Old 04-05-2013, 04:16 PM   #3736
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,130
Originally Posted by Droptarotter View Post
Low.........you forgot to add the "Teaser Beer" waiting in the fridge for when you get the carb out!
Cheers
True that... I was trying for the subtle hint!
Low594 is offline   Reply With Quote
Old 04-08-2013, 08:11 AM   #3737
DaddyBigDaddy
AKA -Evel Kneilson
DaddyBigDaddy's Avatar
Location: Liberal ShitHole, San Fran-sissyco, Kalee-Fornee-a
Oddometer: 303
How do I run hi fender dual disc 640 brake lines?
How do I run/get hi fender dual disc 640 brake lines?
The stock Brake crossover line is too short for a high fender setup and I want to keep dual discs.
Is there a longer right caliper cable available from Ktm and if so how to route it?
DaddyBigDaddy
1998 KTM 620 Adventure
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
DaddyBigDaddy is offline   Reply With Quote
Old 04-08-2013, 11:22 AM   #3738
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 13,693
The touratech kit comes with one.
A bit pricey but its a plug and play.
http://www.touratech-usa.com/Store/P...er-LC4-640-ADV
Maybe the PDF instructions will give you some ideas
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 04-08-2013, 12:53 PM   #3739
FreeGranite
Nubile dirtrider
Oddometer: 118
Yowza,that is pricey. I bet Spiegler Performance can custom make one to work. I had them make one for my LC4E because the stocker was a bit short with risers and a Lynx. Real trick. You will need to call them to place the order, but you can get a quote through the interweb. The man I talked to even had an LC4 SMC. Also, the orange is a good match.
FreeGranite screwed with this post 04-08-2013 at 12:54 PM Reason: I before E except after C
FreeGranite is offline   Reply With Quote
Old 04-08-2013, 01:00 PM   #3740
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,130
If you have to have one made, I recommend Royal Brass in San Jose... they do real nice custom orders!
Old 04-08-2013, 01:08 PM   #3741
enduro0125
enduro0125's Avatar
Oddometer: 13,693
I remember someone (Pyndon maybe?)
did a crossover from the left line on his 9xx
Another option.
AMA 487807A
Old 04-08-2013, 02:40 PM   #3742
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 303
Pass on TT
Thanks for Spiglar tip. Ill have them make 2 cables and just put a double feed bold on my master
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
Old 04-08-2013, 07:11 PM   #3743
tstick14
tstick14's Avatar
Oddometer: 151
second filter cover gasket
I got those pesky o-rings in the carb to bite I posted about a little while back, just a little organic spit lube and they squeezed in and stayed.
Now I just drained the oil out, checked Creeper's how to, everything is good except one thing. The 2nd filter cover is supposed to have a gasket right? There was none when I pulled it off? When I looked it up in my pdf maintenance guide and the parts fiche online I'm finding different answers for what should be there. I have an 03, should I get the o-ring and gasket or just the gasket for the second filter cover? There is no groove for an o-ring but the maintenance manual states there is, but online fiche diagrams only show the gasket?
Straddlin' 640 Adv.
tstick14 is offline   Reply With Quote
Old 04-08-2013, 08:53 PM   #3744
dnrobertson
Big Bike, Slow Rider
Oddometer: 794
Guess you already know, but you should have a double feed bolt on one of the calipers. When you get the new hydraulic lines (or are you really converting to cables ), just swap the master bolt with the double caliper bolt.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 04-08-2013, 09:25 PM   #3745
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 303
Thanks for the tip! I actually need 2 single bolts now, 1 for each caliper, then if I want switch to my off road single disc wheel I can just run 1 single bolt off the master.
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
Old 04-08-2013, 09:28 PM   #3746
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,178
The tourtech kit kind of sucks. The guides are flimsy and the mounts to adapt the fork guards to the fork legs are even cheesier. Both of mine fell apart just installing them then one broke trying to put it back together.
There is a parts list I believe in the Orange Crush section or check KTMtwins.com or ktm950.info - The guards from one of the KTM 85cc minis work for the lowers and if you buy a second lower cable guide and install it upside down under the existing guide, you'll have that covered.
You will need a 2nd full length brake line from a 950/990. Remove the banjo bolt/washers from the left caliper to install the brake lines to the master cylinder. Then use that master cylinder bolt to fasten the left line back to the caliper. All you will need to do is hose clamp an upper guide to the right fork leg to keep the right line moving vertical and put a loop in the line so it can bend and flex as the wheel moves through the travel.
You will also need to make a fastener for the right leg to attach the right brake line t the guard
And of course, a fender
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 04-08-2013, 09:38 PM   #3747
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 303
Actually
I'm doing all this for 1997 620 Adventure Rally build. Found a Euro model w original KTM Dakar motor w 325 miles!
I bought a 2007 640 48mm dual disc front end and RTT triples w built in stabilizer. Now i have a single disc front wheel and the dual disc I can swap fairly quickly.
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
Old 04-08-2013, 09:57 PM   #3748
theGrinch
SNF Dream Riders
theGrinch's Avatar
Oddometer: 2,004
The flat gasket supersedes the o-ring style, if your cover has no grove for the o-ring some one has replaced it. When you say there was no gasket when you pulled it off, what was used? silicone? RTV?
Originally Posted by pcvance View Post
Who's the clueless noob?
theGrinch is offline   Reply With Quote
Old 04-08-2013, 11:10 PM   #3749
RiverRatRider13
Motorcycle Chum
RiverRatRider13's Avatar
Oddometer: 335
well i pulled the trigger on the seat concepts foam and cover. Got the grip top, carbon sides, and orange stitching. Pretty excited! Read quite a few good reviews on them.
Still really trying to find a speedo though, I hate trail techs and want mechanical.. I found a Duke 2 speedo, will this work?
RiverRatRider13 is offline   Reply With Quote
Old 04-09-2013, 05:48 AM   #3750
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,887
Use 518 or 515 Gasket Eliminator.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is online now   Reply With Quote
Times are GMT -7.   It's 09:34 PM.
