Old 03-17-2013, 09:33 PM   #61
blue01
blue01's Avatar
Oddometer: 144
Originally Posted by ph0rk View Post
Have you tried out a DL650?
The rear cylinder is kind of a bear to get to, but otherwise it is cheap to maintain and there are plenty of luggage and windscreen options. I'd suggest a 2012+ if the money isn't an issue.
You're joking, right?
MHaz01,
I rode a fair bit with a guy that had an LT1200, me on a GL1800. The bikes are different but still had a lot in common. The Wing would definitely be the easiest switch for you.
The Wing gets a little less gas mileage but burns regular gas. They have all the usual such as radio, intercom, heated seats and grips on some. The Beemer's a bit faster in the corners but the Wing has the straight line acceleration. For the average rider, that's not a big deal.
Oil changes are easy, do it right on the centre stand.
80,000 miles on mine and the only repairs have been blown fork seals, twice. I ride on rough roads.
Other than that, it's routine maintenance: all fluids changed twice to date, tires every 15,000 miles. $300 for a set of 'Stones. Air filter pulled twice. Now that's a big, time-consuming job!
The Wing isn't cheap to maintain either, according to my wife, but I have an independent mechanic do all the work on it. He charges about $100 to change the tires, on the bike. It's only been back to the dealer twice, each time for recalls.
If you can't afford a new one, there's plenty of used ones around.
Here's a good place to start:
http://gl1800riders.com/forums/forum...-Sale-by-Owner
Got any questions, let me know.
Death to all Tyrants
blue01 is offline   Reply With Quote
Old 03-18-2013, 10:28 AM   #62
stripple
Runnin' Hard
stripple's Avatar
Oddometer: 612
I didn't see anyone mention the Triumph Sprint ST/GT. I can't speak to the reliability of the Sprint, but I put about 20k on a 2007 Speed Triple and was very impressed with the reliability. Honestly, it was as trouble free as any Honda I've owned.
So, what would you Sprint riders say to it's reliability?
“Who is the happier man, he who has braved the storm of life and lived or he who has stayed securely on shore and merely existed?” Hunter S. Thompson
stripple is offline   Reply With Quote
Old 03-18-2013, 06:27 PM   #63
JerryH
Oddometer: 5,069
I don't know about the 1800, but the 1500 Goldwing is VERY cheap to maintain if you do it yourself. The biggest issues maintenance wise are replacing the cam drive belts, and tearing the rear drive apart to clean/lube the driveshaft splines, U joint, etc. Once done on a used bike with the right lubricant, it will only need to be done every 40,000 miles or so. Goldwing tires can be replaced without any kind of lift, just put it on the centerstand to take the wheels off. There are also a number of independent Goldwing shops around. There's one here, but I wouldn't trust them. They use the wrong grease on the final drive parts. It actually has to be a moly paste rather than grease.
I find it surprising how many are recommending touring cruisers to someone who currently has a BMW, especially considering the way cruisers seem to be thought of around here.
JerryH is offline   Reply With Quote
Old 03-18-2013, 09:36 PM   #64
dhawker
Oddometer: 42
I have owned a 2005 Sprint ST since it arrived in North America. After fixing a few known issues with the first release (rectifier, poor designed luggage and sprag clutch) it was very reliable. All the above issues were handled under the warranty. When I totalled my Sprint in an accident last year, I considered buying about 12 different machines. BMW k1300S and GS1200 Rallye, MotoGuzzi Norge and Stelvio, Honda VFR1200 and ST1300, Kawasaki Concours 14, Ducati Multistrada, Yamaha FJR1300, Suzuki Hayabusa, Triumph new Trophy and Sprint. I needed a replacement and could have bought any of them, but ended up with another Triumph Sprint (GT model). It has one of the nicest motors in the business, great character and makes you fall in love with motorcycling. Definitely a sportier, sport tourer. Not the fastest, highest technology, or the best at any one thing, but as a combined package with all things considered, it is hard to beat.
dhawker is offline   Reply With Quote
Old 03-19-2013, 04:18 AM   #65
nbsdave
Oddometer: 306
Originally Posted by Cakeeater View Post
A 20 grand HD might break your bank....but, here's my maintenance costs in 22,000 miles and two seasons:
One new back tire done at the dealer (22,000 miles) about 280 bucks.
One tightened steering head bearing: about 250 bucks if I recall.
Maybe four oil changes, amsoil, all DIY. (if you can pick your nose, you can change the oil on a Harley). Total about 250 bucks.
That's it. So about 800 bucks for 22,000 miles, and that should set me fine for another six to eight thousand miles.
Front tire still good til 30,000.
No other issues. Brakes fine.
Cakeeater.
Am impressed with the miles you get on your tires.
Can you share how you do it?
nbsdave is offline   Reply With Quote
Old 03-19-2013, 04:30 AM   #66
cb1313
Oddometer: 41
Yamaha Venture
I have a 2005 Venture Midnight for sale. Cb Contact if interested
cb1313 is offline   Reply With Quote
Old 03-19-2013, 04:36 AM   #67
grelcar
grelcar's Avatar
Oddometer: 104
I replaced the stock tires on my 2010 Road King at just over 21,000 miles, Rear tire could have made it a little longer, front tire had lots of tread and two plugs in it. Not uncommon to get these kind of miles out of tires on the newer HD touring models. Other than a brake switch recall, only fluid and filters for maintenance.
grelcar is online now   Reply With Quote
Old 03-19-2013, 04:39 AM   #68
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 5,347
I think the DL650 would be the cheapest to own and operate as a touring bike. Cheap to buy, great on gas, cheap to insure and cheap to maintain.
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 03-19-2013, 04:42 AM   #69
nbsdave
Oddometer: 306
excellent, still curious-how do you do it?
engine braking on downshift or not? front brake only, speed kept under 60, tire pressure, slow acceleration?
I have never heard of 20000 miles on a rear and I want to do it too.
Old 03-19-2013, 05:11 AM   #70
Unstable Rider
10,000 Lakes
Unstable Rider's Avatar
Oddometer: 2,566
Outfit TWO new KLR's, replace the seats, and take the left over change and take a trip around the world.
Twice.
Can you get a new clutch lever for your Bmw for $5.90 at the dealer-parts counter?
That's what Kawi charges for one, OEM. $5.90.
Farm-equipment simple to work on.
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 03-19-2013, 05:18 AM   #71
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,432
I didn't read every post so others may have already weighed in with thoughts similar to what I'll observe to the OP.
Originally Posted by MHaz01 View Post
I'm going to have service work done on my BMW K1200LT this Spring. I don't have a facility or the time to do most of the work myself so I'm looking at a pretty big bill for work done by the BMW dealer.
I don't understand why it costs more to buy, mount and balance two tires on my Beemer than it does for four tires on my car, and the car tires last six times more miles.
I don't understand why replacing the front and rear suspension costs twice as much as a set of four top-quality shocks/struts for my car.
In short, I'm getting really sick of the costs to maintain my Beemer.
I ride mostly two-up and take long trips, sometimes longer than 10,000 miles. I need a good, comfortable bike for us, and one the has reduced maintenance costs. And I don't want to break the bank buying it.
What say you, panel of experts? Which bikes are worth testing with the criteria above in mind?
Your observations about the obscenely high costs of maintaining a BMW describe exactly why I got off of my last one in 2005 and have been on a Gold Wing ever since.
And the Wing matches your wished for criteria.
While I am eying the 1800's with a view getting one in a couple of years, at present I own an older GL1500 that runs flawlessly and handles perfectly. It has long since been paid for and insurance on it and the DR run me around $300 a year. Annual maintenance costs are comparable with my annual expenditures on coffee with my riding buds.
If I do the annual maintenance myself the cost is materials plus my time.
If I have it done at the local shop it is ~ $250 to have the oil, hydraulic fluids, and coolant changed. Actually, at off-years it is less because the coolant and hydraulic intervals call for every other year under normal use.
Given my riding style I get around 12,000 miles out of a rear tire, and 20,000 out of a front tire. I can mail order a new set, pull the rims myself, and have them mounted and balanced at a local independent for $35 a wheel. Total cost less than $500.
On a different tact, sometimes we fall into the trap of thinking it is about the look and the "status" and not about the riding experience. Screw the look and status -- get something that supports the enjoyment of the moment. I ride with a group of friends on an eclectic passel of bikes that include a Wing, a Moto Guzzi, a Road King, an ST1100, and occasionally a VStrom 1000. Part of breaking free of the vogue BMW neurosis is reclaiming one's soul from the clutches of the "we're all individualistically just alike" group-think.
Back to one of your comments, why is the front and rear suspension being replaced? I still have the stock springs in the front and the OEM adjustable rear shock in the GL and they work fine.
Answering the question is not necessary, but reading your comment at that point again reminds me of why I left BMW and their "we're doing you a favor by selling you our expensive to maintain, chronically needs something repaired motorcycle" attitudes.
Seriously, if you buy a GL you can look at 32,000 mile valve adjustments. And discounting the replacement of tires, which are dependent in part on the rider's style, you can look at annual costs of around $250 with the dealer servicing your bike.
FWIW
PS: and with an apologetic caveat -- I didn't start my response intending to lapse into a rant on modern the beemer crowd or their late model bikes. I know a lot of fine people who still ride them. And there are people riding every marque who embrace their own forms of neurosis...
'00 BMW R1100RT, Gone away: 5 previous BMW's, 3 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 03-19-2013, 07:10 AM   #72
BanjoBoy
BanjoBoy's Avatar
Oddometer: 878
Originally Posted by mousitsas View Post
FJR1300
As maintenance free and inexpensive to run as a (big) bike can get.
^THIS^
2007 FJR1300
2007 FZ6 (Dirt bike)
BanjoBoy is offline   Reply With Quote
Old 03-19-2013, 07:30 AM   #73
Cakeeater
Oddometer: 959
Ha, yeah: I ride the latest greatest Dunlop HD touring tire. I'm blown away by their durability...and grip. When it came time to replace...I ordered OEM, and I've never done that before.
Now...I rarely use my back brake unless I'm on gravel or really slippery stuff. Bad/good habit I learned as kid when I'd do stoppies all the time on my 10 speed...back brakes didn't do much when the tire was off the ground.
I don't do burnouts, hard downshifts or things that would obviously wear the tires out. ABS keeps it from flat spotting.
But...I do ride fast -- normally 80ish on the highway, 90-plus in the open west.
Maybe 1500 miles of the 22,000 were two-up.
Otherwise I check my air pressure, but I'm not slavish about it. I've heard of lots of guys that have this kind of mileage on their HD touring tires. No need to go darkside with this kind of wear.
Cakeeater
Cakeeater is offline   Reply With Quote
Old 03-19-2013, 08:04 AM   #74
basketcase
basketcase's Avatar
Oddometer: 1,432
And another thing!
You mentioned that your bride will be riding with you.
There is a prime reason, if not THE driving reason to look seriously at the GL1800.
Until I bought a Wing in 2004 my wife never cared about going with me on any ride. Since then she has been with me annually on a trip to the twisties in north Georgia and the mountain areas around Tellico Plains, TN. And every once in a while she jumps on the thing with me for a day trip or ride across town.
The comfort of the particular model line is unparalleled. And the intercom, sound system, and other co-rider support is second to none.
One of my brothers in law has an '03 1800 that he and his wife have ridden for nearly 100,000 miles, all of them trouble free. Their longest trip was a month long and some 9,000 miles that took in nearly all of the US lower 48, and parts of Canada.
If you are serious about her being with you, take her on the test ride with a fully equipped helmet to try out the audio systems before you pull the trigger on a choice.
Finally, I will warn you that a trailer hitch and the trailering option is a hazard to your pocket book -- if not your back. Women are genetically predisposed to filling up any amount of discretionary storage space ... which creates additional work for the significant man in her sphere of existence.
If I want my wife to hear that I'll tell her.
Seriously, co-rider comfort on a trip of the length you mentioned will be paramount to enjoyment. Make her a part of the test ride process.
Old 03-19-2013, 08:27 AM   #75
NonDairyCreamer
incomprehensible
NonDairyCreamer's Avatar
Oddometer: 95
A question for any Road King owner, present or past.
I once owned a '92 FLHS, Electra Glide Sport Moco called it, Road King now. When cruising interstates, usually 80-85, I had the slightest bit of vibration in the front end which I thought was the wind pushing the windshield. It was very subtle. Is this something anyone has noticed on later models?
Also the motor vibration had my feet always slowly sliding off the floorboards, I always wanted to find some of the boot scrapers found on bikes from many years past to mount, like stirrups.
A great bike for exploring and touring though. I wonder now if a fork damper or just tightening up the yoke bearings would fix the first problem. Maybe for the other issue some boot magnets?
"Which will you have: wise madness or foolish sanity?" Cervantes' Don Quixote
NonDairyCreamer is offline   Reply With Quote
Times are GMT -7.   It's 05:46 AM.
