Old 07-25-2013, 04:41 AM   #4186
Queen of Spades
tall drink of water
Queen of Spades's Avatar
Oddometer: 1,003
Another (kinda pricey) option for longer-than-stock throttle, clutch and choke cables:
http://www.motionpro.com/motorcycle/custom/
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades is offline   Reply With Quote
Old 07-25-2013, 01:24 PM   #4187
muttley92
Oddometer: 66
Ok guys, I have searched the thread index and everywhere else I can think of, but I just can't seem to find any info on Jetting an FCR 41 MX for a straight through pipe and a cone filter (I have no space for an airbox) The engine runs alright but doesn't feel quite right in the higher gears, WILL NOT start when hot and sometimes cuts out if you blip the throttle form idle. Any suggestions? Many thanks.
muttley92 is offline   Reply With Quote
Old 07-25-2013, 03:19 PM   #4188
WVhillbilly
WVhillbilly's Avatar
Oddometer: 11,361
What does your plug look like?
White, black, brown?
WVhillbilly is offline   Reply With Quote
Old 07-25-2013, 04:22 PM   #4189
DaddyBigDaddy
AKA -Evel Kneilson
DaddyBigDaddy's Avatar
Location: Liberal ShitHole, San Fran-sissyco, Kalee-Fornee-a
Oddometer: 303
KTM 620 carb and cable swap
I need to adapt my 99 620A to the FCR 41 carb
I have a single throttle cable now but need to convert to a dual push/pull cable but want to keep my original throttle receiver w the switches, it's a one piece unit
The throttle receiver has a blocked off 2nd cable receptacle
Can thie be drilled out to accept the second cable? I'm putting on a throttle tamer so no issue attaching both cables... Anyone done this?
I have bar risers so will need 2" longer cables too
Advice, links or parts suggestions would be appreciated
Thanks! DaddyBigDaddy. Ken@AspenRacing.Com
DaddyBigDaddy
1998 KTM 620 Adventure
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
DaddyBigDaddy is offline   Reply With Quote
Old 07-25-2013, 05:11 PM   #4190
dnrobertson
Big Bike, Slow Rider
Oddometer: 848
I bought some Venhill cables from Munn that solved the length problem for my 39mm FCR. I cannot find the order at the moment so I don't know part numbers.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 07-25-2013, 07:06 PM   #4191
wvrocks
wvrocks's Avatar
Oddometer: 627
Ken, check your email. I may have something that will work for you.
Sent from my iPhone using Tapatalk 2
Never underestimate the power of stupid people in large groups.
wvrocks is offline   Reply With Quote
Old 07-25-2013, 07:34 PM   #4192
overlandr
Dystopist
Oddometer: 5,926
Originally Posted by muttley92 View Post
Ok guys, I have searched the thread index and everywhere else I can think of, but I just can't seem to find any info on Jetting an FCR 41 MX ...
Enter the following terms into a google search term window:
ktm 640 FCR41mx jetting +site:advrider.com
and/or try ktmtalk.com
overlandr is offline   Reply With Quote
Old 07-25-2013, 08:50 PM   #4193
mcguyver
mcguyver's Avatar
Oddometer: 1,295
Looking for some help here guys.
2006 640 adv. 600000
Kim
Bike starts fine, but if I twist the throttle to 1/4 it stalls.
Pulled the cover off top of carb, thinking it may have been an issue with the needle but all looks good.
Drained carb. Still No good.
Where should I look next? Could it be a fuel pump issue? How do i check?
All info appreciated. I am falling out of love with bike very quickly.
mcguyver is offline   Reply With Quote
Old 07-25-2013, 09:00 PM   #4194
lost1
Oddometer: 57
450 smr wheels on my 02 adventure and vice versa
Anyone know if the ktm 450 17 inch supermoto wheels will fit on my 02 adventure and vice versa. I know a guy who wants to make swap.
Thanks in advance
lost1 is offline   Reply With Quote
Old 07-25-2013, 09:38 PM   #4195
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,334
Kim
600,000 KM ! the bike is worn out....
You must mean 60,000... At that mileage the carb slide, guide and needle jet will be worn out unless they have already been replaced...
With the stalling issue it would be a good idea to make sure the chke/enricher piston is fully closing and not stuck partially on... Also a good idea to pull the carb and give it a good cleaning... Pay attention to the passage ways in the pilot circuit and look for blockages...
gunnerbuck is offline   Reply With Quote
Old 07-25-2013, 10:56 PM   #4196
mcguyver
mcguyver's Avatar
Oddometer: 1,295
Tkanks gunnabuck. What do you mean worn out at 600000 Kay's surely not
Of course I meant 60000k. Carb slide needle jet etc are all reasonably new. Pulled carb and blew out. All looked pretty good.
I connect the throttle cables while the carb was off and noticed that the slide does move when I twist the throttle. I know it relies on vacuum, but shouldn't it move up and down when I turn the throttle?
Old 07-25-2013, 11:26 PM   #4197
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,334
The slide has no mechanical connection to the throttle linkage and works solely off engine vaccuum ...
When you blew out the carb did you remove the pilot jet and pilot fuel screw and pass air through them? Did you make sure that air passes through from the air jets in the airbox end of the carb bell?
Does your jet needle have the correct assembly, spring to top plastic washer, to clip {3rd notch}, to bottom plastic washer, to steel washer and then through the slide?
The fuel pump is usually trouble free but at 60,000 km your diaphragms within the pump could be getting tired... Try running a fuel line direct to the carb, bypassing the pump and see if the same thing happens...
Also check the little filter that sits inside the carb intake fuel hose spigot to see if it is clogged...
Old 07-26-2013, 12:47 AM   #4198
mcguyver
mcguyver's Avatar
Oddometer: 1,295
Thanks Gunner
Did all most of that put it all back together, turned fuel on Andes pouring out the drain hose at the bottom.
I have obviously put the something I incorrectly. Will pull it all apart again.
Wouldn't be so bad if the carb wasn't such a pain in the ass to get out and back in again.
Old 07-26-2013, 01:14 AM   #4199
muttley92
Oddometer: 66
The plug is black, it was brand new and the motor has run for about an hour I'd say. Think its probably too rich at the bottom. Not sure about top end yet, will sort that later. If I can fix the hot start I'll put it on the road.
Old 07-26-2013, 02:14 AM   #4200
WVhillbilly
Oddometer: 11,361
I bet the seat hasn't softened up yet.
Rich at the bottom, but a dead spot.
Without running it more, it will be hard to judge.
When you have hot start issues does it smell like it's flooded?
Times are GMT -7.   It's 04:48 PM.
