Old 05-28-2013, 04:05 PM   #3931
Somewhere Far Beyond
The Narrator
Somewhere Far Beyond's Avatar
Oddometer: 214
Originally Posted by meat popsicle View Post
Better setup thread:
http://www.advrider.com/forums/showthread.php?t=79898
Idle may want to be higher than 1500 according to Creeper.
Not sure if Stenhouse Racing still has the replacement idle mixture screws that are finger adjustable, but if so they are useful.
Thanks to both of you. I've been reading Creeper's setup thread and it has been quite enlightening.
I've got an order in to Stenhouse Racing for one via the website. According to that there were a few left. Seems like a worthy investment to me.
I'm excited to get this baby dialed in. Just reeaaally want it to not vibrate all over the shop when I have it fully choked. Craziest thing to watch.
2003 KTM 640 Adventure
Somewhere Far Beyond is offline   Reply With Quote
Old 05-28-2013, 07:53 PM   #3932
bmwktmbill
Traveler
Oddometer: 5,182
Thanks Meat,
and yes, idle mixscrew is beyond useful, absolutely a necessity in my mind.
b
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 05-30-2013 at 10:12 PM
bmwktmbill is offline   Reply With Quote
Old 05-30-2013, 01:17 PM   #3933
The Narrator
Oddometer: 214
Electrical
So I can't slack up my choke cable cause that sucker's already slacked to the max. I've got a BST Idle screw on order from Stenhouse so I'm moving onto other stuff on the bike. Specifically, I'd like to wire in a manual override switch for the cooling fan so I can turn it on at will. I'm not going to add a second cooling fan most likely. Anybody know why exactly there is a capacitor on the bike? To protect the ignition system and CDI from spikes?
Old 05-30-2013, 03:30 PM   #3934
dnrobertson
Big Bike, Slow Rider
Oddometer: 826
Originally Posted by Somewhere Far Beyond View Post
.... Anybody know why exactly there is a capacitor on the bike? To protect the ignition system and CDI from spikes?
The answer may be here:
http://www.advrider.com/forums/showp...&postcount=188
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 05-30-2013, 09:40 PM   #3935
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,237
Nice find dnrobertson!
Somewhere far beyond, you can get a different thermoswitch so the fan turns on at a lower temperature. I bet that's indexed. Second fan was popular and fairly easy too (as long as your rear subframe is aligned).
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 05-30-2013, 10:19 PM   #3936
bmwktmbill
Traveler
Oddometer: 5,182
I believe the '02 and earlier Adventure bikes had the lower temp switch,
pn. 580 35 045 000, 80-85 GRAD '94.
bill
Bill Shockley
Old 05-31-2013, 04:48 AM   #3937
tdreyer
KTiM
tdreyer's Avatar
Oddometer: 504
bill
I have never found where someone confirmed the lower temp fan thermo switch from the earlier models fit the later models. I have looked @ the right radiator p/n' s and they are different from my '04 SXC.
Can anyone confirm the older fan thermo switch is a direct replacement for the one in my SXC?
~Tim
"04625 SXC
'04 625 SMC 76,xxx mi.
'97 CR500 Sold
tdreyer is offline   Reply With Quote
Old 05-31-2013, 05:06 AM   #3938
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,235
I put on radiators from another model RFS when I lost a jousting match with a dead tree, I thought from an RXC but not sure, I do know the temp switch for the fan did not fit. I had to redo the plug so it could adapt to my 03 640 Adv
Cat remember off hand but one was like a 15mm thread and the other a 17mm
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 05-31-2013, 06:46 AM   #3939
wvrocks
wvrocks's Avatar
Oddometer: 616
I've searched the Index but can't seem to find an answer. Is it normal for the tach needle to bounce a lot on a 640 Adv? Everything else vibrates so I wouldn't suprise me. Seems to be worst in 3-4 gear around 4k rpm. Swings about 500 rpm either way.
Never underestimate the power of stupid people in large groups.
wvrocks is offline   Reply With Quote
Old 05-31-2013, 04:44 PM   #3940
Uncle Crumpet
Uncle Crumpet's Avatar
Oddometer: 616
Indicator removal
whats the secret to removing the 640 ADV rear indicators? Am trying to replace mine as their stuffed, undo nut and then what? it seems the stem is either press fit or moulded into the tail piece and doesn't want to budge on either side, I know it will be simple, but it has me stuffed at present, thanks for your help!
there is no mechanical problem so bad, that with a little more fixing, cant be made worse.
Uncle Crumpet is offline   Reply With Quote
Old 05-31-2013, 07:05 PM   #3941
mtbdemon
mtbdemon's Avatar
Oddometer: 998
Gear oil
So I have a bit of a silly question. I bought some"gear oil" at the local shop. It is motorex gear oil 10w/30 synthetic. The back of the bottle says "synthetic manual gearbox oil for motorcycles with seperate engine and gearbox lubrication"
I have to think that this would NOT work in my 620 engine, but could I not use it in my 200 two stroke engine? Thanks
Ken
I am a leaf on the wind, watch me.....ride (I know, it makes no sense)
2007 YZ 250F SOLD
1998 KTM 620 Adventure
2004 KTM 200 EXC
mtbdemon screwed with this post 05-31-2013 at 07:39 PM
mtbdemon is offline   Reply With Quote
Old 05-31-2013, 09:37 PM   #3942
bmwktmbill
Traveler
Oddometer: 5,182
WV,
Had that problem!!
When the tach bounces, crazy as it sounds, your ignition switch, or the connection, is failing.
IMHO.
We can thank Gunnerbuck for that, maybe he will comment.
When I cleaned my ignition switch internally the bouncing stopped.
Follow the tach ground wire on your wiring diagram.
BTW the bouncing drove me crazy.
(Working on your pdf.)
bill
Bill Shockley
Old 05-31-2013, 09:42 PM   #3943
The Narrator
Oddometer: 214
You guys are great. Very helpful, thanks!
As for changing the thermoswitch, I don't think it's a capatible swap. At least without some modifications to make that switch fit. Possible though that a complete right side radiator from an earlier LC4 might be a direct fit to 03 and later bikes, which would save modding the original radiator to make a new switch fit.
Old 06-01-2013, 01:30 AM   #3944
The Misinformant
What road?
The Misinformant's Avatar
Oddometer: 350
You can fit the older cooler operating thermofan switch to the newer Bikes. You just need to find the right kind of plumbing fitting to make the smaller diameter early model switch fit into the larger hole on the later models radiator.
BMW 450X (Rallye Project).
Bandit 1200.
KTM 640 ADV.
RF900R - Gone.
TTR250 - Gone.
CB500 - Gone.
TS185 - Gone and sorely missed.
Z50 - Gone.
The Misinformant is offline   Reply With Quote
Old 06-01-2013, 06:24 AM   #3945
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,148
Ken
You are correct. Transmission only. Perfect for your 2t. Do not put it your engine crank case.
fastdadio is offline   Reply With Quote
Times are GMT -7.   It's 02:12 PM.
