Old 12-22-2013, 12:21 PM   #346
Sporting Wood OP
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
All orders shipped so everyone is getting them by Xmas. Cheers
Thanks to everyone for being patient while we churned through a rather extensive backorder list. Everything is back on the shelf and ready for immediate shipping. Thanks!
Sporting Wood is offline   Reply With Quote
Old 12-23-2013, 04:47 AM   #347
mousitsas
mousitsas's Avatar
Oddometer: 2,913
SW and ManuC
I just fitted an AEM wideband gauge. At the point when the hesitation occurs is I think when the needles begin to rise (15-25% throttle) and AFR shoots at well over 17. I am trying to keep throttle as steady as possible and increase very slowly, when ths happens.That is at a high enough gear and incline to keep engine load at max. So it seems the needles need to be raised. Didn't have the chance yet to try WOT for a long enough strech, but it seems that when revs rise above 6000, AFR is somewhere between 12 and 13.
Needles are the FP at #3, floats 4 - 4.5mm, 170/172 mains, 45 slows all else stock.
I have set idle with the screws at AFR 13.5 or so which corresponds at 2 turns out.
Any comments?
mousitsas screwed with this post 12-23-2013 at 04:54 AM
Old 12-23-2013, 05:57 AM   #348
Sporting Wood OP
Oddometer: 896
Originally Posted by mousitsas View Post
SW and ManuC
Any comments?
Good work! You are correct. You will need to raise the needle. You checked your air jets, right? Should be stock 80 & 50. That will also cause a lean spike...
When you raise the needles, it will typically mean that the main will bleed more, prompting you to lean out the bottom end a bit. Could mean an even taller float, I've never gone over 5mm, or a drop back to 42 pilots.
Congrats, you have one of the strong LC8's. Most of them won't run /4.
Old 12-23-2013, 08:07 AM   #349
mousitsas
mousitsas's Avatar
Oddometer: 2,913
Old 12-23-2013, 02:02 PM   #350
ManuC
950 SM
Oddometer: 123
SW and ManuC
Any comments?
Thanks Mousitsas
I will try 4 on the needles for the rest I have the same jettings only the fuel screws on 2.5 are differents.
Or first try to put 172/175....
ManuC is offline   Reply With Quote
Old 12-23-2013, 06:57 PM   #351
2kool2be4gotten
2kool2be4gotten's Avatar
Oddometer: 39
Back ordered Over-Sock Filter received today, just in time for topping the tree :) Thanks for putting all of this together!
knobby tires on a gravel road....
2kool2be4gotten is offline   Reply With Quote
Old 12-24-2013, 05:15 AM   #352
mousitsas
mousitsas's Avatar
Oddometer: 2,913
Went for a ride today with the needles @4 stop
Problem has disappered stop
Bike is mental stop
This filter setup should not be legal stop
Still no chance to open it up for top speed to check mains stop
Will report at first chance stop
Merry Xmas to all
Old 12-24-2013, 06:01 AM   #353
ManuC
950 SM
Oddometer: 123
Yes
Just finish to put mine to 4 but with the weather no chance to ride it
Thanks Mousitsas and Merry Christmas to all
Old 12-25-2013, 06:09 AM   #354
ManuC
950 SM
Oddometer: 123
Voilà just make a little test and Bingo no more surge like Mousitsas
Now just the fine ajustement with the fuel screws and may be drop the mains to 168/170 or 165/168 (I think it pulls harder before with 165/168)
For the moment
Mains 170/172
Needles FP at 4 from the top
Floats 4 mm
Pilots 45
Fuel screws 2.5
From 0 to 1000 ft level
Old 12-25-2013, 09:47 AM   #355
mousitsas
mousitsas's Avatar
Oddometer: 2,913
For the moment
Mains 170/172
Floats 4 mm
Pilots 45
Fuel screws 2.5
Nice!
You must be right about the smaller mains. I will try tomorrow to give it run at WOT.
Old 12-25-2013, 11:06 AM   #356
ManuC
950 SM
Oddometer: 123
Impatient of the results.
Old 12-26-2013, 07:05 PM   #357
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 511
Nice bedtime reading
950 SE
WR250R
950 ADV
ICERIDER is offline   Reply With Quote
Old 12-26-2013, 07:08 PM   #358
renogeorge
Oddometer: 1,404
And this filter setup does the same for the 990 FI!!!
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 12-26-2013, 11:25 PM   #359
mousitsas
mousitsas's Avatar
Oddometer: 2,913
The weather has taken a dive, lots of rain, will have to wait for a couple of days unfortunately, for WOT AFR readings.
Old 12-27-2013, 02:29 AM   #360
ManuC
950 SM
Oddometer: 123
Yes the same here .... patient
Times are GMT -7.   It's 05:18 AM.
