Old 03-16-2013, 01:59 AM   #16
Sand Goanna
Sand Goanna
Sand Goanna's Avatar
Oddometer: 298
Cool2
Originally Posted by tHEtREV View Post
If you are getting dodgy looking Philips head screws out, give the screw driver a sharp tap or two with a hammer to help seat the driver and loosen the screw a bit...
I think thats what it does anyway...
Touch of valve grinding paste between the surfaces of the screw and driver will also help. LOTS!!
"It's only an idea, no need to shit yourself".
Sand Goanna is offline   Reply With Quote
Old 03-16-2013, 01:59 AM   #17
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 16,254
#1 Be nice to your mother.
7th Day Adventourist.
Re-incarnated
Terrafied
I have learnt a lot from my mistakes. I am heading out to make a few more.
davorallyfan is offline   Reply With Quote
Old 03-16-2013, 02:45 AM   #18
sidetrack one
Chief Tiddler
sidetrack one's Avatar
Oddometer: 5,670
Bearings come witrh basically no grease in them, always pluck the seal cover and add some grease and reseal
then use the old bearing to install
Needle rollers such as in swingarms are very thin walled, a correct size drift is nice, of course not everyone has a lathe!
I live more in 5 minutes on my motorcycle than some people live in a lifetime...............
Where are my pants?
www.buyabale.com.au.. Our farmers thank you!
sidetrack one is offline   Reply With Quote
Old 03-16-2013, 02:49 AM   #19
sidetrack one
Chief Tiddler
Oddometer: 5,670
For old school style forks, a broom handle can be jammed into the damper to lock it while removing the lower bolt
then once you have one out, you can determine what size nut you need, and make one up
PS, Suzuki PE250 is 19 mm!
Where are my pants?
Old 03-16-2013, 03:07 AM   #20
richo360
Oddometer: 917
Originally Posted by nazza View Post
If something's too hard to fix, flash your tits and some poor sucker will do it for you.
Come over to my place Naz, I will fix everything for you eventually......
700RR
richo360 is offline   Reply With Quote
Old 03-16-2013, 03:17 AM   #21
Phil_Fong
Labelled Extremist
Phil_Fong's Avatar
Oddometer: 13,172
Always expect Lentil to eat all of his BBQ'd lamb chops
tEAM nONG - Quorn Schnitzel Club
Phil_Fong is online now   Reply With Quote
Old 03-16-2013, 04:43 AM   #22
D_A
D_A's Avatar
Oddometer: 1,280
Originally Posted by sidetrack one View Post
Bearings come with basically no grease in them, always pluck the seal cover and add some grease and reseal
With slow moving bearings like head stems and swing arms this is always a good thing, but be careful not to over-fill any bearings in a high speed application. The extra grease drag causes the bearing to overheat and forces the grease out of the seal, then when the bearing cools it sucks the seal in against the bearing race and it will grind and cause early failure. This can happen on any bearing spinning 3000rpm, and higher speeds make it worse. I've seen this a bunch of times on electric motors with high speed stuff (6k rpm) being really bad for it. I don't think a bike wheel will be spinning much more than 1500rpm at 100Kph but it's still a good idea not to pack a sealed bearing too tight.
The little bit of grease that's in the bearings as delivered is the right amount to get the rated life and speed out of the bearing under the conditions used for testing, but that doesn't allow for wash-out which isn't unusual on bikes.
+1 for putting the new bearings in a bag in the freezer. The cold makes the bearing shrink and they drop into location much easier, often with no driving necessary. The same trick can be used for the shaft that goes inside the bearing ... once the bearing has warmed up and expanded again or course.
D_A is offline   Reply With Quote
Old 03-16-2013, 04:59 AM   #23
Precis
Maladroit malcontent
Precis's Avatar
Oddometer: 3,684
Originally Posted by UncleGra View Post
Yeah..I've used the socket trick before...the new cones were a bit tight to get started and that freezing thing came to mind...couldn't remember whether it was freeze the bearing or freeze the hub...either way I would have been scalded for putting bike parts in freezer...so I just blundered on..
Remember your nuts - whatever freezes, shrinks....
I met a bloke who got divorced because he put some hubcaps in the dishwasher: too bad about the paint-stripper on them - and the gold leaf on the plates that were also in there....
"I would like to die on Mars; just not on impact." Elon Musk
Precis is offline   Reply With Quote
Old 03-16-2013, 05:13 AM   #24
vagueout
vagueout's Avatar
Oddometer: 1,704
At the risk of sounding as one taking the high moral ground........ it's precisely this perception of us (suckers) blokes that in recent times has made me reluctant to help a woman in need on the road or whatever scenario. Perhaps i'm just another jaded retrosexual.
i just seek clarity
vagueout is offline   Reply With Quote
Old 03-16-2013, 05:33 AM   #25
It'sNotTheBike
Oddometer: 704
....so this is where my big idea comes in...which I invented naturally of course.....time for a pic..
Mechanics have been using old bearing races as a makeshift tool for
installing the new races in the hub for many decades. Rather than
split the race usually a slight bit of grinding around the outer circumference
of the old race to prevent it from becoming "stuck" in the hub is the preferred
method. You need to remove maybe .003" from the outer surface.
There are better ways to install the new races, such as using a
tool which is actually designed for the purpose and is made of metal which is
softer than the races or the hub so damage to the hub and races is avoided,
but if you are careful the old race works well enough.
Usually there is no need to use a freezer or that sort of thing because the
interference fit is not that "tight" and a few taps with the correct hammer
will easily seat the new races.
It'sNotTheBike is offline   Reply With Quote
Old 03-16-2013, 06:13 AM   #26
DRjoe
DRjoe's Avatar
Oddometer: 5,136
Just
Old 03-16-2013, 06:21 AM   #27
Colonial Mick
Nettle Licker
Colonial Mick's Avatar
Oddometer: 2,413
Nice ti s Na...oops tip Nazza...in the same vain...if you have had a serious accident in a remote area and you dont have a plb, sat phone , spot or the like...if you can make it to your feet..or knees even...just unzip and take a leak...a vehicle will suddenly appear out of nowhere...
Never a truer word spoken !!
"Be who you are and say what you feel.
Because those who mind don't matter
and those who matter don't mind".
Colonial Mick is offline   Reply With Quote
Old 03-16-2013, 07:02 AM   #28
KevS69
KevS69's Avatar
Oddometer: 460
Never Piss into the wind
KTM 640 ADVENTURE
KevS69 is offline   Reply With Quote
Old 03-16-2013, 12:48 PM   #29
gavo
Slacker
gavo's Avatar
Oddometer: 1,837
When fitting new bearings it is best to freeze the bearing and warm the hub,whatever as each time a new bearing is fitted some metal, just microscopic amounts are removed. Do it enough times there's no longer a resistance fit for your bearing
gavo is offline   Reply With Quote
Old 03-16-2013, 03:26 PM   #30
nazza
Trouble
nazza's Avatar
Oddometer: 2,294
It's okay, I don't flash my tits at dogs anyway. The rspca might arrest me
dr650: Charlie
My Adventure Riding Blog | Adventure Riders Blogs |
nazza is offline   Reply With Quote
Times are GMT -7.   It's 08:29 PM.
