Old 05-03-2013, 08:06 PM   #76
DisTech OP
DisTech's Avatar
Oddometer: 616
Nav tower
I know everyone is probably sick of the nav tower, but I finally committed to drilling the spacer holes!
GPS platform.
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 05-04-2013, 02:05 AM   #77
Te Hopo
AKA Deanohit
Te Hopo's Avatar
Oddometer: 1,403
I'm not sick of it mate, I'm one of those guys who likes to read and see pics of every detail, especially when it comes to work as tidy as yours is.
Te Hopo is offline   Reply With Quote
Old 05-04-2013, 03:14 AM   #78
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 1,967
Mistakenly thought this was the other 790 build that I had already seen. Opened it to make sure and presto, all sorts of wonderfulness!
Excellent build and don't worry about overposting about the nav tower. Want to see everything that it takes!
Jimmy the Heater is offline   Reply With Quote
Old 05-04-2013, 05:55 AM   #79
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,816
This is my third subscription to one of your threads -- stop it
Beautiful tower! You are very talented for this sort of thing. I can't imagine what you would be able to come up with if you used a plasma CNC machine, 3D printer, and sheet metal and tubing benders.
Carry on! Excellent work!
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 05-04-2013, 06:11 AM   #80
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,783
/\ Those guys said it for me, I even subbed to your thread, thanks for taking the time to post your work!
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 05-04-2013, 08:01 PM   #81
DisTech OP
DisTech's Avatar
Oddometer: 616
Nav tower
Well aright then! Thanks for the encouragement. And now more nav tower!
Gardgets attached!
Naked cockpit (that sounds so dirty)!
Old 05-06-2013, 08:43 PM   #82
DisTech OP
DisTech's Avatar
Oddometer: 616
Nav tower
No going back.
Hrrmm...
More vertical?
This view I like. And clearances work too.
Old 05-07-2013, 01:59 PM   #83
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,783
Looks great to me, on my Lynx fairing, I used some rubber channel to trim parts, like you could use some to close up the gap between the headlight ring and the windscreen.
Old 05-09-2013, 06:35 PM   #84
DisTech OP
DisTech's Avatar
Oddometer: 616
Thanks and thanks for the idea. You'll see in a moment why the seals probably won't work on this project.
Old 05-09-2013, 06:42 PM   #85
DisTech OP
DisTech's Avatar
Oddometer: 616
Nav tower
The screen is set more vertical and I like it better.
Nav tower series is about done. Just have to figure wire/cable routing and then it's 790 break in!
Old 05-09-2013, 10:31 PM   #86
The Breeze
Oddometer: 205
That is one F'ing sweet DR!!!!
The Breeze is offline   Reply With Quote
Old 05-15-2013, 06:23 PM   #87
DisTech OP
DisTech's Avatar
Oddometer: 616
Break in
Just got back from the beginning of a Motoman break in! Braaww, braaww, braawww! Then it started raining and rush hour traffic was sucking. Needless to say I am cold, wet and happy! The new front end is sooo much nicer, forks are firmer, bars are taller. Can't wait to see how it handles offroad. Did I mention it is taller? I can finally stand up comfortably, the BRP/Scotts submount with Pastrana FMX bars works for me!
I've got my Innovate wideband air/fuel gauge mounted temporary. Pretty interesting to watch while riding around. Expected it to show I was running much richer than it does. Says around 11 while running, 16.8 is just after it was shut off.
The 790 definitely has more torque all over, may have clutch slipping problem now.
Old 05-15-2013, 08:53 PM   #88
bkoz
bkoz's Avatar
Oddometer: 316
Very, very cool, great build thread.
How tall are you? RMZ front end + BRP mounts + Pastrana FMX bars equals one big DR.
bkoz is offline   Reply With Quote
Old 05-16-2013, 02:06 AM   #89
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,816
DisTech, did you calibrate the LC-1? It needs to be calibrated, otherwise it will show random things. Also, if you connect to it using your laptop, you can adjust the range it reports on.
Old 05-16-2013, 05:13 PM   #90
DisTech OP
DisTech's Avatar
Oddometer: 616
I'm 6'-5", so yea it's pretty tall now.
Yes, calibrated in free air it read 22.4 like it should. 16.8 was just odd because I had just turned the bike off and wheeled in inside. Gonna ride with it for a while, still think it's jetted to rich.
Times are GMT -7.   It's 07:17 AM.
