Old 03-17-2013, 02:54 PM   #1
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
Brakes
Okay guys i'm trying to figure these brakes out...If i ride spiritley than i get pretty serious fade...i have plenty of life on the pads and just bled with motul rbf600...is this just an inherent problem of the brakes not able to handle the weight and speed or is there something else i can do?
Originally Posted by Reprobate
Familiar. My stock response: "Most people die in bed. So, where do you sleep?"
Mr_Snips is offline   Reply With Quote
Old 03-17-2013, 03:04 PM   #2
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,940
Brake fade is due to your fluid overheating. Dirty or contaminated fluid is usually the cause. The easiest thing to try is simply to change out your brake fluid and make sure you bleed it completely through the lines. That SHOULD fix your problems.
akarob is offline   Reply With Quote
Old 03-17-2013, 03:20 PM   #3
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
I did yesterday. And am having the same issues today. I might try some more aggressive pads
Old 03-17-2013, 03:32 PM   #4
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,940
Well, maybe it's not fade you're experiencing. Fade is when you suddenly have no brake pressure. The lever you are pushing/pulling on will suddenly be at the limit of it's travel and your brakes wont have any effect.
If you mean that the brakes don't feel like they have enough grip to stop the bike quickly, you either have air in the lines or your brake pads and rotors probably have some oily contamination on them.
Old 03-17-2013, 03:43 PM   #5
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
At the start of my ride they felt great...just as they should. As the ride wore on (especially through some fast twisties) where i was hard on the brakes and gas the lever got mushy and hasnt returned to how it felt initially.
Old 03-17-2013, 04:01 PM   #6
It'sNotTheBike
Oddometer: 704
Originally Posted by akarob View Post
Brake fade is due to your fluid overheating. .
The brake pads and / or rotors overheating can also cause brake fade.
You imply that brake fluid boiling is the only cause.
That is incorrect. There are several other possible causes
for brake fade.
It'sNotTheBike screwed with this post 03-17-2013 at 04:09 PM
It'sNotTheBike is offline   Reply With Quote
Old 03-17-2013, 04:07 PM   #7
It'sNotTheBike
Oddometer: 704
Sounds like you need to do a proper bleeding of your brakes
and also install some new high performance brake pads.
If you are unsure of how to do the work properly,
it is well worth the cost to pay an expert to do the work.
Old 03-17-2013, 04:22 PM   #8
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
i can do the work fine...i think i'm having issues with the pads at this point just because i flushed and bled the brake system yesterday with fresh motul rbf600 fluid.
anyone have recomendations for brake pads?
Old 03-17-2013, 04:45 PM   #9
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 1,084
pads
Maybe you should try HH of the brand of your choice. HH are usually the highest performance pads
dogsslober is offline   Reply With Quote
Old 03-17-2013, 04:48 PM   #10
jas123
jas123's Avatar
Oddometer: 115
Here is something to try. Sometimes after hard braking, pads get a harder where they are creating the most heat, and need to be burnished( removal of hard spots) when riding at higher speeds lightly touch the brake for a second or 2, do it a few times. The key is to not overheat the pads, just clean them up.
Some pads hard spot easier than others. Used to race snowmobiles cross country and do some testing for Hayes brakes. After hard spotting the pads, a few brake taps on a straightaway any they were back to full strength next corner. It might do the trick.
jas123 is offline   Reply With Quote
Old 03-17-2013, 05:53 PM   #11
Bgunn
Mucha distancia
Bgunn's Avatar
Oddometer: 1,442
I'm trying some Galfer green pads. Seem to work well, some say they may have a shorter life span than stock.
Never been in love with the brakes on my 950.
Bgunn is offline   Reply With Quote
Old 03-18-2013, 02:53 AM   #12
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,681
I also prefer the organic pads.
They don't last as long, but I prefer the feel.
EBC's are cheap enough to put on more often,
and feel better then the stock KTM pads, IMO
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is online now   Reply With Quote
Old 03-18-2013, 10:33 PM   #13
amanlikemike
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 1,057
Try going up a dot from the RBF600.
Dot 5 fluid has a higher boiling point. Always helped on my track bikes. That and decent sintered pads.
Also worth checking you're not glazing the pads first time out.
Cheers,
Michael
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike is offline   Reply With Quote
Times are GMT -7.   It's 08:30 AM.
