Old 03-17-2013, 03:16 PM   #1
indr OP
Oddometer: 501
Installing Brake Disk on wheel
indr screwed with this post 02-22-2015 at 11:59 PM
indr is offline   Reply With Quote
Old 03-17-2013, 03:39 PM   #2
troidus
Oddometer: 15,705
If the bearings are in the wheel, pass the axle through and set the axle on a couple of jackstands, then give it a light spin. If it's really out of whack, you'll see it.
troidus is online now   Reply With Quote
Old 03-17-2013, 05:22 PM   #3
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Mounting should consist merely of inspection for corrosion, burrs, dings, foreign material on the mounting surfaces. If you suspect the disc is bent, use a dial indicator.
Old 03-18-2013, 01:08 PM   #4
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,614
^Yep!
It doesn't take but the smallest piece of spooge to keep the disk from sitting squarely on thte wheel . . . . NASA clean room protocols aren't necessary, but god a new old toothbrush ready . . . . .
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 03-18-2013, 11:30 PM   #5
troidus
Oddometer: 15,705
Before digging out the dial indicator and setting it up, a first-order visual check is useful to see if it's even worth the bother. If you can see either axial or radial runout, you're likely far enough out to warrant replacement and the dial indicator isn't needed.
Times are GMT -7.   It's 09:17 AM.
