Old 03-18-2013, 03:12 PM   #16
catalina38
Contrarian
Oddometer: 1,622
Low tire pressure is only going to get you a flat tire and a bent rim. The previous photo shows good body position and be sure to steer with foot pressure not the bars. Look ahead to where you want to go, not down in front of the bike. Going fast will mask bad technique and since you will have to turn or slow down for obstacles at some point you may as well learn to do it right so you can go fast or slow, whichever speed is right for the terrain in front of you.
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 03-18-2013, 03:18 PM   #17
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,732
Originally Posted by catalina38 View Post
low tire pressure is only going to get you a flat tire and a bent rim. The previous photo shows good body position and be sure to steer with foot pressure not the bars. Look ahead to where you want to go, not down in front of the bike. Going fast will mask bad technique and since you will have to turn or slow down for obstacles at some point you may as well learn to do it right so you can go fast or slow, whichever speed is right for the terrain in front of you.
+1
traveltoad is offline   Reply With Quote
Old 03-18-2013, 03:36 PM   #18
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,937
In that pic my tire pressure is 30F/30R
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 03-18-2013, 04:01 PM   #19
Sumi
Sumi's Avatar
Oddometer: 1,799
+1 on throttle:) get as fast as possible to a minimum of ~50-60km/h (30-40mph).. I also like to keep the rpms at about 5-6k.. then the front will somewhat float on top of the sand, staying on it's path more or less (the bikes momentum keeps it on the path I guess).. some say that it's better if you transfer your weight as back as possible.. It's scary, and I've seen bad accidents in sand.. but you have to build up and maintain speed (I know it doesn't seem logical when you are there, and it's scary), or the front will just wash out. You can kind of feel when you get to the minimum required speed, as the bike keeps going forward, no matter where the front wheel is pointing (ofcourse in limits). Also IMO the tkc front sucks in sand (at least for learning)... but then again the 9x0 also isn't the ultimate "how to learn riding in sand" tool
Edit: Sorry, I've read now, that you've been desert racing.. so nevermind my post:)
Sumi screwed with this post 03-18-2013 at 04:15 PM
Old 03-18-2013, 04:21 PM   #20
icebergstu
Husqvarna Tragic
icebergstu's Avatar
Oddometer: 491
I dont have a 990 but setting you clickers and tyre pressure is the key. It takes 5 minutes and will turn sand from a burden into a pleasure regardless of dampeners.
CLICKERS:
COMPRESSION - You need to be 3/4 to maximum hard
REBOUND - You need to be 3/4 to maximum hard plus 5 clicks (I think the WP have a vast amount of clicks so 5 should do.
This will keep your front wheel from bouncing too much and get your front wheel pushing back into the sand quickly where all the traction is.
TYRE PRESSURE:
Use the rim clean method - Take your front tyre pressure down to say (Big heavy bike hmmmmm) 15psi. Ride for a few hundred meters in dusty sand and if you see a line where the tyre has cleaned the edge of the rim that is the rim clean line. It needs to be about 2mm to be perfect but will vary slightly.
The pressure will vary from bike to bike, tyre to tyre. There is no set standard PSI
This Video will help with rim clean
Try these methods and I am almost positive you will get fantastic results.
Stu
Husqvarna TE610 Adv
Husqvarna WR 300 2T
Honda CT110
icebergstu is offline   Reply With Quote
Old 03-18-2013, 08:40 PM   #21
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,937
Stu
hahahahaha.....15 psi on a 990......hahahahahahahahaaa.....sigh.....hahahahah a
Old 03-18-2013, 08:47 PM   #22
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,732
It's not the tire pressure... trust me on this one.
Old 03-18-2013, 11:12 PM   #23
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,201
Sand scares the shit out of me in (on) any vehicle, and the fact that there seem to be as many notions about how to ride it as there are recipes for spaghetti sauce doesn't lead me to believe I'd be successful at it on the 990.
I think I'll take the pussy way out & avoid sand at any opportunity.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 03-19-2013, 12:48 AM   #24
icebergstu
Husqvarna Tragic
icebergstu's Avatar
Oddometer: 491
As I said...rim clean cant be put down to tyre perssure but I figured you guys need all the help you can get... I dont own a horrifically heavy overrated Bajaj so I cant tell what good tyre pressure is which is why you use rim clean method.
Better than your idea anyway genius! ;)
Stu
Husqvarna TE610 Adv
Husqvarna WR 300 2T
Honda CT110
icebergstu screwed with this post 03-19-2013 at 01:39 AM
Old 03-19-2013, 03:00 AM   #25
Lc8grrr
Vtwin madness
Lc8grrr's Avatar
Oddometer: 442
So Meoni had 30psi Mousse in his 950Rally when he won Dakar... A fully fueled 660Rally weighs the same as a 950A with 5L in the tank and they run mousse at about 15psi. Someone better tell the factory they're wrong.. First i've heard of rim clean but looks the goods thanks
Lc8grrr is offline   Reply With Quote
Old 03-19-2013, 03:46 AM   #26
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 908
Lets not forget that stock rims are butter... Dropping pressure will increase the chances of these against a rock, tree seed, hard dirt or a very stiff desert worm
690R
Old 03-19-2013, 10:54 AM   #27
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,937
Well if you run the rims that the factory supplies to Meoni et al and if you have a crew to change your mousse every evening and if you can loft the front wheel at anytime like a factory racer and if you get a new rim at not cost and if you can ride a taco'd wheel out like Meoni...and if you like advice from a guy who doesn't own a 9x0
try 15 psi....
Old 03-19-2013, 11:48 AM   #28
duckboy810
duckboy810's Avatar
Oddometer: 243
i rode my 990 for my first time in real deep dry 2 track sand in ocala FL (mefo rear and pirelli scorp front prob dropped air down to about 30-35) and after about a half hour i found if i hit the throttle and looked ahead as soon as i started to get squirrely it helped alot
KTM ADV 990R
SUZ DRZ 400S
KAWI KLR 250
Instagram: Duckboy810
duckboy810 is offline   Reply With Quote
Old 03-19-2013, 12:51 PM   #29
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,288
Gas, keep standard amount of air in the tire and then more gas. Get in the upper range of revs and find a spot where you can test riding positions. Try ride with the legs tight around the bike, standing and sitting. Get used to the amount of gas it needs.
What i think when riding is like go skiing and it just control with pushin the footpegs and gas.
http://www.youtube.com/watch?v=TiIsLi95fJ4
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 03-19-2013, 01:59 PM   #30
Gustavo.Ramos
Oddometer: 908
Imagine there's a big dog barking and running behind you. Hit the gas, move your ass closer to the rear and aim your sight at where you want to go!
don't go too fast, some trees might not move away from your path fast enough!
690R
Times are GMT -7.   It's 03:08 AM.
