Old 04-03-2013, 07:52 PM   #16
_cy_
Oddometer: 6,335
yup .. your LiFePO4 battery is probably toast
still try to charge it back up with any automotive charger that has a true float mode. your LiFePO4 battery could still be good. note the pop you heard could have came from voltage regulator instead. 17v is usually not high enough to cause a cylindrical LiFePO4 battery safety to pop.
most dumb chargers will charge to about 14.2v-14.9v, then if it's got a float mode .. go down to 13.2v-13.6v range. stay away from automotive chargers that go over 14.6v.
assuming you don't own a specific to LiFePO4 charger ... use any std automotive charger .. monitor charge voltage... when battery reaches 14.2-14.4v .. remove battery from charger. then allow battery to rest overnight, voltage should read between 14.4v to 13.8 range ... LiFePO4 operates within a very narrow voltage range of 13.3v to 12.85v ... very little power from 14.6v to 13.6v ...
_cy_ screwed with this post 04-14-2013 at 07:21 AM
Old 04-03-2013, 07:54 PM   #17
veetwo _tls OP
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,850
F*#@ about 6hrs old
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 04-03-2013, 08:00 PM   #18
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,394
Originally Posted by veetwo _tls View Post
i'll grab a VR kit on ebay from roadstercycle.
FH020AA Shindengen Universal upgrade kit with free PVC wiring sheathing
Also Plug and Play kits available, I crimp solder, heat shrink everything you just connect 3 wires and your
done. Email me for an auction for these special kits.
So that means the LiFePo is stuffed
You can relocate the VR on the left side of the airbox to keep it cooler. Maybe not neccesary with the better VR but a precaustion. Also when installing it you get very good connections. Poor connections will also cause them to heat up.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is online now   Reply With Quote
Old 04-03-2013, 09:01 PM   #19
veetwo _tls OP
RENOVATIO:
Oddometer: 1,850
someone stole my airbox i don't have one oh yeh i got FCR's
yeh i relocated my OEM 6mths ago to here.
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 04-06-2013 at 05:55 AM
Old 04-05-2013, 04:48 AM   #20
veetwo _tls OP
RENOVATIO:
Oddometer: 1,850
Question
what is the best battery to use for COLD weather starting -2C & up
make etc
CHEERS: brett
MY07 950 SER
Old 04-05-2013, 04:57 AM   #21
_cy_
Oddometer: 6,335
make etc
at -1OC (14f) LiFePO4 battery will loose 50% of it's AH capacity. hence need to warm LiFePO4 battery up in extreme cold conditions by running some electric accessories before starter.
for extreme cold weather starts and/or Adv duties far from support.... recommendations is to stay with AGM or stuff the largest LiFePO4 battery you can fit in space available. main drawback is $$$$ .. both batteries shown below are about 14AH actual .. 24 cell Antigravity = 13.8AH actual
Shorai LFX36 or Earth-X ETX36 (3lb 11oz) ...
_cy_ screwed with this post 04-14-2013 at 07:10 AM
Old 04-14-2013, 09:08 PM   #22
veetwo _tls OP
RENOVATIO:
Oddometer: 1,850
Originally Posted by mountain eagle View Post
I think my R/R is gone. Voltage readings at the battery are basically unchanged when running.
Searches here indicate two choices....
Ricksmotorsportelectrics.com
Rodstercycle.com
Both are mosfet versions and not OEM, Any other options out there?
What's the preferred relocation spot?
just gone through the same problem
i was told by 2 well known members here to use this as it is the best.
i just got the The Super Mosfet Kit FH020AA (plug & play) http://www.roadstercycle.com/
from LA to OZ in 7 working days will have it at my door today.
Some info
http://www.advrider.com/forums/showt...7#post21097267
http://www.advrider.com/forums/showt...757934&page=27
VR relocation
left side of airbox:
http://www.advrider.com/forums/showp...postcount=4577
frame on left side: best i seen so far (watch his post for this bracket )
http://advrider.com/forums/showpost....postcount=4686
http://www.advrider.com/forums/showp...postcount=4631
MY BIKE:07 KTM 950 SER
MOTOBATT Battery
OEM
CHEERS: brett
MY07 950 SER
Old 04-15-2013, 05:17 AM   #23
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,394
Curious if you were able to resurrect the LiFePO battery????
Old 04-15-2013, 10:47 AM   #24
veetwo _tls OP
RENOVATIO:
Oddometer: 1,850
charging & testing will let you know
CHEERS: brett
MY07 950 SER
Old 04-22-2013, 10:22 PM   #25
veetwo _tls OP
RENOVATIO:
Oddometer: 1,850
We have tested this battery over the course of a few days, and it is functioning correctly.
It has not dropped below 13.1V and we have used to it start and run a GSXR1000 repeatedly. The battery appears to be OK.
After speaking to Antigravity we believe that this battery is simply not suitable for your bike, especially with the extra accessories fitted (lights, GPS etc)
While the lithium batteries offer many advantages over lead acid/AGM batteries (lightweight, high CCA, no drainage) the area they lack is in AMP/hour capacity.
This is the recommended battery for the KTM 950, but only in stock settings. One option is to go for a bigger battery with more AMP/hours, but it will be a physically larger battery, if you have room in your battery box for a larger battery?
We are able to take this battery back for a refund if the above solution is not suitable.
CHEERS: brett
MY07 950 SER
Old 04-23-2013, 03:04 AM   #26
rider911
Shortcut Navigator
rider911's Avatar
Oddometer: 507
Is the amp/hr rating important while the engine is running? Assuming your not using more power than your stator puts out then I would have thought amp/hr rating is not important. However I'm no electrician!
New RR ~ Across OZ... Corner by Corner
08 KTM 300 exce (small)
12 KTM 500 exc (medium)
07 KTM 990 Adv (large)
rider911 is offline   Reply With Quote
Times are GMT -7.   It's 10:57 PM.
