Old 03-12-2013, 04:00 PM   #16
catalina38
Contrarian
Oddometer: 1,643
Check out a parts fiche on one of the online parts sites to see where they are.
munnracing.com
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 03-12-2013, 04:17 PM   #17
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,953
http://65.57.254.60/shoponline/catal...76014100%2Egif
# 60 IIRC
Follow the vacuum line from the underside of the throttle bodies to where it plugs into the sensors. I don't know what side of the throttle bodies they are on.
Here is a pic of one from my bike. See the line coming out of the intake tube going to the sensor on the frame rail.
Other side of bike
One more
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 screwed with this post 03-12-2013 at 04:23 PM
DSM8 is offline   Reply With Quote
Old 03-12-2013, 04:52 PM   #18
catalina38
Contrarian
Oddometer: 1,643
The brass fitting being pointed at has a 1mm hole that gets clogged. Use some thing just a bit smaller than 1mm and clean the hole. One side is easy to get at the other not so much.
KTM 990R 500EXC
Old 03-13-2013, 10:24 AM   #19
tilting40s OP
Oddometer: 57
Update: so just calculated for last ride 20.16... mpg :( It sucks because I'm happy w/ how smooth and powerful it is. I've been reading that a lot of people who got good mpg's with stock map put slip on pipes had the bike prof. remapped and experienced mid 20's mileage. I guess re-setting to stock map would be the first step. If that doesn't help then it's on to more investigation. Anyone exp. remapping really screwing with economy??? What have people paid for professional remapping?
tilting40s is offline   Reply With Quote
Old 03-13-2013, 12:09 PM   #20
DeepSea
electronically challenged
DeepSea's Avatar
Oddometer: 242
Ace Motorsports in Concord Ca, flashed mine with the Akra map before I bought a cable. It was $25 or $30 if my memory is correct. But they will only do a stock or Akra. And the custom map you have will be lost. If your in no hurry, when I get back next month. Ride on out to Antioch and I'll save your map and flash it with which ever you like.
CDR 2012 ------ Too Lazy to write my own RR
Commercial Diving flashlight and tools
It's not me. My bike is Narcoleptic.
Research is what I'm doing, when I don't know what I'm doing.
DeepSea is offline   Reply With Quote
Old 03-14-2013, 07:01 AM   #21
tilting40s OP
Oddometer: 57
DeepSea,
That would be awesome. I'm going to clean my sensors and intake stuff see if that helps, then move onto the stock map. I'm thinking of investing in a cheap PC to get tuneECU and cable (would want in eventually) but I still would need to learn how to use it correctly-Whole other story.....
Thanks for the help everyone!
Old 03-14-2013, 07:42 AM   #22
DeepSea
DeepSea's Avatar
Oddometer: 242
Will send you a PM once I get back home.
It's pretty easy to use TuneECU. Just doing it the first time is intimidating. At least to me it was.
Old 03-21-2013, 09:05 AM   #23
tilting40s OP
Oddometer: 57
As far as cleaning the throttle bodies, what would you guys suggest? Carb cleaner? And what should I use for the sensors? Would Q-tips w/brake cleaner work? Thoughts? Also would anyone have a step by step for pulling the throttle body off the intake. (I know its simple but it my first time) :) Cherry poppin!
Old 03-21-2013, 10:09 AM   #24
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 935
Originally Posted by brents347 View Post
Do you have the petcock on one tank turned off? Becuase this is TERRIBLE mileage!
Wish i had 90miles on each side tank, and having FUN!
Originally Posted by Irideeverything View Post
I picked up an 08 990 ADV in January and did some decent road riding over the weekend. Gas light came on around 130 miles I think. It took about 2.2 gallons per side. Sounds like $hitty mileage to me, or another problem. Thoughts??
Decent offorading, 130 miles to the light ain't that bad..
With Tuneecu (or 990 friend with tuneecu) check if O2's are off, set them on and testride. Test TB's synch and if no change, load stock map.
690R
Old 03-22-2013, 01:08 PM   #25
tilting40s OP
Oddometer: 57
I can't find anything small enough to clean the hole, what have you used?
Old 03-23-2013, 05:03 AM   #26
Gustavo.Ramos
Oddometer: 935
pin, needle, piece of electric wire...
690R
Old 03-25-2013, 11:31 AM   #27
DSM8
DSM8's Avatar
Oddometer: 3,953
They can also be un-threaded from the intake tube and cleaned off the bike if you are so inclined.
Dont use the little cleaning tools they sell for torch tips. That will really screw it up.
Old 04-26-2013, 02:08 AM   #28
DeepSea
DeepSea's Avatar
Oddometer: 242
Haven't forgot about you. I'm still offshore.
Will be back on or just after mothers day weekend.
Old 04-26-2013, 06:52 PM   #29
Deviant666
Present
Deviant666's Avatar
Oddometer: 536
That's about normal for a 990...950's have slightly more tank volume...
KTM 990 Adventure White 2009 R specced
ZZR1400 ABS 2008
Deviant666 is offline   Reply With Quote
Old 04-27-2013, 09:50 AM   #30
Hootowl
Oddometer: 1,258
For reference I did a ride this week that was 176 miles from the last fuel stop. The low fuel light hasn't lit up yet.
About 1/2 of that distance was easy,fast dirt; the other half was pavement cruising at 70+ MPH.
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl screwed with this post 04-27-2013 at 09:56 AM
Hootowl is offline   Reply With Quote
Times are GMT -7.   It's 07:43 PM.
