Old 03-11-2013, 01:45 PM   #1
CRW OP
I dont want a pickle
CRW's Avatar
Oddometer: 772
950 ADV puking coolant a sustained triple digits
Just got back from a Baja trip. With a few long pavement days. We were doing sustained triple digits for times of a hour or two plus. The 950 would over fill the coolant reservoir bottle and puke out on my right leg. topped it off a few times, when it cools down it wont drink the fluid back in. The bike never over heated. runs like a top.
New radiator cap?
anyone else seen this?
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
CRW is offline   Reply With Quote
Old 03-11-2013, 02:01 PM   #2
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,276
Try radiator cap first. Make sure the rim where the cap sits is clean. If that does not work, could be that the head bolts are loose. If that's the case, make sure the head bolt TSB has been done.
Orangecicle is offline   Reply With Quote
Old 03-11-2013, 02:02 PM   #3
Orangecicle
On a "Quest"
Oddometer: 3,276
Don't forget to burp the system when you get the new cap in place.
Old 03-11-2013, 02:35 PM   #4
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,440
Yeah sounds like cap. The advice to check the sealing surface is good too.
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 03-11-2013, 03:08 PM   #5
Sumi
Sumi's Avatar
Oddometer: 1,861
I'm having this issue as well.. It's either the cap or the head gasket / head bolts.
Try cap first, as others have suggested.
Old 03-11-2013, 03:13 PM   #6
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,917
Most like the cap has residue on the seal ring and there wont allow the system to pressurize and that brings the boiling point way down
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 03-11-2013, 03:45 PM   #7
Orange Toaster
Orange Toaster's Avatar
Oddometer: 113
Head gasket
Sorry to say it but most likely head gasket.
Try this test:
http://advrider.com/forums/showpost....71&postcount=7
/OT
'03 KTM 950 Adventure
Orange Toaster is offline   Reply With Quote
Old 03-11-2013, 07:41 PM   #8
GZERO
Fixing stuff around
GZERO's Avatar
Oddometer: 265
Some 950s have the head gasket problem.
From your description yours is one of them.
Before anything, change the radiator cap and make REALLY REALLY sure the system is well burped, because this might cause almost the same symptons.
But, if it still happends, new head gasket (might as well make sure the cyl and head gasket are perfectly flat since you're in there), new head bolts as well as nuts and washers.
This is a TSB.
Having some time off bikes.....family first :(
GZERO is offline   Reply With Quote
Old 03-11-2013, 08:06 PM   #9
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,913
This is a TSB.
His signature says he has an 06 Adventure 950. This bike DOES NOT need the head nut TSB. These bikes were already fixed before being delivered. It can still be a head gasket, but I'd look elsewhere first.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 03-11-2013, 08:12 PM   #10
GZERO
Fixing stuff around
GZERO's Avatar
Oddometer: 265
I'm sorry to say, but i have seen 990 that had the early studs (they were early versions) as well as the "defective" oil pressure regulator.
Anyway, like i said, make sure is nothing else before doing anything else.
Old 03-12-2013, 05:04 AM   #11
ABuck99
0.0
ABuck99's Avatar
Oddometer: 650
Is there any consensus out there relative to LC8's that replacing stock radiator cap with an uprated (higher) PSI limit will have positive result on reducing boil over, or negative impact on the cooling system?
Most of the late model KTM thumpers come with 1.8 bar/26psi caps. But it seems all years of KTM bikes 690-1190 are only equipped with 1.4bar/20psi caps.
Thoughts?
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 03-12-2013, 05:54 AM   #12
Orangecicle
On a "Quest"
Oddometer: 3,276
Thoughts?
I would think that more pressure would result in higher incidents of water pump seal failure.
Old 03-12-2013, 06:16 AM   #13
DockingPilot
Oddometer: 9,917
Pop the cap and look under it. You could eliminate or conclude on wether this is the problem in two minutes.
Frank Reinbold
Old 03-12-2013, 06:19 AM   #14
DockingPilot
Oddometer: 9,917
Also have you ever flushed the cooling system since new ? If not then I would lean even more towards the cap leaking pressure
Frank Reinbold
Old 03-12-2013, 08:52 AM   #15
CRW OP
CRW's Avatar
Oddometer: 772
Thanks for all the responses.
Yes the cooling system has been flushed!
The bike has the updated head bolts.
The bike never boiled over or over heated!
Checked radiator cap on the trip seemed fine.
I have a hard time to believe its the head gasket as this only happened when I was doing sustained 100mph plus for at a minimum of a hour at a time. No sign of loss of oil or power.
I will try this bottle trick to rule out the head gasket
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
Times are GMT -7.   It's 01:26 AM.
