Old 04-18-2013, 02:55 AM   #3781
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 14,667
Derrick at Motolabs has them.
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 04-18-2013, 03:22 AM   #3782
TexasDirt
Oddometer: 19
Clutch cable 58402090000
So I broke my clutch cable as I arrived at work tonight.
Has anyone tried or succesfully used an alternative cable to the OEM part(58402090000)? I need to get one on the bike ASAP since it is may primary source of transportation(yes by choice, cars are for sissy's!).
TexasDirt is offline   Reply With Quote
Old 04-18-2013, 09:00 AM   #3783
Tseta
Lost
Tseta's Avatar
Oddometer: 674
Originally Posted by tstick14 View Post
So there I was re-installing my BST after new jets and all. Was "extra" careful with that cheap plastic choke nut, had it all in nice. Started connecting the throttle cables then noticed that the back side of the plastic housing was broken! I started looking and didn't see what I was looking for, can I just replace the plastic house nut, and whats the part #? Check out this video, could we do this with our choke?
http://www.youtube.com/watch?v=Z4Bi4YWTaqQ
You should have asked this question in the BST-40 Bible Thread (linked on the first page of this Index Thread!), or even better, read through (at least the first page of) that thread, the answer is contained there...
But here's something even better (also contained in the mentioned BST-40 bible thread): http://www.advrider.com/forums/showp...&postcount=555
Cheers,
Tseta
Tseta is offline   Reply With Quote
Old 04-18-2013, 12:28 PM   #3784
dolphins13
orange rules
Oddometer: 138
[QUOTE=TexasDirt;21213252]So I broke my clutch cable as I arrived at work tonight.
Has anyone tried or succesfully used an alternative cable to the OEM part(58402090000)? I need to get one on the bike ASAP since it is may primary source of transportation(yes by choice, cars are for sissy's!).[/QUOTE
There is a simple mod for the clutch cable. I cant find the link? I cant put pictures on here to show you. Basically just use a zip tie and a little piece of tubing (maybe 1.5") To hold the cable against the frame so it dosnt wiggle so much right by the handle. Actually feels smoother? I think? Maybe someone else can help you find link or explain it so you can understand better? I believe the cable will last a lot longer. Not sure how much longer tho?
dolphins13 is offline   Reply With Quote
Old 04-18-2013, 03:57 PM   #3785
Blue Man
Oddometer: 64
2004 640
My buddy has an '04 with 90 miles on it, does anyone know what this thing is worth, been sitting in my shop and now he wants to get it gone.
2001 XR 650R- dual sport
2003 XR 650R- fun bike
2002 YZ 250- district bike
2006 YZ 125-sons race bike
American Quarter Horse-wifes ride
Blue Man is offline   Reply With Quote
Old 04-18-2013, 04:16 PM   #3786
theGrinch
SNF Dream Riders
theGrinch's Avatar
Oddometer: 2,103
Question
Pics? which model? does it run?
Originally Posted by pcvance View Post
Who's the clueless noob?
theGrinch is offline   Reply With Quote
Old 04-18-2013, 09:36 PM   #3787
TexScrotumRidesAgain
Oddometer: 22
LC4 Rear Hub has CRACKS,is this normal wear&tear?
G'day,I just changed the rear tyre on my 2000KTM LC4 620 Supercomp and(too my HORROR) discovered very fine cracks between the spokes and bearing housing(drive-side)on the outside of the hub,they are in the dished section.
I removed the bearing and gave the inside and outside of the hub a good clean.As far as I can see there are NO cracks inside the hub or on the other side of the hub where the sproket and spokes attach to.In other words the cracks DO NOT go all the way thru.
Now my questions are,is this normal or should I start to pannic.The bike has about 12000kms on it!
Has anybody else experienced this?
Can I get a few more rides out of it(keeping a close eye on the state of the hub)of about 80-100km in lowspeed singletrail?
Or do I risk a complete failure in the middle of no-where?
I should also ad it is NOT a cush drive .
Any thoughts would be appreciated.
TexScrotumRidesAgain is offline   Reply With Quote
Old 04-18-2013, 09:49 PM   #3788
bmwktmbill
Traveler
Oddometer: 5,218
Originally Posted by mcguyver View Post
Hey all
I am replacing the steering head bearings on my 06.
When seating the the bottom bearing, should it be a tight fit down onto the seal or should there be a bit of freeplay between the seal and the bearing. I have applied about 150 psi of pressure to seat the bearing and am reluctant to apply any more and I still have a bit of freeplay between the seal and the bearing.
Any info appreciated.
How did you apply pressure to the bearing? I've always used the old shell to drive the bearing that was just removed from the oven.
Stick the triple clamp and bearing in the oven to warm things up or use a heat gun, add a little oil where things need to slip together, then use the old shell, a hammer and a punch to set the bearing tight.
Don't cook the seal, get things a little warm.
IMHO.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 04-18-2013, 11:07 PM   #3789
caribooster
Not enough time...
Oddometer: 51
Any crack in your wheel is a problem, I would start looking for a new one immediately. If you have a wheel failure in the middle of a corner it could be your last ride forever...!
caribooster is offline   Reply With Quote
Old 04-19-2013, 01:26 AM   #3790
Oddometer: 22
Don't get me wrong ,I'm taking this very seriously or I would'nt be online trying to sort it out!
It's just that it's the start of my riding season here and this is really inconvenient as I had planned some rides very soon.I thought if there's the chance I could get more info one way or another(this maybe a common prob)
With prices for a second hand wheel going for around $500(and I might still have the same issue)it looks like I'm going to have to source an aftermarket wheel from the states which I can get here (AUS)for less than $450.
I also don't wanna be in the middle of bumfuk with a busted bike!
Old 04-21-2013, 10:51 AM   #3791
tstick14
tstick14's Avatar
Oddometer: 151
what do all these electrical plugs go to?
I'm going through my bike, which I haven't done since I bought it last year. I'm finding electrical plugs that are unplugged and wonder what they go to and why they're unplugged. I'm not good at electrical diagrams and such so if you guys could look at the pics I posted below and maybe identify them for me?
Black plug pulled out on left and smaller white plug in center as well as single white plug on right above larger white plug set. All were tucked under right frame.
close up of plugs above
Two empty plugs sets under dash facing the bike
Another empty plug under dash from riders position.
Straddlin' 640 Adv.
tstick14 is offline   Reply With Quote
Old 04-21-2013, 12:50 PM   #3792
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,543
I have same un-used connectors on mine...from my understand the wiring harness is used on a few different models and not all the connectors are used in each case. And as for the one under the fairing up front, I believe it's for the optional handle bar mounted odometer controls.
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 04-21-2013, 01:36 PM   #3793
CSF
CSF's Avatar
Oddometer: 167
not sure about the ones under the seat... but the 2 2 prong plugs up front are for "accessories" (one of mine goes to a cigarette lighter port installed to supply power to a GPS), and there is a 4 prong plug for the trip master switch if you want to add that. There is a really useful wiring full color diagram floating around here somewhere, if you're interested...
CSF is offline   Reply With Quote
Old 04-21-2013, 01:48 PM   #3794
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,584
Black plug pulled out on left...
The black plug with orange seal is for the EPC which has obviously been wisely junked & capped off by the previous owner. I cut that off & sealed the wires up back into the loom.
Pretty sure I also have the other 2 stray connectors there, I would be interested to know what they are for too as I am also having a wiring tidy up & would rather chop off plugs that I will never need than have them hanging there cluttering up the already cramped wiring loom & confusing me when troubleshooting. That 4 pin one under the dash is indeed the tripmaster control - chopped mine off, figured I can solder it back on in the unlikely event of needing it one day - things are much more cramped under the dash of the 640E though.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 04-21-2013, 02:53 PM   #3795
tstick14
tstick14's Avatar
Oddometer: 151
Thanks for the replies about my electrical connectors. The ones up front can be used to wire in heated grips and GPS? I'd like to do that, and if those can be used then that makes it easy.
Straddlin' 640 Adv.
Times are GMT -7.   It's 03:23 PM.
