Old 06-18-2013, 12:49 PM   #4021
TexasDirt
Oddometer: 19
Supertrapp Mod..
I have a Supertrapp with a welded plate protecting the Guts inside. this is on an 02 640 enduro. so when something broke loose inside, i had to cut her open with a hole saw right down the middle and remove the spark arrestor and pipe attached to it.
I know there is a mod out there that calls for this exact technique. can anyone explain to this noob how or what adjustments need to be mage at the carbe/air box to get it to stop bogging, backfiring and stalling since I cut her open?
I have toyed with the idle air/fuel mixture screw but that is not helping(could be user error). It seems as though the vaccuum on the exhaust side has increased and we are now pulling too much fuel but that is a guess.
please help!!! this is usually my primary vehicle.
TexasDirt is offline   Reply With Quote
Old 06-18-2013, 01:04 PM   #4022
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,564
Thumb
You most likely need to rejet.
Also why fight with the stock supercrapp. Get yourself an FMF Q4.
The 2006 model will fit perfectly. You will definitely need to rejet with the Q. No need to thank me, the smile on your face will suffice!
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Old 06-18-2013, 02:05 PM   #4023
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,450
Originally Posted by Saronkhye View Post
Hi, I have bought all the gear to the garter spring for the sprague clutch.
I followed instructions to remove stator, I do not have tools to take off flywheel outer nut. I tried 5 th gear brake on with no joy. I have the bolt in the case to lock out the motor but it has a little washer and is not long enough. If I get a longer bolt will this cause an damage to 2002 ktm640 adv. is there any other way of getting nut off. Also I found some small metal shavings near stator, is this normal, I intend on doing main bearing at same time. Any help appreciated.
Cheers
Ron
If you have a 1/2" socket set make yourself a flogging spanner type device out of a couple of short extensions & a t-slider thingy. Tape it all together so it don't fly around the shed. 5th gear plus brake as you tried then give it a good smack with a BFH. Don't do this with your mechanic mate's expensive sockets Left hand thread remember.
Or make a flywheel holding tool. Or buy a compressor & air impact wrench.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 06-18-2013, 02:35 PM   #4024
dolphins13
orange rules
Oddometer: 138
157.5 mj and removal of snorkel made my bike run great. With the exhaust mod you speak of. page 1 will tell you anything about your bike.
dolphins13 is offline   Reply With Quote
Old 06-18-2013, 08:35 PM   #4025
beek-02
blazing a trail
beek-02's Avatar
Oddometer: 113
Cheers
Ron
Dewalt 18v impact driver has worked for me on pretty much everything and you don't have to worry about f'ing up your crank. The connection rod pin is pressed in and the web halfs are not clocked other than the surface tension that can be overcome with massive amounts of torque. Long story short your eccentricity could get tweaked it will be out of center and your bearings will fail prematurely. Jmo, also why it's a good idea to use the tool instead of putting it in gear and taking your chances. I've done this before and it does work but I also had a crank go out in an IT175 shortly after rebuilding it. I was still rather young/inexperienced and until now haven't really thought about that as the possible cause but it probably was.
Good luck
In my experience you can usually get the job done without the proper tools but they are almost always worth what they cost.
Sent from my SCH-I535 using Tapatalk 2
"Opinions are like a$$holes. Everybody's got one and everyone thinks everyone else's stinks."
beek-02 is offline   Reply With Quote
Old 06-18-2013, 11:21 PM   #4026
Jkils
Jkils's Avatar
Oddometer: 29
Does anyone have a good link to the WP Extreme 50mm RSU fork manual? Or a link to the manual for 98/99 640? I'm looking for some torque values, etc.
I'm in the middle of installing new fork seals.
The links I am finding are all dead...
Jkils is offline   Reply With Quote
Old 06-18-2013, 11:30 PM   #4027
bmwktmbill
Traveler
Oddometer: 5,142
Cheers
Ron
Two things.
Air impact, left hand thread so backwards brother.
Second thing, maybe somebody put the nut on with red loctite so heat it up a little with a heat gun or worst case a little propane.
Now it wll come off a little hot.
And no it's not right but it's being done.
I put mine together using the reverse and a quick rattle with 90 psi air(on and off).
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 06-18-2013 at 11:35 PM
bmwktmbill is offline   Reply With Quote
Old 06-18-2013, 11:40 PM   #4028
Jkils
Jkils's Avatar
Oddometer: 29
Along the same lines. It seems the circlip holding in the seals is no longer being sold. Has anyone replaced one recently, or know where to get one?
Old 06-19-2013, 12:27 AM   #4029
Geekventure
Geekventure's Avatar
Oddometer: 117
Question Stalling after fast left turn...
Hey all
My 2002 started stalling yesterday after I replaced my clutch cable.
For some reason on my commute home the bike seems to not be getting any fuel when I come out of a really long and fast (75-80 mph) left handed exit ramp. The first time it happened I thought it might have something to do with a shifting choke cable or even an electrical disconnect...but then it happened again in the same place going the same speed the very next day.
After puttering a little bit further...I can tell it's trying to get gas back by the way it sputters similar to when I'm running out of gas. I try to maintain a constant speed but it eventually dies. Dangerously sitting on the left side of the highway for 45 seconds and it starts right back up again.
To eliminate the empty tank theory, I filled it up this morning so I would have only put 50 miles on the 4.7 gal tank. I'm getting 45-48 mpg so that means ~ 1 gallon was gone at this point. That leaves 3.7 gallons inside the tank today when it happened again.
Tomorrow, I'm going to try the same sweeping ramp at the same speed with a completely full tank to see what happens.
Some other things I repaired:
  • I had to re-glue the breather hose onto the lockable gas cap because (plugged hole...possible vapor lock?)
  • I ran a second clutch cable next to the working one for a quick repair next time it snaps.
The petcock is on the left hand side of the bike (on position) so the only thing I can think of is that all the gas is sloshing to the right side (from the G-forces) and the petcock is sucking air?
Has this happened to anyone before?
"Not all those who wander are lost." - J. R. R. Tolkien
Geekventure is offline   Reply With Quote
Old 06-19-2013, 05:20 AM   #4030
FreeGranite
Nubile dirtrider
Oddometer: 118
This should do it. The first link is a good oneon the WP 5060 (50mm extremes). Pay no attention to the blue and yellow.
FreeGranite is offline   Reply With Quote
Old 06-19-2013, 06:01 AM   #4031
Kawidad
Kawidad's Avatar
Oddometer: 4,844
Originally Posted by Geekventure View Post
Hey all
Are you sure it's open and a little glue didn't glop over and into the breather, and it's now clogged and/or restricted?
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 06-19-2013, 08:48 AM   #4032
Jkils
Jkils's Avatar
Oddometer: 29
Old 06-19-2013, 11:06 AM   #4033
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,203
I went through a period where my '00 was stalling frequently because it was starving for fuel. In my case it was generally after work but it would happen anytime the bike was parked in the heat of the day and I would get on as the day was cooling. It got worse with less fuel in the tank but it was way above empty. When I let it sit or checked the fuel level it would fire right up again.
The problem was the gas cap wasn't venting properly. Air in the tank would expand during the day and vent out but as things cooled the cap prevented air from venting back in creating a vacuum. The cap is easy to service. To take it apart just turn it upside down, press the top down a little and remove the small metal rod. There are two small check valves with thin rubber flaps. Once I cleaned these the problem went away for good.
Sparrowhawk is offline   Reply With Quote
Old 06-19-2013, 11:30 AM   #4034
Casejeep
Casejeep's Avatar
Oddometer: 739
Hello,
Just bought an 06 with 3800miles, and the battery seems to die over night. so im thinking i need a new one? I still have power but not enough to start the bike.
I can get a good deal on Ballistic batteries, but have read some stuff that the battery can mess with something and the bike wont like it.
Any help would be cool. Thanks
MY F800 GS Build
Casejeep is offline   Reply With Quote
Old 06-19-2013, 06:10 PM   #4035
CuStOm
Oddometer: 13
This brake pedal is killing me! Does anyone know of a larger tip? Do any later model linkages fit?
LC4-E setup for an adventure. Best farkle = kickstand!
CuStOm is offline   Reply With Quote
Times are GMT -7.   It's 10:58 PM.
