Go Back   ADVrider > Riding > Regional forums > Canada
Old 06-04-2013, 10:31 PM   #76
2Trider
Oddometer: 267
Glad you made it into Telegraph
As stated Sounds like water in the gas....turn fuel to reserve and drain the carb for a minute or two... hopefully letting any water in the tank flow out as well
Good luck and was good to see you.
2Trider is offline   Reply With Quote
Old 06-05-2013, 08:27 AM   #77
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,656
I think your bike has the Vacuum fuel petcock. I'd look at that for sure the diaphragm or vacuum line may be damaged. Lots of the fuel up there also comes from the same Husky/Mohawk refinery in PG and does contain Ethanol.They seemed pretty lax on labeling the pumps up that way for the "may contain Ethanol".
I sure got crap gas around there last year and that plugged my filter.Don't know if you have inline fuel filters but what I know for sure is that water in the gas may plug them if they are the cheaper "paper type" variety. Water swells the media and plugs the filter.
Good luck...looks like the weather is improving. Time for a quick run up that way if Fedex shows up this week with my new tires.
Have tools, will travel!
Old 06-05-2013, 09:17 AM   #78
hannes vg OP
Oddometer: 61
we drained the carb. all looks clear, no dirt and smell's like gas.
if my kickstand is up i still can crank it over so it has connection.
if the biks is running i can drive 100K without it shutting down on me it got the same power as before.
it's just the starting that's screwed over. after some time of cranking it and giving some throttle it would fire up. but then the problem is if i try to long my batterie runs out. had to jump it a couple of times. maybe the batterie isn't charging anymore.
but it's in a shop now and probably have to pay a sh*tload of money.
and not shure if they find the problem.
i tryed with a mecanic yesterday. he was thinking of taking the carb out to clean it. but he didn't have the time. and i'm not that great when it comes to that stuff so......
hannes vg is offline   Reply With Quote
Old 06-05-2013, 09:20 AM   #79
hannes vg OP
Oddometer: 61
and there is spark but i dont think it's a good spark but the other guy's here think it is. even with the new sparkplug it's kinda look weak to me. it's not bright blue. but sometimes the bikes starts up so...
Old 06-05-2013, 02:10 PM   #80
hannes vg OP
Oddometer: 61
They say it's the coil. Shipping waiting till monday hopefuly
Old 06-06-2013, 09:23 PM   #81
swinada
swinada's Avatar
Oddometer: 74
did you get that coil in?
When were the valves last checked and adjusted in your bike? Tight valves can cause starting problems too.
swinada is offline   Reply With Quote
Old 06-09-2013, 11:35 AM   #82
hannes vg OP
Oddometer: 61
the coil should arrive tomorow. let's hope it's gonna work. i wanna ride again. the weather is been great the last couple of days. whitehorse is a nice town, but staying here for 5 days without transportation that kinda sucks. let's hope that tomorow everything will be fixed.
greetz hannes
Old 06-09-2013, 12:54 PM   #83
swinada
swinada's Avatar
Oddometer: 74
greetz hannes
Oh you're in Whitehorse, I thought you're still in Dease Lake. Let's hope the coil is all you need. If you're going to be stranded any longer up there send me an email and I'll send you an address of some friends in Whitehorse.
Old 06-09-2013, 01:08 PM   #84
hannes vg OP
Oddometer: 61
ok, thanks!!!!
Old 06-10-2013, 03:05 PM   #85
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 481
Hello Hannes I am at Mitchs in Fort Simpson and just now see your problems....Whitehorse is a good city to be stuck in are you at the Robert Service campground? As for the valves they were set at the loose end of the specifications. I,ll be riding down the Liard river trail in a couple of days after visiting the Nahanni.
Cheers Cal
Life is short, don't waste it....now get out there!
MitchG is online now   Reply With Quote
Old 06-11-2013, 06:58 PM   #86
hannes vg OP
Oddometer: 61
Back on the road.
What a great feeling.
But the bike it's still acting weird when i start it.
But i'm in haines now, soooo nice and sunny.
Pics on the way
Greetz
Old 06-11-2013, 08:08 PM   #87
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 985
Yahooooooo
Yes I am quite serious.
Mike Ryder is offline   Reply With Quote
Old 06-12-2013, 07:45 AM   #88
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,215
Back on the road.
Greetz
It great that your back underway, but not so good that your engine problems were not fixed?
Did anyone get around to cleaning the carb? Was a new spark plug cap installed with the new coil?
gunnerbuck is offline   Reply With Quote
Old 06-12-2013, 09:06 AM   #89
hannes vg OP
Oddometer: 61
Carb is cleaned. Sparkplug don't realy know. Don't think so
When engine is cold it starts pretty good but if it's warm it gets harder and harder.
Gonna try and get to D2D someone there will know my problem. :)
Damn love haines
Greetz
hannes vg screwed with this post 06-12-2013 at 10:46 AM
Old 06-14-2013, 08:04 AM   #90
GISdood
GISdood's Avatar
Oddometer: 856
Hard starts when it's hot sounds like a valve adjustment issue to me. Hopefully someone there can help you check/adjust them.
Sent from my SGH-I747M using Tapatalk 4 Beta
GISdood is offline   Reply With Quote
Times are GMT -7.   It's 06:39 AM.
