Old 06-14-2009, 09:37 PM   #826
Mike In Spokane
Mike In Spokane's Avatar
Oddometer: 15
My 1995 KTM 400
Bought this new. Replaced plastic with some interesting Carbon Fiber looking stuff that came to the dealer without being ordered. Stickers said 6 days winner on fender. I replaced front fender with a newer model to save the original. But shrouds and etc are still on bike. Anybody seen this stuff before??
http://i676.photobucket.com/albums/v...02JPG111111.jpg
Mike In Spokane screwed with this post 06-14-2009 at 09:42 PM
Mike In Spokane is offline   Reply With Quote
Old 06-23-2009, 03:56 AM   #827
hardhat
Oddometer: 24
Counter Balancer on 625sxc 03
I love my 625sxc! But the vibrations hurt my hands! (I AM NOT WINING!)
In searching the info on ADV, there seems to be conflicting info on counter balancers.
Anybody know - for sure- does the 625sxc have a counter balancer?
If not, is it feasible to add one? If yes, can anything be done to increase its effect?
(I've done the jetting, bar foam, etc. It helped, but for longer rides, the vibes make my hands numb.) THis doesn't happen on the klr650, 690, beemer, etc. (My other ride is a 950Adv.)
I'd appreciate any thoughts. Unless i want to spend $10K for a 690 (and get a small tank) I don't see a better bike out there for what i want to do.
Thanks... and... be gentle.
Tim in NJ
In the stable: KTM 530, KTM 625sxc Dual sported, KTM 950, BMW R1100RS
ggggone: KLR 650, BMW R1100R, Honda 550/4 (wayggggone)
hardhat is offline   Reply With Quote
Old 06-23-2009, 06:25 AM   #828
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,235
hardhat, I think the # of counterbalancers varies by year - and that info may be in the model year differences thread. All the more recent LC4s have at least one, past 2000, and I thought the high-flow version (2003-) have two, but rest assured they have at least one. You should find some smoothing by getting the engine setup/tuned properly - did you go through creeper's setup instructions?
Mike in spokane, I've never seen a CF tank on an LC4; not even the Rallye, Factory Supermoto, or Baja racing versions. That is truly unique.
meat popsicle is offline   Reply With Quote
Old 06-23-2009, 06:52 AM   #829
rjf
SBS's #1 fan in January
rjf's Avatar
Location: Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
Oddometer: 4,376
Mmmm, carbon bodywork
Central Coast ADVenture bike training courses and 1 on 1 lessons - For details Click HERE
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadslide, thoroughly used up, totally worn out and loudly proclaiming- WOW-WHAT A RIDE!
rjf is offline   Reply With Quote
Old 06-23-2009, 05:41 PM   #830
Cruiser
Oddometer: 1,356
Yes the 03-04 sxc has a counterballancer and they have a bearing on each side that should be replaced every 10k miles or so(what I've been told by my dealer) to keep them from failing and doing damage. If you have not had this since new get these done and verify that the CB is "lined up" so to speak,, timed right.. as I've been on several 640's which vibrate and 2 03 sxc 625's that have very little vibs.
Steve C
04 KTM 525 sx/exc-ds!-its street legal,really officer it is! well..
03 KTM 625-gone....
97 GG 250ec-for sale,, just email me if interested
Cruiser is offline   Reply With Quote
Old 06-23-2009, 06:25 PM   #831
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,764
Replacing these bearings every 10k seems a bit much. I've never heard anyone mention this as a maintenance item at all. I can see doing a normal interval inspection and swapping when needed. There have been a few noted here that have failed.
As to getting the CB "lined up right", well that's all about making sure the two little dots are next to each other when all assembled back up. Once they are in place, they are not going to become mis-timed.
The amount of vibes between bikes had been bandied about quite a bit and I truly believe most of the differences have to do with state of tune rather than any mechanical issues in the build of the bike.
Some theories abound claiming that KTM might be asleep at the switch with some of the bikes during the assembly of the crank or that there are variations in the weight of the pistons and cranks from bike to bike and this causes the noticeable difference in vibes. I don't buy it, personally.
Regardless, make sure it is set up properly and maintain it well including getting the valves set to the proper clearance, then ride the crap out of the bike. That's what their meant for, to be beaten like a rented mule.
Originally Posted by NWGS
This post has zero to do with civility and more to do with stupidity.
NICO is offline   Reply With Quote
Old 06-23-2009, 07:56 PM   #832
Cruiser
Oddometer: 1,356
I thought 10K sounded like low miles,, but if you ride hard off-road 10K is a lot.. street not so much.. but if it hasnt been done it should be done by 10k,, seams these are easy to do and relatively inexpensive.. and yes,, two dots,, but they are easy for a novice to get wrong if he isnt paying attention.. and slightly off could cause a nice vibe.. worth a look see.. and the outcome if the case side bearing does go bad is a case half.. a bearing is cheap considering.. I change my oil much earlier than the intervals in the manual too when I'm off-road a lot.. if I'm on road,, you can stretch it out,, or should I say I would.. even when strung out on road it isnt as bad as reving it trying to get over large trees/rocks and thru mud holes smoking the clutch plates..
Steve C
03 KTM 625-gone....
Old 06-24-2009, 02:11 PM   #833
Bonebag
ADDvrider
Bonebag's Avatar
Location: Wisconsin..Hot,Cold and everything in Between
Oddometer: 5,380
Also posted as a new thread in thumpers..but
Rear chain guide of the early model LC4 640..2000 OK..I read the thread index and honestly it's a bit confusing about this part..does anyone have a simple explanation on how to upgrade this unit. I looked under part number 54607066100 and that's fine..There is also a unit by TM Designworks on KTM parts.com as seen HERE Will this unit fit as it replaces the above part number and do I also need the following??
retaining plate chain guide '94 50207070000superceeded by
50207070044
HH collar screw M6 *55 ws=8 0015060553
HH collar screw M6*50 ws=8 0015060503
HH collar screw M6*16 ws=8 0015060163
I guess there should be a link to the chain guide without the bazillion pages of other stuff??
Bonebag is offline   Reply With Quote
Old 06-24-2009, 08:21 PM   #834
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,584
Found and replied in your new thread.
Yes, should be indexed.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 06-24-2009, 09:35 PM   #835
meat popsicle OP
Ignostic
Oddometer: 14,235
hey wolfie,
are these not enough?
http://www.advrider.com/forums/showthread.php?t=203978
http://www.advrider.com/forums/showt...35110&page=117
unbolt, bolt on, ride...
Old 06-25-2009, 04:35 AM   #836
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,584
Slap me, please.
Cheers,
Colin
The Stable
Old 06-25-2009, 09:00 AM   #837
meat popsicle OP
Ignostic
Oddometer: 14,235
Slap me, please.
I'm feeling a bit daft, but after reading your latest in the chain guide discussion maybe there is room for another thread on this subject.
Old 06-25-2009, 01:36 PM   #838
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,584
Uh, no, I think two dedicated threads is enough.
Found the indexed one in nothing flat. Hit Ctrl-F in the index, searched for "chain" and it was only a few clicks of "next" to find it.
Cheers,
Colin
The Stable
Old 06-25-2009, 03:46 PM   #839
meat popsicle OP
Ignostic
Oddometer: 14,235
Oh good, I am not completely daft. Just overworked, which ain't a bad thing...
Old 06-26-2009, 09:53 AM   #840
Cruiser
Oddometer: 1,356
If anybody is keepin track you can add 1 more to the cracked rear hub issue for the non-cush drive sxc..
Steve C
03 KTM 625-gone....
Times are GMT -7.   It's 12:48 AM.
