Old 01-07-2009, 06:18 PM   #706
StinkyHinky
Oddometer: 4
SXC wheel bearings
Aw right now, I`ve been looking through this thread and need some advice on wheel bearings for my `03 SXC. I figure once I remove the bearings I`ll be able to find replacement bearings locally. What about the spacers? Is there a better solution than ordering the OE spacers from Munn etc.? What do you all recommend?
StinkyHinky is offline   Reply With Quote
Old 01-07-2009, 11:53 PM   #707
chevaliernoir
Le Chevalier Noir
chevaliernoir's Avatar
Oddometer: 101
When I was preparing my trip in Mongolia, I asked to my KTM dealer what are the spare parts he would recomande me to take.
His answer had no hesitation at all : wheel bearing, and only wheel bearing.
His explanation is that the size is not standard al all and it's almost impossible to find them out of KTM dealers...
Le Chevalier Noir
One thing is sure : Nothing will happen as planned
chevaliernoir is offline   Reply With Quote
Old 01-08-2009, 06:50 AM   #708
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Colin stocks bearings at Stenhouse Racing...
http://stenhouseracing.com/shop/inde...fbac561dc395f6
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 01-08-2009, 01:47 PM   #709
StinkyHinky
Oddometer: 4
Okay, I`ve been checking out the Stenhouse bearings and thats likely what I`m going to go with. Any advice on the seals and bushings? My friends that have enduros get bearing "kits" from Pivot Works but I wasn`t sure what would work as they don`t list any LC4 kits, just 525 and 530. My bushings have a nice groove worn in them so I would like to do it all at once. This bike only has 3,000 miles on it but its previous owner obviously didn`t take good care of it, I`ve already had the cases split because the kick start gears had broken off little by little sending tiny pieces throughout the motor. I think it just got ridden and not maintained because he had another primary bike. I`ve done the motor, the forks and the drivetrain so after these wheel bearings it will be damn near new.
Old 01-15-2009, 12:31 PM   #710
makazica
makazica's Avatar
Oddometer: 750
Foot controls
What would happen if I drop the shift lever for a tooth or two on the shaft?
Also, did anybody modify the rear brake lever in a way to make it longer and lower?
My problem is that I have limited ankle movement on both feet because of sports injuries.
When riding, after some time, it takes a real effort to pull my foot and toes upwards to shift a gear up or to hit the rear brake...the brake mod seems easy to do, but what happens if I drop the shift lever.
Would the free play to the first gear get smaller?
M.
makazica is offline   Reply With Quote
Old 01-15-2009, 01:09 PM   #711
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,975
M.
I see no problem moving it down. The splines run full round on the shaft. The only issue I could see is if you moved the shifter up and it interfered with the case, hindering an up-shift.
Originally Posted by NWGS
This post has zero to do with civility and more to do with stupidity.
NICO is offline   Reply With Quote
Old 01-15-2009, 01:18 PM   #712
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Sommer (I think, or maybe Touratech) used to make a new tip for the brake pedal that made it stick out more (i.e. wider), but I think those dried up. The post 2004 LC4's had the different "folding tip" style pedal end. Nothing new on that style either that I know of.
Chris
1943 BSA M20WD
Old 01-15-2009, 03:11 PM   #713
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,244
Where's the thread on...
field aluminum repairs?
I think folks might be interested in this:
http://www.youtube.com/watch?v=BIk-Vlb5KzM
better propane torch and a stick of AL and you are good to go???
meat popsicle is offline   Reply With Quote
Old 01-16-2009, 02:46 PM   #714
makazica
makazica's Avatar
Oddometer: 750
So, for the shift lever you think if I move it for a spline or two, the space towards the first gear is not going to be insufficient.....I'll try....
About the rear brake lever...I was thinking about just welding a piece of metal on the pedal end so I could move it forward and screw it in with two bolts...
Old 01-21-2009, 02:35 AM   #715
makazica
makazica's Avatar
Oddometer: 750
Wasn't able to slip the shift lever to make it lower, the peg holder extension (towards the frame) gets in the way and disables shifting into first gear....just so you know...
About the rear brake lever, I decided to weld a piece of metal onto the pad, that is going to enable me to push it forward and add a second bolt to fix it in place...
Old 01-22-2009, 01:45 PM   #716
meat popsicle OP
Ignostic
Oddometer: 14,244
minor update
I went through 15 pages of subscriptions (since last update) to look for "How-Tos" that should be in the index - and there were two of 'em. When I get a chance I will be going thru those 15 pages for other threads to index and spraying them about the three parts.
Thank you for your patience.
Old 01-22-2009, 01:56 PM   #717
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,533
meat-you're the one with the patience
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 01-26-2009, 03:06 PM   #718
bikepikespeak.com
bikepikespeak.com's Avatar
Oddometer: 598
tank protection
What happened to the links w/ those fancy carbon tank protectors? I'd like to get me a pair!
bikepikespeak.com is offline   Reply With Quote
Old 01-26-2009, 03:42 PM   #719
meat popsicle OP
Ignostic
Oddometer: 14,244
When on the first page of this thread, hit the Ctrl and F keys simultaineously. This will call up your browser's page search function. enter "carbon" and you will go to the section that has the CF tank protection threads.
Old 01-26-2009, 04:03 PM   #720
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,533
I just got a pair from Chris before xmas his email is: chrisbarnes1@yahoo.com
I haven't mounted them up yet but they are super clean and sexy! Can't wait to see them all done up.
Chris was really nice to deal with too. +1
Beerthief
Times are GMT -7.   It's 05:35 PM.
