Old 01-12-2014, 08:12 PM   #376
renogeorge
Oddometer: 1,485
I am running one on my 2007 990. Very happy with the performance, price and access I now have.
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 01-13-2014, 11:54 AM   #377
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 962
Intake sound is LOUD even with AK cans with baffles removed... i'm having too much fun and attracting unwanted attention...
690R
Old 01-19-2014, 12:32 PM   #378
pilacs
pilacs's Avatar
Oddometer: 74
Laugh
Just placed order. 07 990 ADV.
pilacs is offline   Reply With Quote
Old 01-20-2014, 09:31 AM   #379
Wrath
Oddometer: 3
filterkit
Hello
Already got a IGT JC30-80 filter so i wonder if your baseplate will fit my 990 SMR -11
from what l can read on your add it dosent but a cant understand why?
Im after a baseplate and SAS plates
Wrath is offline   Reply With Quote
Old 01-20-2014, 11:04 AM   #380
Sporting Wood OP
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
Originally Posted by Wrath View Post
Hello
My 990 plate will fit fine. IIRC, the early R models used the SE tank and seat which conflicted with the rear top edge of the standard JC30-65. For that reason, we have ITG manufacture a domed version, a little taller and narrower to better fit in the space.
I believe that your '11will bolt right up however, without the need for either using the domed filter or modifying the seat pan to fit. I don't have a SMR handy here to verify that so.... I can send you one and if it doesn't fit, no biggie. I will take it back. I'm pretty sure it will clear, though.
Sporting Wood is offline   Reply With Quote
Old 01-20-2014, 12:40 PM   #381
Wrath
Oddometer: 3
You have PM !
Old 01-20-2014, 07:03 PM   #382
gearheadE30
gearheadE30's Avatar
Oddometer: 1,001
Just sent in my order!
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 01-20-2014, 07:45 PM   #383
dzrtracin
ride'n 2 live
dzrtracin's Avatar
Oddometer: 2,867
Ordered mine today as well 950SE Kit
Looking for jetting feedback. Im in So California, live @ about 1500' Do a wide range of riding from the desert to the mountains of the High Sierras, mainly the dez though. All the BS removed, plates installed & running FMF Ti cans. Thanks!
Content, NEVER!
dzrtracin is offline   Reply With Quote
Old 01-20-2014, 08:34 PM   #384
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,199
Hi,
Is there an over sock filter for the dome version for a 990 adv?
I'm ready to pull the trigger.
Ohhh and what about the new items that are coming up soon?
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 01-21-2014, 04:04 AM   #385
Sporting Wood OP
Oddometer: 896
Originally Posted by bikyto View Post
Hi,
No, the over sock won't fit onto the dome filter. Some customers are running filter skins with these. Also it is possible to fit the standard filter on the SE but it requires some modification to the seat pan to do so...another alternative.
Old 01-21-2014, 04:05 AM   #386
Sporting Wood OP
Oddometer: 896
You have PM !
Thanks guys.
I'll get it all out asap!
Old 01-21-2014, 07:05 AM   #387
bikyto
bikyto's Avatar
Oddometer: 2,199
OK, I was asking for 990adv. So it might just be better to stick with the standard size filter then and have a pre filter on it. Skin filter clog up too quickly for my long hauls.
Do you have an update on the quick release and other new items you're soon releasing?
Thanks again
Old 01-21-2014, 11:00 AM   #388
Wrath
Oddometer: 3
Thanks guys.
Payment sent !
Old 01-21-2014, 10:38 PM   #389
bikyto
bikyto's Avatar
Oddometer: 2,199
Order sent. I'd like a quick release glove box with it but I am not sure if they are available. If they are, I'd like to add one to the order if possible.
bikyto screwed with this post 01-21-2014 at 11:31 PM
Old 01-23-2014, 09:12 AM   #390
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,624
Finally got around to installing the filter on my SDR.
Really makes a difference in the mid range and is certainly the biggest HP to $ mod I have ever done. It also makes maintenance and access to the throttle bodies very easy.
The only down side is that the filter is hard to clean and oil since the plastic cage is an integral part of the filter. It's not like my 530 filter that I can fully submerge in oil or cleaner and then squeeze. On this filter you really have to massage the oil into the nooks and crannies w/ your finger tips.
Here are a few instal pics.
Gaskets on top of throttle bodies:
Air meter installed on base plate:
Velocity stacks on base plate. I ended up ordering a set of RC-8 velocity stacks. They are shorter and let more air in.
Filter installed:
Times are GMT -7.   It's 05:20 PM.
