Old 03-16-2013, 01:47 PM   #1
cchoc OP
Outdoor Photographer
cchoc's Avatar
Oddometer: 203
2013 F800GS OEM aux lights
For 2013 BMW offers their own LED aux lights for the F800GS. The kit is called a 'retrofit' since it installed by the dealer or end user. The kit is around $800 just for parts, so it is expensive, and consists of the lights, brackets, wiring harness and a replacement switch yoke. There are multiple parts numbers in the kit priced separately, so I expect you could just purchase the switch yoke, for example.
I just had mine installed yesterday, so I don't know how much difference the lights make in the dark, but I like where they are mounted and the fact that they nicely integrate into the bike, including an indicator by the speedo show that the lights are on.
I couldn't figure out how to get a good picture of the mounting bracket without turning the bike upside down, but hopefully you can tell from the pictures how the lights mount on the brackets.
Charlie...
Stalking Light
'13 F800GS Kalamata Metallic
cchoc is offline   Reply With Quote
Old 03-16-2013, 04:30 PM   #2
runnr548
BMW Pilot
runnr548's Avatar
Oddometer: 118
Cool2
The lights and installation look great! I am a fan of the BMW factory fit & finish. They are a bit pricey, but if you like them...then they are worth it!
runnr548 is offline   Reply With Quote
Old 03-16-2013, 06:39 PM   #3
snogoose
Oddometer: 2
I agree, it looks great! Any chance you have the part numbers? In particular I am looking for the bracket to mount some Denali's in that location.
snogoose is offline   Reply With Quote
Old 03-16-2013, 08:06 PM   #4
jengel451
1 Cool MotherF#$cker
Oddometer: 799
http://www.ascycles.com/Illustrated_...indCat=77_0448
jengel451 is offline   Reply With Quote
Old 03-17-2013, 03:52 AM   #5
cchoc OP
cchoc's Avatar
Oddometer: 203
Originally Posted by jengel451 View Post
Thanks for that. Nice that they are available online now.
Sent from my iPad using Tapatalk
Charlie...
Stalking Light
Old 03-17-2013, 09:53 AM   #6
biodieselandon
biodieselandon's Avatar
Oddometer: 358
I've been wondering about that little indicator on the speedo. How are they controlled? Are they on from the switch or do they dim or shut off between low and high beems?
2013 BMW F800GS, Cordoba Blue, ASC, ESA, ABS
2012 BMW G650GS - 13,000 miles ***SOLD***
"If you're not mixing gas, you're not hauling ass!"
"A clean GS is a dirty shame."
biodieselandon is offline   Reply With Quote
Old 03-17-2013, 10:08 AM   #7
cchoc OP
cchoc's Avatar
Oddometer: 203
They are on or off by the switch - if on they stay on whether low or high beam.
Charlie...
Stalking Light
Old 03-17-2013, 10:41 AM   #8
biodieselandon
Oddometer: 358
Hmmmm... After you give us some feedback on how they do at night I might consider these over the Clearwater lights.
Old 03-17-2013, 10:50 AM   #9
Mtl_Biker
Mtl_Biker's Avatar
Oddometer: 596
Charlie, are those lights a single intensity? If they are, then I'm glad (in spite of uncertainty of how I'll mount them) I went with the Denali D2D lights.
I want two things from my lights: To be more visible to others during the daytime, and I'm sure the D2D's on low intensity will do the trick, and; 2) To be able to see better/further at night and again, with high intensity they should serve the purpose.
I'm going to try the wide lens on the left side and the spot on the right, but if on low intensity I feel the spot bothers on-coming traffic or cars right in front of me, I'll probably compromise by using the wide lens on both.
Mtl_Biker is offline   Reply With Quote
Old 03-17-2013, 11:26 AM   #10
cchoc OP
cchoc's Avatar
Oddometer: 203
The lights are single intensity. I was looking for more of a fog light than a driving light, so I think they'll do what I want, but I can understand wanting a dual intensity as well. There is enough traffic around here that I have never gotten used to driving or riding with my brights on at all.
Charlie...
Stalking Light
cchoc screwed with this post 03-17-2013 at 11:35 AM
Old 03-17-2013, 04:03 PM   #11
Farmer-Ted
Farmer-Ted's Avatar
Oddometer: 9
Looks good. Looks like BMW finally went with a normal turnsignal switch.
2012 BMW F800GS
2005 Ducati 999
Farmer-Ted is offline   Reply With Quote
Old 03-18-2013, 10:25 PM   #12
jessehere
Ridin'
jessehere's Avatar
Oddometer: 782
I like those mounts. I wonder if those brackets work on older f8s. What do the brackets bolt to? Do they bolt up to Metal or plastic parts in the beak?
jessehere is offline   Reply With Quote
Old 03-19-2013, 05:34 PM   #13
cchoc OP
cchoc's Avatar
Oddometer: 203
I've been asked to pull the plastic off and take some pictures and will do so when I can find the time. Until then I'm not sure what they mount to. :)
Charlie...
Stalking Light
Old 03-20-2013, 03:02 AM   #14
glennmack
Good Bloke
glennmack's Avatar
Oddometer: 20
Excellent thread, thanks Charlie. I'm in Australia and am considering purchasing these brackets from the US, then mounting the Denali D2D's. Has anyone successfully tried this yet?
Cheers, Glenn
"The stink of a too-loud electric guitar - that's my idea of a good time" - Frank Zappa
glennmack is offline   Reply With Quote
Old 03-20-2013, 09:12 AM   #15
Mtl_Biker
Mtl_Biker's Avatar
Oddometer: 596
Since the BMW lights and bracket are so new, it's unlikely that others have ordered the brackets only and installed other lights (yet). Charlie is the first we've heard to have gotten the whole kit.
What year is your bike, assuming it's an F800GS. I too have Denali D2D's and the optional mounting bracket that Twisted Throttle sells. On their website they show it with a prior-to-2013 model bike and the turn signals are located much lower than they are on the 2013. I'm going to install that way anyway, as it wouldn't prohibit me from changing the mount later. I'm not happy though that the lights would be so close to the turn signals.
A machine shop I visited suggested it would be a really simple matter to create a bracket that attaches to the top of the fork tubes, but thinking about it later I decided not to go that route. First of all I didn't like the idea of the lights turning with the forks (which may not actually be a bad thing) but at extreme angles the lights would likely bump into the fairings. So they'd have to be mounted FORWARD of the forks, and that I certainly don't like.
It really looks like the BMW bracket would be the best mounting option, other than for price of course. Also as long as the bracket doesn't interfere with anything else you may have installed. (In my case it's extremely unlikely the bracket will work as I used the space where the original horn was to install a Stebel Nautilus Compact air horn and I'm covering one of the bolts the bracket would use. And I'm NOT giving up my horn!)
Cheers, Glenn
Times are GMT -7.   It's 09:04 AM.
