Old 04-09-2013, 06:32 AM   #3751
Kawidad
Kawidad's Avatar
Oddometer: 4,918
Quick question for the collective.
My 2001 640E has developed a small leak on the seal that lives on the shifter/kick starter rod. I have a new gasket and o-ring in hand, but before I pop the old one off is there I should know or anything different? Or is it the usual, like other bikes and pop the old on off and put a new one on with a seal driver?
I'm leaving for a long ride at the end of the week and don't want to screw it up before the trip.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 04-09-2013, 07:12 AM   #3752
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,280
A bit on it in here starting at post # 102: http://advrider.com/forums/showthrea...=732362&page=7
gunnerbuck is offline   Reply With Quote
Old 04-09-2013, 07:52 AM   #3753
Kawidad
Kawidad's Avatar
Oddometer: 4,918
Thanks, I knew you'd have the answer.
However, the seal I got from Munn Racing looks nothing like either of the ones you've pictured. I guess I better call and find out before I begin.
Old 04-10-2013, 07:00 PM   #3754
supercoyote
Oddometer: 94
Public Service Announcement
Just a reminder to all YFF
Please check your valve clearances
Or else your new owner may find this and be terribly saddened for all of your future vehicles
http://imgur.com/QP3uRrU
There's only one rule that I know of, babies - God damn it, you've got to be kind.
supercoyote is offline   Reply With Quote
Old 04-10-2013, 07:01 PM   #3755
jrozar
jrozar's Avatar
Oddometer: 627
we have a local shop that makes hoses for use, I raised my rally fender by an inch and the made nme a line 2"'s longer for $35.00 with fittings and all.
Originally Posted by DaddyBigDaddy View Post
How do I run/get hi fender dual disc 640 brake lines?
The stock Brake crossover line is too short for a high fender setup and I want to keep dual discs.
Is there a longer right caliper cable available from Ktm and if so how to route it?
jrozar
Las Vegas NV
www.my2wheels.com
jrozar is offline   Reply With Quote
Old 04-11-2013, 07:40 AM   #3756
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,247
Originally Posted by Droptarotter View Post
For the seat........check with Seat Concepts.
Cheers
When I talked to Seat Concepts they said they don't have a seat for the E.
Sent from my SCH-I535 using Tapatalk 2
Sparrowhawk is offline   Reply With Quote
Old 04-11-2013, 08:26 AM   #3757
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,157
I think that might be a first.... a place that makes something for the A but not the E!
Low594 is offline   Reply With Quote
Old 04-12-2013, 02:33 PM   #3758
RiverRatRider13
Motorcycle Chum
RiverRatRider13's Avatar
Oddometer: 339
I will let you know bc I ordered one... should have it in a few days
"E" is for enduro right?
http://seatconcepts.com/products#!/~...52&id=15208090
RiverRatRider13 screwed with this post 04-12-2013 at 02:58 PM
RiverRatRider13 is offline   Reply With Quote
Old 04-12-2013, 04:57 PM   #3759
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,280
You probably have the inner seal that mounts in the case... You can probably get a seal hook to pry that one out, it should be easier to change than the shift shaft seal that I had pictured in the link...
Yeah, you better check real good as to which seal is actually leaking...
Old 04-12-2013, 08:58 PM   #3760
trevor2k
Oddometer: 34
So, after not installing my rear luggage rack for the 1.5yrs of owning it, I found out tonight that it doesn't fit my bike. The rear tabs for the subframe holes are not in the right position and it seems like the length of the "grab" handles isn't long enough for my rear fender. I have a 2000 LC4E 400, (which is technically more of a '99 - thanks for the loose model year changes KTM!).
Any ideas of what this rack would fit? Earlier 620s? Guess I need to sell or trade it for the right one.
On my LC4 I think the rear support tabs should be on the central bars....
trevor2k screwed with this post 04-12-2013 at 09:03 PM
trevor2k is offline   Reply With Quote
Old 04-13-2013, 04:41 AM   #3761
Hipster
Hipster's Avatar
Oddometer: 1,812
Guts Racing sells seat kits for the 640e http://www.gutsracing.com/pages/719.html
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 04-13-2013, 05:05 AM   #3762
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,503
That looks pretty much identical to the rack on my 2002 640adv.
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 04-13-2013, 07:05 AM   #3763
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,280
Yep, fits all the models with the newer type fender up to 2007...
Old 04-13-2013, 07:55 AM   #3764
trevor2k
Oddometer: 34
Thanks for the feedback gents. If anyone in here wants it, I'll trade it for the proper fitting rack or a skid plate. I'm going to post it up in the fs section when I get back from my sw Utah trip.
Old 04-14-2013, 06:57 AM   #3765
Kawidad
Kawidad's Avatar
Oddometer: 4,918
I talked to Chip Munn and he said that KTM made several design changes to the seals depending on year of production, so the one he sent me is supposedly the correct one, so we'll see.
Times are GMT -7.   It's 07:12 PM.
