Old 07-26-2013, 05:54 AM   #4201
muttley92
Oddometer: 66
Originally Posted by WVhillbilly View Post
I bet the seat hasn't softened up yet.
Rich at the bottom, but a dead spot.
Without running it more, it will be hard to judge.
When you have hot start issues does it smell like it's flooded?
It doesn't smell rich, no. I leaned the air screw off half a turn (now 2 turns out) and for reference the jet sizes are 168, 85 and 45 respectively. It is now much easier to start when hot.
I am however worries about cooling. I am running koso RX2N clocks that came with their own temperature sensor. So ot should be correctly calibrated. But it is only 20mm long opposed to the much longer stock one. The temp on the clocks reads 130C before the rad even starts to get warm! I'm wondering if there may be a vapour pocket under the sensor that is throwing off the reading or if the conventional way I've plumbed in the rad is incorrect.
If I'm not mistaken the stock pipes flow to the top of the radiator? Where I have mine flowing into the bottom. Could this cause a significant issue?
Also I have. 1.8 bar cap rather than 1.4.
Many thanks.
muttley92 is offline   Reply With Quote
Old 07-26-2013, 09:50 AM   #4202
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,179
Originally Posted by mcguyver View Post
Thanks Gunner
Did all most of that put it all back together, turned fuel on Andes pouring out the drain hose at the bottom.
I have obviously put the something I incorrectly. Will pull it all apart again.
Wouldn't be so bad if the carb wasn't such a pain in the ass to get out and back in again.
For sure a float issue, maybe your float needle tip is shot or the float seat O-ring is not working... Check your float height and make sure it is paralell or a little higher than parallel...
I have had lots of practice so it only takes me about 15 minutes to pull the fairing, tank and have the carb in my hand... It does wiggle up between the frame rails, the only things to remove before are the choke cable, TPS + the vent and vacuum hoses... I loosen the front clamp and take the rear one completely off to allow the rubber boot to collapse clear of the airboot bell when you pull the carb back and upward...
640 A x 2
BC RIDING 2014
gunnerbuck is offline   Reply With Quote
Old 07-26-2013, 04:33 PM   #4203
Tonicu
Oddometer: 168
Neutral light
Continuing with the problem and possible culprit, I wiggled all the cables under the dash unfortunately without success.
To my surprise, the engine didn't start, just made the typical relais sound as when the battery is almost dead. But it wasn't.
I managed to get it started, and while out for a singletrack quick blast, the engine stalled several times while in 1st gear with almost no throttle. And there ... I saw the light.
The neutral one, I mean.
It lit for about a second, then it went off again.
I happened to use the engine cut switch and saw a hint of light in the neutral led every time I pushed the button. I only noticed it because it was pitch black.
So ... I think Clint was right and I owe him a beer. Anytime, antipodian.
Next step ... dismantling the engine cut-off switch, unless you have a better idea.
Tonicu is offline   Reply With Quote
Old 07-27-2013, 05:58 AM   #4204
Queen of Spades
tall drink of water
Queen of Spades's Avatar
Oddometer: 854
How much should I pay for a used Akrapovic full system in average condition? There are a few small dents on the header.. not clean.
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades is offline   Reply With Quote
Old 07-28-2013, 03:27 AM   #4205
Tonicu
Oddometer: 168
Question Neutral light ... and more
Further investigation shows a bit more trouble than expected. I didn't find the cause of the unlit neutral light, but I did find this
Brushes were changed only 5K kms. ago, so I don't quite understand this kind of wear.
This explains the relais "click" sound when the brushes got stuck at that damaged copper plate. So I ordered a new starter motor.
Problem sorted out, but ... there were debries here and there
And these bits ... maybe parts of the countershaft bearing with some play I posted a couple of months ago?
The oil plugs looked like this when the oil was changed 500 km. ago.
Apart from that neutral light issue, the bike runs fine, full of performance -and enjoyment - and doesn't burn more oil than say half a liter in the 4 or 5000Kms oil services.
Could this be connected with the great difficulty of starting the bike with the kickstarter, which watching the state of the starter motor probably means it's taking more work than it's supposed to, therefore making me think ... of the sprague clutch. But it should make weird noises, and apart from a rattle sound that disappears as soon as I press the clutch lever, the engine sounds healthy and runs fine. Maybe a bit of an increase on fuel consumption, but I'll put that to the chain&sprockets wearing out.
So you have all info, I replaced an inlet rocker roller bearing ( and every other bearing under the rocker cover for my peace of mind ) 15000 kms ago, and have found some debries on the plugs, but I'd say all that - or most of it - should have been flushed after the first oil service.
Then ... where would you start from?
Tonicu screwed with this post 07-29-2013 at 06:20 AM
Old 07-29-2013, 06:15 PM   #4206
mcguyver
mcguyver's Avatar
Oddometer: 1,269
Thanks Gunnabuck. I am losing patience with this thing. You wouldnt like to come for a nice holiday to Australia would you? You sort my bike out and I will give you a bike to ride around.
mcguyver is offline   Reply With Quote
Old 07-29-2013, 10:28 PM   #4207
Queen of Spades
tall drink of water
Oddometer: 854
Did Dirt Rider, Dirt Bike or whoever eles ever test the LC4 Enduro or include it in a dual sport shootout?
Old 07-30-2013, 03:31 AM   #4208
WVhillbilly
WVhillbilly's Avatar
Oddometer: 10,163
Many thanks.
You want to get your coolant pipes routed correctly. You could have an air pocket, or are just not getting a correct reading.
WVhillbilly is offline   Reply With Quote
Old 07-30-2013, 06:06 PM   #4209
HydroDog
Oddometer: 132
CycleWorld had a quick test by Jimmy Lewis back in Dec. 99. He liked the bike and thought the stock suspension was good enough to race Barstow to Vegas.
08 Buell Ulysses
07 GasGas 300
02 MZ Skorpion Traveller
99 KTM 640e
HydroDog is offline   Reply With Quote
Old 07-30-2013, 06:22 PM   #4210
Queen of Spades
tall drink of water
Oddometer: 854
That would be my model too.. thanks... off to fleabay.
Old 07-30-2013, 06:41 PM   #4211
theGrinch
SNF Dream Riders
theGrinch's Avatar
Oddometer: 2,048
Question
Put a new earth-x battery in the LC4 and it was taking a minute for the lights to come on (dash and running lights) before it would start. Today I go to start and no light no start. checked fuses and none blown been looking for a short but can't find one.
Any ideas?
this is starting to dive me nuts.
Originally Posted by pcvance View Post
Who's the clueless noob?
theGrinch is offline   Reply With Quote
Old 07-30-2013, 10:55 PM   #4212
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
Any ideas?
Delayed response to power on? Maybe Luke could help you with that kind of nonsense.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 07-30-2013, 11:06 PM   #4213
bmwktmbill
Traveler
Oddometer: 5,102
Any ideas?
What's the battery voltage?
Are the connections tight?
Do the other functions like horn and lights still work?
b
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 07-31-2013, 10:23 AM   #4214
theGrinch
SNF Dream Riders
theGrinch's Avatar
Oddometer: 2,048
Cool2
b
Found it, it was the wire that comes from the main fuse off the battery that joins to the voltage regulator and continues on to power the ignition. Had fixed it in the passed but wires are small and heat had caused them to melt again. My guess is they could not take the power from the new battery, plus the bike has been sitting for a year. All is well now, I hope.
Old 07-31-2013, 09:20 PM   #4215
bmwktmbill
Traveler
Oddometer: 5,102
Man, I am happy for you!!!
Easy to imagine the worst.
bill
Bill Shockley
Times are GMT -7.   It's 06:12 PM.
