Old 06-29-2013, 04:41 PM   #4051
Droptarotter
Oddometer: 1,222
You are not missing anything............the axle should slide out.........I would try more penetrating oil and keep moving the axle back and forth, left to right.
Good luck.
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 06-29-2013, 05:16 PM   #4052
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 13,693
Keep the spacer out,thread the nut back on and hit with a rubber hammer.
It will come out.
Reapply with some good water proof grease.
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 06-29-2013, 06:38 PM   #4053
cjm1219
cjm1219's Avatar
Oddometer: 107
It will come out.
That's how I got it as far out as it is. Now it is in the wheel but doesn't want to go further. Maybe I can find something to fit in there to pound it out more.
I tried the freeze out stuff to try to get it to contract.
I will keep at it. Just wanted to make sure I wasn't missing something.
I am glad I am trying this at home cuz I would never be able to do this on the trail.
I clean and grease it up for reassembly. Any chance it might be bent and that is why it is giving me such a hard time?
2000 KTM 640 LC4e
1998 Triumph T509 Speed Triple
cjm1219 is offline   Reply With Quote
Old 06-29-2013, 06:51 PM   #4054
enduro0125
enduro0125's Avatar
Oddometer: 13,693
Just make sure you use a brass punch if you do.
It's possible but not likely that its bent.
I've never seen a rear axle bend.
AMA 487807A
Old 06-29-2013, 09:05 PM   #4055
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,178
Tap it back in, lube it, tap it out again, lube it, tap it back in, etc. also twisting it around can help loosen it up too.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is online now   Reply With Quote
Old 06-29-2013, 10:55 PM   #4056
bmwktmbill
Traveler
Oddometer: 5,048
Yes this and you might heat the axle and let it cool and have at it again.
Propane or a heat gun.
You could heat the hub, I know I would. Heat will help the oil work/penetrate and weaken corrosion and crud. Stay away from the sprocket carrier and the brake caliper.
For a punch your tool kit has a steel rod but as as already suggested a brass punch is best.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 06-29-2013, 10:57 PM   #4057
Queen of Spades
tall drink of water
Queen of Spades's Avatar
Oddometer: 846
bill
I picked up my brass punch from a local Ace Hardware store. It wasn't more than a few dollars.
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades is offline   Reply With Quote
Old 06-29-2013, 11:04 PM   #4058
bmwktmbill
Traveler
Oddometer: 5,048
For sure. An old guy like me has a drawer full of punches and 10 laying on the bench plus 10 or 20 odd wood pieces/punches and chunks for setting seals and ...you know.
Must have a half dozen old axles and machine bolts.
Actually it's out of control.
b
Bill Shockley
Old 06-30-2013, 06:45 AM   #4059
Lortdadu
Joe Cool
Lortdadu's Avatar
Oddometer: 214
if you have some good lock pliers, you can grab on to the axle and twist it around a bit to help as well. If you have the brass punch set you can pull on the axle while you hit on the other end with a hammer.
Make sure you clean the areas where the axle is in touch and lube/grease it properly before placing it back.
I may not have gone where I intended to go, but I think I have ended up where I needed to be. - Douglas Adams
KTM LC4 400 2002 - Military version
Lortdadu is offline   Reply With Quote
Old 06-30-2013, 08:38 AM   #4060
cjm1219
cjm1219's Avatar
Oddometer: 107
Thanks for all the tips.
It came out pretty easy this morning. Sitting overnight with all the penetrating oil seemed to do the trick.
Not really any crud in it. I think it was more just lack of grease. I will use plenty in reassembly. I would hate to have to go through that effort if I was trying to change a tube in the middle of no where.
2000 KTM 640 LC4e
Old 06-30-2013, 08:43 AM   #4061
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,407
A light sanding with fine grit paper to get rid of any rust and crud before you grease and reinstall would be a good idea too.
2005 KTM 950 Adventure
Roaming Rally 2011RR2012 RR2013 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 06-30-2013, 10:35 AM   #4062
Queen of Spades
tall drink of water
Oddometer: 846
Talking
Changing oil today and realized the spare filters I have are actually for my tractor, not the pumpkin.
Any chance I'll find an equivalent to the KN-156 at local auto store?
Old 06-30-2013, 11:07 AM   #4063
Queen of Spades
tall drink of water
Oddometer: 846
The asylum to the rescue. Autozone has a puralator ML16817 in stock nearby.
Old 07-02-2013, 03:57 PM   #4064
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,368
Originally Posted by laramie LC4 View Post
hey guys, i could use your help. this is a shameless request for your vote.
trying to win an intake system for my 990 and need your vote. please go to this THREAD and make a post for a vote with my member name.
thanks,
laramie
Thanks to those of you who have voted. I'm in the lead with 1 day to go. If you havnt had a chance to vote yet, I'd sure appreciate it.
Thanks,
Laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 07-02-2013, 09:13 PM   #4065
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,178
Be careful tugging on that aluminum block or even hitting it, the same piece on my 950 cracked in half and is not sold separately. Your axle is probably rusted on both sides of one of the bearings. Place something heavy like a cloth wrapped 10lb sledge hammer (aka, the BFH) against the swingarm near the aluminum block so all the impact goes into moving the axle and not bowing the arms apart when the whole wheel moves.
Good luck
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Times are GMT -7.   It's 11:51 PM.
