03-17-2013, 03:49 PM
#1 |
Oddometer: 20
Klr 600 doohickey rebuild
The sound coming from the left side was loud. Upon aquiring in here about what could be wrong with the bike, SkiBumBrian reached out to me and offered his knowledge. He also got me started with Eagle Mike who is a real gentleman. Prior to getting into the thick of taking the KLR apart Brian offered to send me the tools needed for the job, mind you I live in NJ and Brian in CA. Having received Brians tools and Eagle Mikes upgrade I got down to business. What I found was the original spring had been replaced and had minimal tension. The real problem was with whoever did this job before me. When they put it back together, they did not line up the balancers correctly, thus causing the vibration. I pulled the balancers off and realigned the chain and balancers per the manual with direction from Brian.. I applied the upgrade, put it back together and fired her up. Problem solved. Now onto replacing the water pump seals. Thanks again SkiBumBrian!!!!
86 KLR600 / Yamoto 50cc Quad / 2006 Loncin 110 Quad / 1985 LT250EF Quadrunner / 1979 XS650 Special / 1972 Kawasaki G3SS 90 / 1973 Aermacchi X90 / 1986 Honda 450 Rebel restored / 2003 HD Deuce Screaming Eagle / 1978 Honda 550 Four (K) / BAYOU 220 / 1985 BAHA 90 / 1987 KDX 80 BruceDeuce screwed with this post 03-17-2013 at 05:16 PM |
