Old 07-21-2013, 08:47 PM   #4171
bmwktmbill
Traveler
Oddometer: 5,194
Originally Posted by dolphins13 View Post
So my bike has no spark? I replaced plug, and the wire looks good. Ignition coil next? Is it common for these to quit working? I never had 1 go bad before.
Dolf,
I'd start a separate thread saying what you have tried and a little history.
Is the ground tight?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 07-22-2013, 08:49 PM   #4172
Gerst
Gerst's Avatar
Oddometer: 253
Thanks for all the tips for removing the swingarm bolt. I got it out Saturday. It took a fairly hard whack with the 3lb hammer and brass drift to move it. I had to drive it the whole way out. It was the right side Bushing Sleeve. I'm not sure what happened but there was some corrosion on the sleeve and minor pitting on the bolt. Black, not rust colored and everything else was in good shape. I replaced everything except the bolt cause I had the parts on the shelf. Anyway she's ready to ride!
Thanks,
Gerst
Gerst is offline   Reply With Quote
Old 07-23-2013, 05:16 PM   #4173
cjm1219
cjm1219's Avatar
Oddometer: 107
Can my bike use a clutch cable from a different model or make of bike?
I need to try to find a local source for a clutch cable for my 2000 enduro as I just noticed the casing is splitting on the clutch end. I have a weekend full of riding planned and would like to get this swapped out before.
Anyone know of a different cable that will work?
No local KTM dealer in town but all the other manufactures. Hell I even have an Aprillia dealer withing walking distance of my house.
I have tried some searching but in kind of a time crunch. Anyone know?
2000 KTM 640 LC4e
1998 Triumph T509 Speed Triple
cjm1219 is offline   Reply With Quote
Old 07-23-2013, 06:52 PM   #4174
WVhillbilly
WVhillbilly's Avatar
Oddometer: 10,860
http://www.ktmworld.com/
http://www.munnracing.com/
Call tomorrow, eat overnight shipping.
I wouldn't think anything else would fit it well enough to be reliable.
I keep a spare cable zip tied to my cable.
Easy fix then if it breaks.
WVhillbilly is offline   Reply With Quote
Old 07-23-2013, 07:31 PM   #4175
wvrocks
wvrocks's Avatar
Oddometer: 615
KTM LC4 (640) Thread Index
Motion Pro makes a cable that fits my 2000 640 Adv. Should fit yours too. It's heavier all the way around.
Get 2 and run them parallel for a backup
Sent from my iPhone using Tapatalk 2
Never underestimate the power of stupid people in large groups.
wvrocks is offline   Reply With Quote
Old 07-23-2013, 07:34 PM   #4176
Queen of Spades
tall drink of water
Queen of Spades's Avatar
Oddometer: 917
Are the Adventure cables (clutch & throttle) the same length as the Enduro, or longer/shorter? I have bar risers and would like to get a taller bar.. I'm restricted by the cable length right now.
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades is offline   Reply With Quote
Old 07-23-2013, 07:36 PM   #4177
wvrocks
wvrocks's Avatar
Oddometer: 615
The motion pro seems longer than the stock one that was on my bike. You could check stock length on the parts fiche at ktmworld.com
Old 07-23-2013, 07:38 PM   #4178
WVhillbilly
Oddometer: 10,860
Clutch cable at least is the same.
1115 mm.
Figure the throttle is too.
KTM World has microfiche, I get part numbers there quicker than looking in my book
Old 07-23-2013, 07:44 PM   #4179
Queen of Spades
tall drink of water
Oddometer: 917
1115 mm.
ADV and E model are both 1115mm according to the fiche.
I ran across a site that sold cable components separately (to build custom length cables), but I forgot to bookmark it.
Old 07-24-2013, 05:15 AM   #4180
wvrocks
wvrocks's Avatar
Oddometer: 615
Motion Pro says part #10-0082 is the same length as factory. It fits my bike with 3" rox risers and higher bars just fine. It seems like it still has some extra length over the factory one. It does have an inline adjuster built in so you have some extra adjustment room. I made my initial adjustments mostly in the housing instead of with the lever adjuster since its kind of floppy to begin with.
Speaking of that, if you haven't done this mod yet, check it out.
http://www.advrider.com/forums/showthread.php?t=529980
Old 07-24-2013, 05:32 AM   #4181
cjm1219
cjm1219's Avatar
Oddometer: 107
I was hoping someone knew if, say a cable from a yamaha blah blah blah or something would work on my bike.
I will call around today to see if I can find something local.
Thanks for any info.
2000 KTM 640 LC4e
Old 07-24-2013, 07:03 AM   #4182
Kawidad
Kawidad's Avatar
Oddometer: 4,901
The "E" model throttle cables are not the same as the Adventure. The E uses a different switch gear housing and specific to that model. AFAIK, there are no aftermarket throttle cables made for the E if you have that weird housing. However, I have to put in a caveat and that is the E model uses several different housings during it's run and some did use the Adv housing, so you might have gotten lucky, I didn't.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 07-24-2013, 07:17 AM   #4183
Queen of Spades
tall drink of water
Oddometer: 917
What model did you have? I replaced the clutch cable a couple years ago and got by with a good cleaning and lube of the existing throttle cables.
I'm thinking that having some cable assembly supplies (sheathing, wire rope, crimps, balls, ect) may be the only solution for longer cables. From what I'm reading it's not a simple "plug & play" process.
Resouces:
http://www.flanderscables.com/
http://www.venhillusa.com/Universal-Cable-Kits-c742/
http://bbs.homeshopmachinist.net/arc...p/t-37622.html
http://www.xs650.com/forum/showthread.php?t=83
http://www.xs650.com/forum/showthrea...=1026#post1026
Old 07-24-2013, 06:05 PM   #4184
Kawidad
Kawidad's Avatar
Oddometer: 4,901
Resouces:
Mine is a 2001 640E.
Old 07-24-2013, 08:26 PM   #4185
tileman
tileman's Avatar
Oddometer: 882
gas tank replacement?
Hi all.
Has anyone here changed the tank over to one from a later model exc similar to this one,
http://www.safaritanks.com.au/home/9...ypage.tpl.html
I have spoken to wayne at safari tanks and he mentioned a issue with the CV carb interfering with the bottom of the tank. Understanding of course that the standard seat will not fit with the other tank. The mount points as in the follow pictures either side of the frame look similar.
http://strong-clan.smugmug.com/photos/98957871-M.jpg
http://bend27.smugmug.com/Motorcycle...5233&k=spjsQ8J
Obviously the mount points on the rad would be different or not even used,
http://strong-clan.smugmug.com/photos/98957874-M.jpg
The "why"? (because I'd like too)
Any help or ideas are appreciated.
If ignorance is bliss, why aren´t more people happy?????
tileman is offline   Reply With Quote
Times are GMT -7.   It's 02:12 PM.
