Old 06-24-2013, 05:27 PM   #166
teambft
teambft
teambft's Avatar
Oddometer: 1,203
Holy Crap
Well, I gotta say - I just got done with my mods last night.
2005 950 ADV, 12,000 miles.....just bought the bike - very unmolested
Did canisterectomy and SAS removal.
Rejetted based on Sporting's advice:
I'm planning to ride 500-2000 ft, mostly
Just installed D&D pipes - which I love!!
Used the Factory Pro kit from Sporting.
168/165 mains, 3rd clip, 4mm float height, 45 mains and roughly 1.25
turns on the screws
Installed Sporting's intake system and ITG filter - which is a godsend
compared to the alternatives.
Bike rips!!!!!!! Starts very well, idles beautifully, pulls hard. Wow.....fun factor increased dramatically. Several years back I had FI 990's.....which had mods as well, but this current set up is way more pleasing.
Have yet to log miles and report back MPG and overall riding dynamics.
Oil filter also had the dreaded waves in it......so gonna send my case out to CJ Designs for a waterpump rebuild.
Anyhow, thanks SW - very happy customer here.
2011 KTM 300 XC-W, 2001 Aprilia Falco, 2010 KTM 530 XCW Six Days, others
2012 KTM 500 EXC - sold, 950 SER-sold (regret)
Prior: BMW XC, TE610, KLR 650, 07 KTM 990 Adv, and many more ...BMWs, Ducs, KTMs, Harleys
teambft is offline   Reply With Quote
Old 06-24-2013, 07:28 PM   #167
vwboomer
Buffoon
vwboomer's Avatar
Oddometer: 10,269
700ft Above sea level here.
I started out with the 175 mains and 45 pilots and was very happy with power, still got the same fuel economy as with the stock jetting. Last change was to accomodate going to CO in two weeks - dropped the pilots back to 42.
Big loss in power, but mileage stayed right about 35, or just a tad higher.
Hopefully this setup works ok as we will be going all the way up to 14k feet on some stuff I don't really want to ride on any bike much less a big loaded one
vwboomer is online now   Reply With Quote
Old 07-02-2013, 01:22 AM   #168
doctor_big
It hurts when I fall down
Oddometer: 700
Ok, I'm lying here with a 12inch incision in my right leg, all slugged out on morphine. Had a revision of my hip replacement (rip out old stem in femur, bore out a thou, slam in an oversize spike).
My filter is sitting in the box in my garage, and my best buddy is gonna install it for me.
But I need to get a jet kit and block off plates. Can someone assist me with one-stop shopping for these items?
I am 800ft above sea level and favour clean running and good midrange over balls-out performance.
Jason
Better to die on your feet than live on your knees.
doctor_big is offline   Reply With Quote
Old 07-02-2013, 06:36 AM   #169
keener
Speed changes you.
keener's Avatar
Oddometer: 928
Ouch...so u want to make that bike faster? :)
PM me if u couldn't get the plates, I can make them. Im in Toronto.
04 ADV 950
keener is offline   Reply With Quote
Old 07-02-2013, 08:14 AM   #170
doctor_big
Oddometer: 700
Btw, I damaged the hip implant when I slipped on the ice WALKING THE DAMN DOG!
Incidentally, not looking for freebies out of this, just part numbers or a kit name so that I can order with little fuss.
Old 07-07-2013, 03:46 PM   #171
Sporting Wood OP
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
OUCH! PM sent, gonna help you out with a jet kit if you haven't found one already.
Sporting Wood is offline   Reply With Quote
Old 07-10-2013, 08:02 AM   #172
keener
Speed changes you.
keener's Avatar
Oddometer: 928
Are you guys able to remove the carbs without removing either tanks with this setup?? that would be great.
Its should be possible to access the 6mm clamp screws with some sort of angled 6mm socket driver from the top. My filters are in the mail
04 ADV 950
Old 07-10-2013, 09:12 AM   #173
DirtJack
DirtJack's Avatar
Oddometer: 1,529
How is the 990 test version working out?
The title asked the question of the day.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-10-2013, 11:32 AM   #174
Sporting Wood OP
Oddometer: 896
You will spend more time with that than its worth if its even possible. Try just taking off the right tank. Its possible to do it w/o removing the left.
Old 07-10-2013, 11:32 AM   #175
Sporting Wood OP
Oddometer: 896
Delays, delays, delays! Shouldn't bee to much longer.
Old 07-11-2013, 09:32 PM   #176
Thumper996
Thumper996's Avatar
Oddometer: 592
Tuning In
Started off with the following setup for SM Sport Riding and have a bad surge at quarter throttle steady cruise in any gear. 500 feet above seal level hot humid 80 - 90's weather. Starts and idles perfect. Rips at top speed and low rpm and mid rpm full throttle roll-on's, no stumble just raw power.
Original setup:
FMF cans
Part Factory Pro kit and Part H2W kit for my jetting
Main Jets 170R / 168F
Pilot Jet #45
Needles Factory Pro Ti needle 4 position from top
IMS screws 2 turns (Flex-Jet installed for easy adjustment)
Air Jet #70 as supplied by H2W to replace stock #50
Float Height 3.5MM
New setup tonight:
Already feels way better, on 20 minute evening test ride surge is 99% gone after raising the needles to 5 from top.
FMF cans
Pilot Jet #45
Needles Factory Pro Ti needle 5 position from top
IMS screws 2.5 turns (Flex-Jet installed for easy adjustment)
Float Height 3.5MM
Thumper996 is offline   Reply With Quote
Old 07-11-2013, 10:01 PM   #177
Sporting Wood OP
Oddometer: 896
The big air jet made the surge. .
Old 07-11-2013, 10:27 PM   #178
Thumper996
Thumper996's Avatar
Oddometer: 592
Was thinking along that line, but not sure wanting to play with needles little more before changing it. It's all different for each bike and rider, so I am working toward setup. It fun to tinker anyway.
So far so good, well get to tell more Sunday on a ride.
Old 07-13-2013, 11:20 PM   #179
keener
Speed changes you.
keener's Avatar
Oddometer: 928
Just finished installing it. Went for a quick test ride around the block...didnt know this bike can accelerate this hard! More comments lster its past 1am.
04 ADV 950
Old 07-14-2013, 03:47 AM   #180
motornorte
Spaniard Bastard
Oddometer: 1
Is it tape for heat insulation?
motornorte is offline   Reply With Quote
Times are GMT -7.   It's 09:26 PM.
