Old 03-16-2013, 04:06 PM   #31
OzJuJu
Team Barracuda
OzJuJu's Avatar
Oddometer: 778
Buy a cheap arse bearing press..... worth every cent
XT660Z '11
TTR250 Open Enduro '98
OzJuJu is offline   Reply With Quote
Old 03-16-2013, 05:59 PM   #32
-Macca-
Oddometer: 79
Originally Posted by KevS69 View Post
Never Piss into the wind
Never fry bacon in the nude.
-Macca- is offline   Reply With Quote
Old 03-16-2013, 06:05 PM   #33
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,567
anyone got some tips on artificial insemination?
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 03-16-2013, 06:15 PM   #34
philth
philth
philth's Avatar
Oddometer: 6,280
i suffer from post insecurity and after posting I thort, hm, maybe that was a bit too disgusting, so i nuked it.... but it was true
i must not post hairy buttocks
philth is online now   Reply With Quote
Old 03-16-2013, 06:45 PM   #35
D_A
D_A's Avatar
Oddometer: 1,280
I found it funny, given the context.
D_A is offline   Reply With Quote
Old 03-16-2013, 07:01 PM   #36
UncleGra OP
CRASHING BORE
Oddometer: 3,031
yeah but...pissing into the wind is the best way to get some of your own back...
...meanwhile back at the ranch..
Valve stems make a cheap half decent punch..
and for re-seating fork seals...a 50mm rural poly joiner is good for sliding the seals home with out destroying them.
.. I fixt it...my way....gjr
Done good...Played strong... J.G.
UncleGra is offline   Reply With Quote
Old 03-16-2013, 07:03 PM   #37
UncleGra OP
CRASHING BORE
Oddometer: 3,031
Ya know when i was younger maybe 15 yrs ago..I thought that was cattle duffing...
Old 03-16-2013, 08:17 PM   #38
El Toad Man
Offroad adventurer
El Toad Man's Avatar
Oddometer: 637
Originally Posted by tHEtREV View Post
If you are getting dodgy looking Philips head screws out, give the screw driver a sharp tap or two with a hammer to help seat the driver and loosen the screw a bit...
I think thats what it does anyway...
And if that fails, sometimes I've found that tightening the screw slightly will break the seal easier than trying to undo the screw. Very handy if the screw is already mangled in the "undo" direction but still ok in the "tighten" direction.
I think carb screws on some bikes not meant to be undone. Get plenty of inox or WD40 into the threads days before you intend to undo them, plenty of time to soak does help.
KLX650C 1993
El Toad Man is offline   Reply With Quote
Old 03-16-2013, 08:52 PM   #39
fallingoff
Oddometer: 3,677
no vomitus into the wind too
fallingoff is offline   Reply With Quote
Old 03-16-2013, 09:25 PM   #40
D_A
D_A's Avatar
Oddometer: 1,280
Better into the wind than into your helmet.
Sneezing in your helmet with a cold is also not recommended.
Old 03-16-2013, 09:30 PM   #41
rutsthematter
rutsthematter's Avatar
Oddometer: 165
And never eat yellow snow.
rutsthematter is offline   Reply With Quote
Old 03-16-2013, 11:58 PM   #42
59DEN
59DEN's Avatar
Oddometer: 888
Any home made ideas ptting in and removing swing arm bearings
59DEN is offline   Reply With Quote
Old 03-17-2013, 12:05 AM   #43
fallingoff
Oddometer: 3,677
old story
put in freezer
use a drift same size as outer edge of bearing
socket etc
saw a special tool for putting in/removing swingarm bearings
i'm sure somebody will chip in with some more advice hopefully
bash jhe old ones out carefully/ don't damage swing arm
cheers
Old 03-17-2013, 01:33 AM   #44
sidetrack one
Chief Tiddler
sidetrack one's Avatar
Oddometer: 5,744
Next time you got your axles out, weld a stop on to prevent rotation, cuts out one spanner
Use a E pin instead of a split pin
While you got the welder out, make up a specific tool for your axles, this one does both axles on the DR,plus undoes the rim locks
Old school enduro rider here, old inner tubes are the only way to hold all your bits on,
Get a 5 buck watch from GO LO and stick it in plain view, essential for us old farts with diminishing eyesight!
Many headlights stay on when cranking, put an isolating switch in to give you every chance
I also run a total kill switch that I turn off every night when I'm on th e track
Weld an extesion foot on youre kickstand
Run a connection straight from your battery for your battery tender/charger, then make some lightweight jumpers with the same fitting, fine for a jump, personally tested
Install a surrender monkey, you'll be amazed how much quicker you go!!
I live more in 5 minutes on my motorcycle than some people live in a lifetime...............
Where are my pants?
www.buyabale.com.au.. Our farmers thank you!
sidetrack one is offline   Reply With Quote
Old 03-17-2013, 01:39 AM   #45
sidetrack one
Chief Tiddler
Oddometer: 5,744
When you take that sidestand spring off, put the stand down and pack the spring with coins, then retract it and the spring will fall off!
Where are my pants?
Times are GMT -7.   It's 06:56 PM.
