Old 03-18-2013, 01:22 AM   #1
1coolbanana OP
1coolbanana's Avatar
Oddometer: 1,437
Help----990 Fuel Pump
Hi guys
Needing a bit of help
Just took my fuel pump out of the OEM tank to put into a Safari tank and it no longer works.
Refitted everything, put 5 litres into the tank to cover the pump but nothing, no noise, no fuel, nothing.
Checked all the wiring and there is 12 volts at the plug.
Any help would be appreciated
Thanks in advance
Cowabunga dudes................Wuuuuka Wuka
2012 990 R
2004 950 A..........sadly missed
1coolbanana is offline   Reply With Quote
Old 03-18-2013, 01:26 AM   #2
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,145
Originally Posted by 1coolbanana View Post
Hi guys
Thanks in advance
Check if the quick disconnect is seated and locked into place correctly. Give it a push once again. The lock should "click" into place.
Even then, you should be able to hear the fuel pump cycle when you switch the ignition on. Did you check your kill switch ? is it "off" by any chance ?
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 03-18-2013, 01:26 AM   #3
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,915
I would think a cable got caught during insertion in the tanks.
A cable probably got caught and unplugged or cut. I am afraid you would have to dismantle again...
Old 03-18-2013, 01:27 AM   #4
sabink
Oddometer: 116
Hi guys
Thanks in advance
When you mount the pump in, there is a slight chance to tear off the ground connector. Have you removed the pump again and checked of all the wires are connected inside?
sabink is offline   Reply With Quote
Old 03-18-2013, 01:29 AM   #5
1coolbanana OP
Oddometer: 1,437
Yes, the quick connect was good and Ive been using the kill switch to cycle the system.
Ive removed the tank from the bike again and everything looks as it should.
Do you mean the wie around the outside of the pump body that live in the fuel?
2012 990 R
Old 03-18-2013, 01:31 AM   #6
1coolbanana OP
Oddometer: 1,437
Havent taken the pump back out yet, looks like Ill have too
Man these Safari tanks suck for fit and finish.
I had to dremel the pump mounting bolt holes (elongate them) to be able to bolt it on.
The main O ring is also a very loose fit, is that normal?
2012 990 R
Old 03-18-2013, 01:33 AM   #7
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,145
with the pump out of the tank now, check if the pump is getting 12V at the female spade terminals ? If it does, then the problem could be with the pump motor. Else the problem is a damaged/torn wiring between the main connector harness and the harness on the pump side.
Old 03-18-2013, 02:05 AM   #8
1coolbanana OP
Oddometer: 1,437
Thanks for the responses guys, found the problem.
Id dislodged one of the internal spade connectors from inside the pump.
All back together and plugged it in and it makes noise so Ill put it back into the tank and see what happens
Thanks very much
2012 990 R
Old 03-18-2013, 03:41 AM   #9
1coolbanana OP
Oddometer: 1,437
Yep........all good now, thanks guys
2012 990 R
Times are GMT -7.   It's 05:45 PM.
