerance. I'll pull the forks in the next few weeks and check the bushings, probably install new ones no matter what and see what happens.
I'll try to remember to take some photos for a refresher on the shade tree mechanic fork re-build.
Old 03-01-2013, 06:02 PM   #3658
DesignerRider
Adventures Since 1984
DesignerRider's Avatar
Oddometer: 100
Eek Why did a woodruff key come out with my oil??!!
Yes, sorry to change the subject, but just wondering what to do now. I drained the oil from my 620 lc4 and a woodruff key came out on the magnetic drain plug.
From my michofiche I saw three keys in the bottom end one on the flywheel side and two on the clutch side (one of which is smaller than the other). This appears to be a larger key and so could be from either side.
Should I tear the thing apart or just ride and hope nothing spins?
I hate it when extra stuff comes out with the oil!
97' KTM 620 EGS-E Rally Adventure
97' KTM 620 RXC-E (the "e" part doesn't work)
88' Honda XR600
70' Yamaha DT175 Enduro
DesignerRider is offline   Reply With Quote
Old 03-01-2013, 07:15 PM   #3659
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,710
From my michofiche I saw three keys in the bottom end – one on the flywheel side and two on the clutch side (one of which is smaller than the other). This appears to be a larger key and so could be from either side.
Hate that. I don't see how a woodruff key could come out while the motor is assembled. They can be pushed out of place during assembly though.
What do you know about the bike? How long have you had it? How many miles since the last rebuild?
Old 03-01-2013, 07:31 PM   #3660
DesignerRider
Oddometer: 100
Thanks for the reply. It has roughly 25k on the engine, but what I do know is that about two years ago the engine was torn down to replace a main bearing that was going bad. Sort of a fluke failure, but that's another story. The work was done by a very good KTM shop in SoCal.
Do you think it's possible that key has been loose in there for two years of riding? You're right, I don't see how it could come out after being installed.
88' Honda XR600
Times are GMT -7.   It's 08:58 PM.
