Old 05-24-2013, 03:52 AM   #31
Soliecirc
Oddometer: 19
Everything works. Finally got around to testing it all out. Removed the tank to access the relay. (Under tank unlike others where it is in the headlight bucket)
Replacing the stock green with The LED one was easy. Just unplug And plug in the new. The idiot light works, the stock front flasher work along with the led rear flasher and beacon 2.
Sabre, your memory did not fail you. I needed to switch the red and yellow to have the signals override the brake.
Thanks for all the help!
https://www.dropbox.com/s/9g12f5ch77...%2000%20AM.jpg
1986 R65
Soliecirc is offline   Reply With Quote
Old 05-27-2013, 03:47 PM   #32
Sabre170
Sabre170's Avatar
Oddometer: 263
Congrats!! Glad it all worked out for ya!
Sabre170 is offline   Reply With Quote
Old 05-28-2013, 01:41 PM   #33
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,298
So FYI, I got some led signals from ebay. Total junk!!! My incandescents were way brighter. Anyway, I keptf the electronic flasher relay and it works with either. SCORE! Anybody recommend some smallish LED signals that are ultrabright and not a million bucks.???
Old 05-28-2013, 11:57 PM   #34
Soliecirc
Oddometer: 19
Originally Posted by Sabre170 View Post
I just installed THESE.
I got the ones here and they seem bright. Which ones did you get, I probably looked at all of them
1986 R65
Old 01-14-2015, 09:37 PM   #35
Soliecirc
Oddometer: 19
So I may have messed something up?!?! Long story short I was replacing the brake light. Was fiddling with the wires to hook up the new tailight and carelessly hooked up the wrong wires. Turned key and there was a POP and the running lights stopped working. Everything else works fine, just the running tailight does not work. I troubleshot with a working tailight and turn signals that operate with a running light and all functions work with the exception of the running light. What is the fix? Is there a fuse? A new relay? Hopefully something easy. Hopefully someone sees this and can help..,
1986 R65
Old 01-14-2015, 10:54 PM   #36
Soliecirc
Oddometer: 19
Found the issue, blown fuse
1986 R65
Times are GMT -7.   It's 08:05 AM.
