Old 03-12-2013, 02:17 PM   #1
rattis OP
rattis's Avatar
Oddometer: 1,209
Me again
I'd like to make my own water pump impeller tool, can anybody please make a drawing as I'm 12 hrs by aeroplane away from the bike.
PRETTY PLEASE
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, thrice up now, two 990 Adv and a 950 SER
rattis is offline   Reply With Quote
Old 03-12-2013, 02:46 PM   #2
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,011
I believe pliers with long slim jaws will do the job.
Maybe you should prefer the ones with bent jaws. Pyndon made one with a flat sheet of metal with two screws bolted on it.
Cheers.
Old 03-12-2013, 03:00 PM   #3
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 20,174
PRETTY PLEASE
Rattis- I will take a picture of one I made and post it for you when I get home in a couple hours. It is a simple design, to put it mildly. When you see it, you'll smack your forehead and say duh! But, seeing truly helps put its simplicity into perspective.
I don't have to be right to argue.
NICO
unaweep is offline   Reply With Quote
Old 03-12-2013, 03:17 PM   #4
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 722
I don't think the wheel needs to be re-invented. Look here.
Pyndon is the man.
HeatXfer is offline   Reply With Quote
Old 03-12-2013, 03:28 PM   #5
Katoom72
Katoom72's Avatar
Oddometer: 898
I don't see why u need the impeller tool. If u take the inside cover off, u can lock the shaft with a big screwdriver and losen the bolt. Vice versa for the mounting.
Unless u want the impeller off for other reason then a WP repair, then i did not say a thing.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 03-12-2013, 04:44 PM   #6
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,005
Here are picks of mine
PRETTY PLEASE
I made mine with a piece of left over Acetal. This can be made out of just about anything.
Orangecicle is online now   Reply With Quote
Old 03-12-2013, 05:14 PM   #7
crazybrit
crazybrit's Avatar
Oddometer: 8,556
+1 or just hold the back of the shaft with a pair of pliars (wrap the shaft with old innertube).
The only point of the impeller holder is to prevent breaking the mating part on the motor. Once the cover is off, the shaft isn't connected anymore so that risk has gone. Instead do the above. Simple, no tool needed.
crazybrit is offline   Reply With Quote
Old 03-12-2013, 11:47 PM   #8
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,156
This is how i did mine .. (from my coolant flush thread - here) and did no damage to the impeller at all - re used it.
Originally Posted by Vicks View Post
remove WP cover (four bolts/screws)
now to remove the impeller retaining screw. There are many "special" tools available for this and you could even fabricate an excellent one el-cheapo using a flat bar of aluminium/steel and two set of bolt/nuts, but i found another way to do it. The impeller has two holes in it to use the special KTM tool hold it in place while you loosen the retaining screw. I spread open a nose plier wide enough to serve this purpose. voila
just be carefull to put enough pressure on the nose plier while you are loosening the impeller retaining screw, so that the pliers don;t slip and damage the impeller.
hold the impeller using the KTM toolkit pliers and the nose plier, i used a rag to cover the impeller blades while using the pliers on it, without which it would obviously damage them. It however, doesn't show in the below pic cos i couldn't do a good enough re-enactment
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is online now   Reply With Quote
Old 03-13-2013, 07:57 AM   #9
rattis OP
rattis's Avatar
Oddometer: 1,209
Talking Tack så mycket
Thank you very(above in Swedish) much indeed lads.
If you were here I'd kiss you all, mind you no tongue though
The wisdom here is great, so please tell me if i need to bring any screws along for the ride.
I have decided on a lengthy trial run in California, hopefully including Red Bluff to Eureka.
So if you see a very tall guy on a little adventure with the odd Swedish flag, that's me
Times are GMT -7.   It's 12:00 PM.
