Go Back   ADVrider > Riding > Regional forums > Canada
Old 05-30-2013, 10:16 AM   #61
Cal
Oddometer: 924
Hannes
Gisdood just posted the Cassier is closed because of flooding.
Cal is offline   Reply With Quote
Old 05-30-2013, 10:45 AM   #62
GISdood
GISdood's Avatar
Oddometer: 858
With any luck, he made it through there yesterday. That washout due to flooding was just posted at 7:30 this morning. Here's hoping...
GISdood is offline   Reply With Quote
Old 05-30-2013, 07:34 PM   #63
hannes vg OP
Oddometer: 61
cassiar
hi,
i arrived steward today. had a lot of rain today.
gonna stay here for maybe 2 days. hoping the rain stops for a while.
didn't get much scenary, all fog on the peaks.
cheers
hannes vg is offline   Reply With Quote
Old 05-30-2013, 08:09 PM   #64
swinada
swinada's Avatar
Oddometer: 74
you're going to start growing webbing between your fingers. How are those rain covers for your boots working out? Are they helping at all?
swinada is offline   Reply With Quote
Old 05-31-2013, 09:20 AM   #65
hannes vg OP
Oddometer: 61
They help really good thanks for that.
Dry boots in the morning is always nice:)
Old 05-31-2013, 12:33 PM   #66
hannes vg OP
Oddometer: 61
Cassiar
Hi,
Pretty much stuck now in stewart because of the flood.
People here think it's gonna take at least a couple of days.
Does someone have an idea what i could do.
Just wait or go back and do the loop. Maybe ferry?
Old 05-31-2013, 04:30 PM   #67
shuswap biker
Oddometer: 220
Since your in the neighbourhood get Hyderized!
http://www.youtube.com/watch?v=d-FqlQQ8d00
shuswap biker is offline   Reply With Quote
Old 05-31-2013, 05:49 PM   #68
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,303
Originally Posted by hannes vg View Post
Hi,
You could ride up to Dease Lake and then take the side trip road out to Telegraph Creek... This would kill a couple of days so the HWY should be fixed by the time your back to Dease lake... The road to Telegraph Creek is one of the Northern B.C.s best rides...
If the road is still washed out you could hire a helicopter in Dease Lake to hoist your bike and fly you to the north side of the flooded area...
gunnerbuck is offline   Reply With Quote
Old 06-02-2013, 07:06 AM   #69
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,303
You should be able to get through now as one lane of the road reopened last night... Safe travels, post lots of pics...
Old 06-04-2013, 04:31 PM   #70
hannes vg OP
Oddometer: 61
Starting problems klr
Ok, update.
Got back from some pretty hard off road riding in telegraph.
The bike is acting not normal.
If i shut it off i cant get it back on, or sometimes.
It takes a while. You can hear it going over but no ignition.
Changed the sparkpluck it goes a little bit better but still takes a lot of time.
And have to give it a bit of throttle
Any ideas?
Old 06-04-2013, 04:55 PM   #71
lexluther11
Ride,Eat,Rest-Repeat
lexluther11's Avatar
Oddometer: 1,204
Have you checked your air filter? If it's dirty they run like crap.
lexluther11 is offline   Reply With Quote
Old 06-04-2013, 05:05 PM   #72
hannes vg OP
Oddometer: 61
Got still enough (power) on the road
It's not that dirty or should i take everything out of there
Old 06-04-2013, 05:39 PM   #73
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,303
Ok, update.
Any ideas?
Are you in Dease Lake? If so, keep your eye open for some KLR owners about town and at the gas station and ask them to listen to your bike to help diagnose the problem... In that country every 3 out of 10 bikes is likely a KLR...
A few things come to mind:
-You've been riding a lot in the rain, it is not unusual to get a bit of water in the carb... Try draining the carb float bowl by cracking the drain screw at the bottom of the carb... This will get rid of any water that may be getting pulled into the jets... When you open the screw the fuel will drain out the rubber hose to the bottom of the bike, try catching the fuel {about 50 ml of it} in a clear container to inspect for water pods...
-It may be possible that your bike has sucked some dirt into the pilot circuit
in the carb... If this is the case you may need to take the carb apart and clean out the jets and passageways...
- Go over your wiring from nose to tail and look for any rub spots or bare spots in the shielding... The wires do have a tendency to move around and rub together from vibration, more so if riding rough roads, over time electrical shorts will develop if not taken care of... A wrap on any wear spots with electricians tape makes for a quick semi permanent fix...
Old 06-04-2013, 06:26 PM   #74
swinada
swinada's Avatar
Oddometer: 74
My first guess would also be your airfilter. Take it out and wash it and reoil. Gas works fine for washing it and I'm sure you'll find somebody around there with a bit of filter oil.
Good luck, have you gotten any sunshine yet? It is nice and sunny down here
Old 06-04-2013, 07:11 PM   #75
Randaroo
Randaroo
Randaroo's Avatar
Oddometer: 13
my klr canundrum(s)
well its good to hear you didn't drown up there, hope ya dry out and can see the rest of yer trip through dry glasses.
ummm, it occurs to me the KLR loves to have that sticky(stuck open) cable-to-switch on the kick stand, fuggn thing caused me a load of grief until i disconnected it.(pull the cover and remove the pin on the end of the cable and shove the sticky switch up, closed) its worked perfect eversince. also that stupid clutch switch in the clutch lever, sometimes it won't close(stuck) and needs to be by-passed.
Davids float boal draining also could be the solution. a splash of Methyl in yer gas will help with that too. that over priced Seafoam stuff works good too.
I just mowed the front feilds here, sunny as heck, love'n it.
Chowder
Randaroo is offline   Reply With Quote
Times are GMT -7.   It's 01:40 AM.
